Precipitation of lead hydroxide in the presence of EDTA
In summary: Let me check if I'm confusing some things here.No, Hess's law has nothing to do with enthalpy. It states that if you can write the reaction as a sum of two or more reactions, the equilibrium constant for this reaction is the product of equilibrium constants of the reactions you summed. Here you can't write it as a sum of two reactions, but you can write it as a product of two reactions and their equilibrium constants, that's the same thing. See the difference?Another difference is that Hess's law is exact. This is a trick, which is quite accurate in some cases, but not exact. It's a difference that is important to know.In summary, EthyleneDiamineTetra-acet
TheSodesa
224
1. The question
EthyleneDiamineTetra-acetate(##EDTA^{4-}##) is used in chemical analysis as a complex-former. ##EDTA^{4-}## is also used to treat heavy metal poisoning, as it forms water soluble complexes with them which can then be easily removed by the body. The reaction of ##EDTA^{4-}## with lead is:
$$Pb^{2+}(aq) + EDTA^{4-}(aq) \rightleftharpoons PbEDTA^{2-}(aq), K = 1.1 \times 10^{18}$$
0.010 mol of ##Pb(NO_3)_2##-solution is added to 1 liter ##(dm^3)## of buffered water solution (pH = 13), whose ##Na_4 EDTA## concentration is 0.050M. Does the added lead precipitate in the form of ##Pb(OH)_2##-salt?
\begin{array}{|l|c|}
Some \ values\\ \hline
K_s(Pb(OH)_2) & 1.2 \times 10^{-15}\\
K & 1.1\times 10^{18}\\
n_0 (Pb(NO_3)_2) & 0.010 mol\\
[Na_4 (EDTA)]_0 & 0.050M\\
pH & 13
\end{array}
If our chemical reaction is
$$aA + bB \rightleftharpoons cC + dD $$
then our equilibrium constant
$$K = \frac{[A]^a [ B ]^b}{[C]^c[D]^d} $$
The solubility constant would be
$$K_s = [ C ]^c [D]^d$$
since the activity ##a_s## of the pure solid on the left side of the reaction equation is 1.
I managed to solve this, I just need a second opinion on whether my solution is correct.
The lead is going to precipitate if the reaction quotient
$$Q > K_s$$
To see if this holds, I need to find out the concentration of lead in the solution. I'm going to assume that the added ##Pb(NO_3)_2## dissolves completely and then reacts with the ##EDTA^{4-}##, before the remaining lead from this reaction then reacts with the ##OH^-##-ions. Below is a table of the first reaction.
concentration & Pb^{2+} & EDTA^{4-} & PbEDTA^{2-}\\ \hline
beginning & 0.01 & 0.05 & 0\\
end & 0.01-x & 0.05-x & x
\end{array}
We can then solve for ##x## using ##K##:
\begin{align*}
K
&= \frac{x}{(0.01-x)(0.05-x)}\\
\iff\\
&(0.01-x)(0.05-x)K = x\\
\iff\\
&\frac{1}{2000}K-0.06Kx + Kx^2 = x\\
\iff\\
& Kx^2 -(0.06K+1)x + \frac{1}{2000}K = 0
\end{align*}
Solving for ##x##:
\begin{align*}
x
&= \frac{(0.06K+1) \pm \sqrt{(0.06K+1)^2 - 4K\times \frac{K}{2000}})}{2K}\\
\begin{cases}
1/20\\
1/100
\end{cases}
\end{align*}
Now ##1/20 = 0.05## won't do, since ##(0.01-x)## would be negative. Plugging in ##x = 0.01## gives us the concentration of lead after the reaction which is ##[Pb]_1 = (0.01 - 0.01) = 0##. Therefore at these concentrations there is no lead left over to react with the ##OH^-##-ions, and there can be no precipitate.
This is a desirable result, considering the use of EDTA in medicine, but this seems too easy. I must be missing something or making wrong assumptions.
No, concentration of Pb2+ is not zero. Both 1/20 and 1/100 are only approximations. What they do tell you though is that the Pb2+ is complexed almost entirely, with concentration of the complexed form equal - for all practical purposes - 0.01 M. Plug this number (together with the concentration of the free EDTA4- left after the reaction) into the K equation and calculate equilibrium concentration of the Pb2+.
