Prestressed concrete - tension in steel cables
In summary, prestressed concrete works by using steel bars that are pulled and elongated, then surrounded by concrete under tension. Once the concrete dries, the tension on the steel is released, causing the concrete to be compressed. This results in a convex shape on one surface and a concave shape on the other. The ratio of steel to concrete must be optimized for the desired forces, and the placement of the steel depends on the type of structure. Tensioning can be more difficult if the concrete shrinks during the curing process, but some types of concrete can expand and tension the steel.
fog37
1,568
108
Hello Everyone,
I was learning about prestressed concrete and how it works. Concrete is very strong under compression but weak under tension. In the case of prestressed concrete, the steel bars are pulled and become elongated.
  • How much do the steel bars elongate when they are pulled?
  • The concrete then poured around pulled steel bars under tension. The tension on the steel bars is later released once the concrete dries. That puts the concrete under compression since it gets squeezed by the steel bars trying to return to their original length. The final concrete slab ends up bulging upward (convex shape) on one surface (that surface is under tension) and bulging inward at the other surface (which is in a state of compression). Wouldn't that tension at one of the surface make the concrete weak? Why would it make it stronger? I see how, once a load is applied to the concrete slab, the convex surface under tension becomes flat and so does the concave surface under compression.
Thanks!
There is no advantage in stretching the bars beyond the elastic limit.
When the external tension is removed, the concrete is compressed by the steel. To optimise the result you must get the ratio of steel to concrete right. Where you place the steel in the slab is dependent on the forces the slab must handle. A cantilever will have more steel at the top, a beam between two supports will have more steel at the bottom.
Concrete may shrink slightly during the curing process which makes tensioning more difficult. There are a few types of concrete that expand and so tension the steel.
Related to Prestressed concrete - tension in steel cables
1. What is prestressed concrete?
Prestressed concrete is a type of reinforced concrete that uses tension in steel cables to increase the strength and durability of the structure. This process involves preloading the concrete with stress before it is subjected to any external load, which helps to counteract any potential tensile forces that may arise.
2. How does tension in steel cables affect prestressed concrete?
Tension in steel cables creates compressive stresses in the concrete, which helps to prevent cracking and increase the load-bearing capacity of the structure. This method is more efficient than traditional reinforced concrete, which relies solely on the strength of the concrete to resist tensile forces.
3. What are the benefits of using prestressed concrete?
Prestressed concrete offers several advantages, including improved structural strength and durability, reduced material and labor costs, increased span lengths, and improved resistance to environmental factors such as corrosion and seismic activity.
4. How are the steel cables tensioned in prestressed concrete?
The steel cables are tensioned using a hydraulic jack or specialized equipment after the concrete has been poured and has gained sufficient strength. The cables are anchored at both ends of the structure and are then stretched to the desired amount of tension before being secured in place.
5. What are some common applications of prestressed concrete?
Prestressed concrete is commonly used in the construction of bridges, parking garages, high-rise buildings, and other large structures that require high strength and durability. It is also used in the production of precast concrete elements, such as beams and columns, for use in various building projects.
16K
  • Beyond the Standard Models
  • Materials and Chemical Engineering
14K
  • Astronomy and Astrophysics
