Problem on thermodynamics first law again
In summary, for the given system of 2.0 mol CO2 at 298K confined to a cylinder of cross-section 10cm^2 at 10 atm, the gas expands adiabatically and against a constant pressure of 1 atm, the work done by the gas on the piston is -1.6KJ, the change in internal energy is -1.6KJ, the change in temperature is -28K, and the change in enthalpy is -2.1KJ. The work done on the piston is calculated by integrating the pressure over the distance moved, using the relationship between pressure and volume in an adiabatic process.
ky92
Consider a system consisting of 2.0 mol CO2 (assumed to be a perfect gas) at 298K confined to a cylinder of cross-section 10cm^2 at 10 atm. The gas is allowed to expand adiabatically and reversibly against a constant pressure of 1 atm. Calculate W, Q, ΔU, ΔH, and ΔT when the piston has moved 200cm.
(Ans: W=-1.6KJ, Q=0, ΔU=-1.6KJ, ΔT=-28, ΔH=-2.1KJ)
The thermodynamics equations
as it is adiabatic, Q=0.
ΔV=0.001m(0.2m)=2x10^-4 m3
W=-PexΔV=-101325(2x10^-4)=-20.27 J
ΔU=W+Q=-20.27 J
and i found that my W and ΔU are wrong
what's wrong with my answer?
should Pgas=Pex if the system is in equilibrium?
i just found that it isn't
but in my book :
"To achieve reversible expansion we must match Pex to P at each state: dw=-Pex dV=-P dV"
i am so confused.
please help!
Calculate the work done by the gas on the piston:
[tex]W_{\text{on piston}} = \int_0^{l_f} P*A \,dl[/tex]
The work done on the gas is just the additive inverse of the work done by the gas. The piston moves 200 cm, given. The area is a constant, so you essentially need to integrate P*dl. The process is adiabatic. What is the relation between pressure and volume for an adiabatic process? (Hint: You need to use the fact that the gas is CO2.)
You make a good point. The problem is with the question. The gas can expand adiabatically but not reversibly. In order for it to be a reversible expansion, there has to be an infinitessimal pressure difference.
In this case there is a significant pressure difference. So what happens here is that some of the energy in the gas does work on the atmosphere and some does work on the piston. The work done on the piston means the piston acquires kinetic energy (or a combination of kinetic and gravitational potential energy if it is not horizontal). So it is a dynamic rather than a quasistatic or reversible process.
In order to calculate that the work that the gas does on the atmosphere and piston, use the internal pressure of the gas. As DH says, you have to use the relationship between P and V in an adiabatic process (adiabatic condition). Express P as a function of V and then as a function of A and length.
AM
for an adiabatic process, Q=0,
ΔU=w+0=w
w=ΔU=CvΔT...
that's all i can think of
i have no idea lol
AM
thank you!
let me think about it...
ΔU=w+0=w
w=ΔU=CvΔT...
i have no idea lol
But you also know that
[tex]PV^{\gamma} = P_0V_0^{\gamma} = K[/tex]
Since PV = nRT, P = nRT/V, so
[tex]TV^{\gamma-1} = K/nR[/tex]
which is also constant, ie [itex]TV^{\gamma-1} = T_0V_0^{\gamma-1} [/itex]
So work out the change in T after an adiabatic expansion of 200 cm (you have to first determine the initial volume and the expanded volume) using this expression. (What is the [itex]\gamma[/itex] for CO2?)
AM
Related to Problem on thermodynamics first law again
1. What is the first law of thermodynamics?
The first law of thermodynamics states that energy cannot be created or destroyed, it can only be transferred or converted from one form to another.
2. How does the first law of thermodynamics apply to problems in this field?
The first law of thermodynamics is the foundation for solving problems in thermodynamics. It helps us understand how energy is conserved and transferred in various systems.
3. What is the equation associated with the first law of thermodynamics?
The equation for the first law of thermodynamics is ∆U = Q - W, where ∆U represents the change in internal energy of a system, Q represents the heat added to the system, and W represents the work done by the system.
4. Can you give an example of a problem involving the first law of thermodynamics?
An example of a problem involving the first law of thermodynamics could be calculating the change in internal energy of a gas as it expands and does work on its surroundings.
5. How does the first law of thermodynamics relate to the conservation of energy principle?
The first law of thermodynamics is essentially a restatement of the conservation of energy principle. It demonstrates that energy cannot be created or destroyed, only transferred and converted between different forms.
