Physical theory a pre-requisite for asking questions?
  • Thread starter Blogical
In summary, it is not necessary for a physical theory to be a pre-requisite for asking questions in modern physics. However, any hypothetical situations or thought experiments must be based on current knowledge and constraints. It is important to reference any mathematical models or theories, and to provide as much information as possible when asking questions in order to receive accurate responses. It is also possible for misunderstandings to occur, so it is important to clarify and provide evidence when discussing concepts from published works.
Blogical
Physical theory a pre-requisite for asking questions??
Should a physical theory be a pre-requisite for asking questions in modern physics?
Both of my previous threads were locked and received lot of criticism because i asked regardind a space-craft moving faster than c, I would just like to point out that there is a mathematical description of a universe in which particles travel faster than c, and also i would like to point out the "THE BLACK SWAN EFFECT", so if there is a new phenomenon, should we rather not examine it because "THERE IS NO PHYSICAL THEORY TO EXPLAIN IT" or should we develop new theory to explain this phenomenon.
Should we not encourage new theories just because they lack proof or due to other reasons!
William cowper said that:
"Absence of proof is not proof of absence"
I also want to know "Is discussing of physical theories which do not have any credible evidence like String theory or Quantum theory of Gravity allowable in this forum??"
If yes, i really don't get the difference between why asking question which are not supported by any physical theories not allowed while physical theories which do not have any experimental backing being allowed to discuss?
Your thread has been sufficiently answered. There is currently no experimental evidence of particles going faster than light (that I know of), so there is no need for a physical theory. So what you have asked is going against mainstream physics and we have pointed that out.
If there is a physical theory out there that is published in mainstream journals and that allows for particles going faster than c, then you can start a thread about it. But if you ask whether what happens if a spaceship goes faster than c, then the only correct answer we can give is: it can't (according to the current understanding of physics).
I posted the initial thread because i was of the same opinion as you guys regarding the space-craft traveling faster than c but was surprised when the same scenario was used in the chapter Special Relativity of the book "Concepts of modern physics" by Arthur Beiser to explain the very fact nothing can travel faster than c, so i wanted to clarify regarding this and hence i posted that thread!
Well, we gave you an answer. It is an experimental fact that nothing can go faster than c. There's nothing more that can be said about it.
Basically, yes.
A hypothetical situation (or thought experiment) has to be constructed from and within what is current knowledge. The whole point of it is to present a situation and then analyze its results and implications. That process can't function if the basis for the hypothesis comes from outside current formalisms because there will be no constraints on the possible mechanisms one can come up with, and no basis for supporting or denying them in present knowledge.
Don't confuse a hypothesis that goes against current knowledge with a "new phenomenon".
Many folks in this forum are highly trained and experienced in analyzing things like this. One of the first things they will do in examining a hypothetical situation is check to see if any assumptions are not met to determine if it is in violation of current knowledge. Sometimes this is not so clear at the very edges of what is known and unknown, but the basic "c check" is going to be the first one in the relativity forum.
Blogical said:
... I would just like to point out that there is a mathematical description of a universe in which particles travel faster than c..
If you want to reference such a mathematical model, and e.g. ask about how its consequences differ from the known universe, this might(?) be ok, but you have to reference it first. Honestly, how can the question get any answer in principle otherwise.
Then what is given in the book is wrong??
Its hard to believe that a book and author of such repute will make such a grave mistake!
You never actually cited the book. It is more likely that you misunderstood what is says.
If you want to start a thread to ask questions, then you need to give us all the information.
If you ask "What will happen if this spaceship moves faster than c", then the only answer we can give is that spaceships don't move faster than c.
If you would have added that you read something in a book that you didn't understand and if you gave us the relevant passage, then our answer would be very different.
You can never give too much information in your post.
I'm reading Shrödingers Kittens by John Gribbin right now and in order not to come across as a crackpot I'll quote:
john gribbin in Shrödingers Kittens said:
"The special theory of relativity does not say that it is impossible in principle for something to travel faster then light. What it does say is that it's impossible to cross the speed of light barrier."
This led to speculation that there might be particles that travel faster then light (called tachyons), but there's no experimental evidence of their existence.
Conventionally interpreted, it does say no. Adding the feature of particles with imaginary mass, you have tachyons. A rocket (made of ordinary matter) will never exceed c (per the theory). A tachyon must alway move greater than c. If tachyons can interact with normal matter, a variety of causality issues arise (for which various solutions have been proposed - in the speculative realm).
Upshot: none of the is relevant to the original question of rocket presumed to be made of ordinary matter.
This question has been answered.
Related to Physical theory a pre-requisite for asking questions?
1. What is physical theory?
Physical theory is a set of principles and laws that explain the behavior and interactions of physical phenomena in the natural world. It is based on empirical evidence and mathematical models that have been tested and refined over time.
2. Why is physical theory important?
Physical theory is important because it allows us to understand and predict the behavior of the physical world. It also provides a framework for conducting further research and developing new technologies.
3. What are the pre-requisites for understanding physical theory?
A strong foundation in mathematics and scientific principles is necessary for understanding physical theory. It is also important to have a curious and analytical mindset and to be open to new ideas and evidence.
4. How does physical theory differ from other scientific theories?
Physical theory is specific to the study of the physical world, while other scientific theories may focus on different areas such as biology or psychology. Physical theory also relies heavily on mathematical models and experimentation.
5. Can physical theory change over time?
Yes, physical theory is constantly evolving as new evidence is discovered and new technologies are developed. What we understand as scientific fact today may be revised or expanded upon in the future as our understanding and methods of studying the physical world improve.
  • Feedback and Announcements
  • Beyond the Standard Models