If I understood you correctly, I'm supposed to invoke Hess's law, meaning one can assume all of the lead reacts with EDTA and then the reverse reaction happens, but then instead of using
$$K = \frac{[PbEDTA^{2-}]}{[Pb^{2+}][EDTA^{4-}]},$$
I should use the equilibrium constant of the opposite reaction
$$K_o = \frac{[Pb^{2+}][EDTA^{4-}]}{[PbEDTA^{2-}]} = \frac{1}{K}.$$
Then if ##y## is the concentration of lead after the reaction,
\hline
concentration & [PbEDTA^{2-}] & [Pb^{2+}] & [EDTA^{4-}] \\ \hline
beginning & 0.01 & 0 & 0.04\\
end & 0.01 - y & y & 0.04 + y\\
\hline
\end{array}
Then
\begin{align*}
K_o
&= \frac{1}{K} = \frac{(y) (0.04 + y)}{0.01 - y}\\
\iff\\
& 0.01 - y = (y)(0.04 + y)K\\
\iff\\
& 0.01 - y = 0.04Ky + Ky^2\\
\iff\\
& Ky^2 + (0.04K + 1)y - 0.01 = 0
\end{align*}
Solving for y
\begin{align*}
y
&= \frac{-(0.04K + 1) \pm \sqrt{(0.04K + 1)^2 - 4K \times 0.01}}{2K}\\
\begin{cases}
0\\
\frac{-1}{25}
\end{cases}
\end{align*}
Again, ##\frac{-1}{25}## obviously won't do, so the concentration of lead after the reverse reaction is 0. Unless I plugged something in incorrectly, I still don't get any lead.
Ninja edit: I let Wolfram Alpha do the math, and instead of doing what my cheap-o pocket calculator did (rounding to zero), it produced ##y = 2.27273 \times 10^{-19}##.
This allows us to calculate the value of the reaction quotient $$Q = [Pb^{2+}] [OH^{-}]^2$$
Here $$[OH^{-}] = 10^{-1},$$
since
$$pH + pOH = 14 \iff pOH = 14 - pH = 1$$
and
$$pOH = -lg[OH^{-}]$$
Now
\begin{align*}
Q
&= [Pb^{2+}] [OH^{-}]^2\\
&= (2.27273 \times 10^{-19})(10^{-1})^2\\
&= 2.27273 \times 10^{-21},\\
\end{align*}
meaning ##Q<<K_s## and the lead won't precipitate.
EDIT2: I got my ##K## wrong in the OP, it seems (reversed order of products and reactants). I blame trying to type in ##LaTeX##.
No idea why you invoke the Hess's law, it is completely unrelated.
No need for ICE table here, nor most of the things you did. You have correctly stated that
[tex]K = \frac{[PbEDTA^{2-}]}{[Pb^{2+}][EDTA^{4-}]}[/tex]
Just solve for [Pb2+] and plug in concentrations of PbEDTA2- as 0.01 M and concentration of EDTA4- as 0.04 M. This is not exact, but good enough. 0.01-2.3×10-19 is close enough to 0.01 that the exact number doesn't matter. Tr to do teh calculations the way I told you and you will see for yourself.
This kind of approximation is often a must when dealing with equilibrium calculations, as a rule of thumb if you add or subtract two numbers and one is smaller than 5% of the other, you can ignore it and see if the results make sense. That is 1+0.05≈1-0.05≈1.
Ok, so
\begin{align*}
[Pb^{2+}]
&= \frac{[PbEDTA^{2-}]}{K[EDTA^{4-}]}\\
&= \frac{0.01}{(1.1 \times 10^{18})(0.04)}\\
&= 2.\overline{27} \times 10^{-19}\\
&\approx 2.27 \times 10^{-19}
\end{align*}
Yeah, the exact same result.
As for Hess's law, I was under the impression, that the reason we can make the assumption that the first reaction goes to completion and then returns to the wanted state while still producing the desired value is because enthalpy is a state function.
Enthalpy is not enough to describe the reaction.
Related to Precipitation of lead hydroxide in the presence of EDTA
1. What is the purpose of using EDTA in the precipitation of lead hydroxide?
EDTA, or ethylenediaminetetraacetic acid, is a chelating agent commonly used in the precipitation of lead hydroxide. It forms strong bonds with metal ions, including lead, which helps to stabilize the precipitate and prevent its re-dissolution. This allows for a more efficient and complete precipitation of lead hydroxide.
2. How does the presence of EDTA affect the solubility of lead hydroxide?
The presence of EDTA decreases the solubility of lead hydroxide in water. This is because EDTA forms complexes with lead ions, removing them from the solution and making them less likely to react with other substances. As a result, more lead hydroxide can be precipitated out of the solution.
3. Can other chelating agents be used instead of EDTA for the precipitation of lead hydroxide?
Yes, there are other chelating agents that can be used in place of EDTA for the precipitation of lead hydroxide. Some examples include citric acid, oxalic acid, and tartaric acid. However, EDTA is often preferred due to its strong chelating ability and stability over a wide range of pH levels.
4. What is the ideal pH range for the precipitation of lead hydroxide in the presence of EDTA?
The ideal pH range for this process is typically between 9 and 11. At lower pH levels, the lead hydroxide may not precipitate as readily, and at higher pH levels, there is a risk of the EDTA breaking down and losing its chelating ability. Therefore, maintaining a slightly alkaline pH is important for the successful precipitation of lead hydroxide.
5. How can the presence of other ions affect the precipitation of lead hydroxide in the presence of EDTA?
The presence of other ions, particularly those that form strong complexes with EDTA, can interfere with the precipitation of lead hydroxide. These ions may compete with lead ions for binding to EDTA, reducing the amount of lead available for precipitation. It is important to consider the concentration and composition of all ions in the solution when using EDTA for the precipitation of lead hydroxide.
  • General Math
