Principal stresses 3D, solving for direction cosines n1,m1,n1
In summary, the OP stated that Gauss-Jordan isn't appropriate, that some ordinary algebra could be used to eliminate a variable or two, that the determinant of the OPs equations should be zero, and that the purpose of the 4th equation is to establish a unit vector in the principal direction.
jan2re
Member warned that an effort must be shown
-4.882L1+M1+2N1=0
L1-2.882M1=0
2L1-0.882N1=0
L1^2+M1^2+N1^2=1
How to solve for L1 ,M1 and N1 ?
0<L1,M1,N1<1
You must do better than that. We require that you show some effort in the Attempt At Solution part.
I have tried back substition ,gauss jordan,matrices and so on ,but this is only a simple math problem so i don't want to spend 1 hour typing in all this mathematics .
Are you saying you can’t solve this by hand?
It wouldn't take an hour to type at least some effort.
Gauss-Jordan isn't appropriate, since this isn't a linear system. Some ordinary algebra could be used to eliminate a variable or two.
Solve the 2nd equation for M1 in terms of L1 and the 3rd equation for N1 in terms of L1. Then substitute the results in 4th equation to obtain L1. Hopefully when substituting the results into the first equation, it will be satisfied identically.
So, do I understand that you want US to do the typing instead?
You should post what you have attempted. From my quick look at it, you may not have specific values of L1 M1 and N1 and might just be left with one of them in terms of another. But you should be able to narrow a range of values (possibly better than 0 to 1).
The object of this calculation is to get a unit vector in one of the three principal directions (probably of stress). The calculation arrived at the present point by using the Cauchy stress relationship to find the directions in which the traction vector acting on a surface is normal to the surface. This identifies the magnitudes of the three principal stresses, and is designed to determine their directions. The OPs set of equations is supposed to find the principal direction for one of the principal stresses. The three homogeneous linear algebraic equations are supposed to have more than the null solution, so the determinant of the OPs equations should be zero (i.e., the three equations should be linearly dependent). I haven't checked to see if the determinant is zero, but it's easy enough to do, and the OP should already have done this. The purpose of the 4th equation is to establish a unit vector in the principal direction, by setting its magnitude equal to unity.
Likes jan2re
Chestermiller said:
The object of this calculation is to get a unit vector in one of the three principal directions (probably of stress)...
Thanks. That makes sense.
Thanks for your answer, maybe i should have posted this in another topic.This is from a lecture in Advanced Mechanics and not homework, i have the complete solution M=0.019, L=0.055 N=0.1256. So the case is how to manage to solve for this values the easiest way. i have written 6-7 pages i attempt to solve this so i didnt see why i should bother to write it here. I have tried to get rid of variables by isolate one of the variables ex. L and put it into the other equations and so on but it got messy and i also was left with terms with 2 unknowns like M=2.345N .When i then used this terms in my fourth equation L^2+M^2... i didnt manage to get it right.Also tried to add equations to get rid of variables but because of the nulls i didnt manage to do so. So my question is how to solve this sets of equations ? You don't have to solve it ,just which method is the best. Sorry to have used the homwork topic,and not explaining it properly.
Step 1: Check the determinant of the 3 linear equations to make sure that they are linearly dependent (such that the equations have more than just the null solution). I calculated the determinant, and it did indeed come out to 0. So you can discard one of the equations. In this problem, the easiest one to discard is the first equation.
Step 2: Solve for two of the variables in terms of the third:
M = 0.347 L
N = 2.27 L
Step 3: Substitute into the direction cosines equation:
$$L^2+(0.347L)^2+(2.27L)^2=1$$This yields $$L=0.40$$$$M=0.139$$$$N=0.907$$
Sorry, but these don't agree with your results. The sum of the squares of your results don't add up to 1.
The equations you start with are inconsistent, so have no solution. If you substitute in your alleged "solution" into those equations, you can see that it does not work.
How do I know they are inconsistent? Well, just try solving one variable at a time (using notation ##L,M,N## instead of ##L1,M1,N1##):
$$ \begin{array}{ccc} L-2.882 M = 0 & \Rightarrow & M = .3469812630\: L \\
2 L-.882 N = 0 & \Rightarrow & N = 2.267573696\: L
\end{array}
Thus
$$-4.882 L+M+2 N = 0.1286550\times 10^{-3} \: L$$
In order for this last quantity to be zero we would need ##L = 0##, but that would give ##M=N=L=0##, making the fourth equation invalidl
Likes jan2re
\end{array}
Thus
The coefficient of L you calculated is just roundoff. For all intents and purposes, this coefficient is zero. So, as I said in my response, anyone of the linear equations is redundant, and can be discarded. The solution I gave in my response is the correct one.
When I apply your method (but keeping more accuracy during the computations and just rounding at the end) I get
$$\begin{array}{c}
L = 0.397\\
M = 0.174\\
N = 0.901
\end{array}
I just let Maple do all the calculations.
Likes Chestermiller
Related to Principal stresses 3D, solving for direction cosines n1,m1,n1
What are principal stresses in 3D?
Principal stresses in 3D refer to the three normal stresses acting on a point in a three-dimensional stress state. They represent the maximum and minimum values of normal stress that a material experiences at a given point.
How do you calculate principal stresses in 3D?
To calculate the principal stresses in 3D, you need to use the direction cosines n1, m1, and n1. These are the direction cosines of the normal vector to the plane on which the principal stress acts. Using these direction cosines, you can determine the magnitude and direction of the principal stresses using stress transformation equations.
What are direction cosines in principal stresses?
Direction cosines in principal stresses are used to determine the orientation of the principal stress relative to the coordinate axes. They are represented by n1, m1, and n1 and are calculated by taking the cosine of the angle between the normal vector to the plane and the coordinate axes.
What is the significance of principal stresses in 3D?
Principal stresses in 3D are important because they provide information about the stress state at a given point in a three-dimensional material. They can help determine the strength and stability of a material under different loading conditions and are used in the design and analysis of structures.
How are principal stresses in 3D solved for direction cosines?
To solve for direction cosines in principal stresses, you need to use stress transformation equations and knowledge of the orientation of the principal stress relative to the coordinate axes. These equations involve the use of trigonometric functions and can be solved using mathematical techniques such as matrix algebra.
  • General Math
