Proof Error Q. Conway's Functions of One Complex Variable VI
In summary: The author does not explicitly use epsilon-delta logic in his proof, but the limit law of Thm 4.2 applies. By your notion, it seems very plausible to conclude that by using r instead of delta and any ball instead of arbitrary epsilon, the proof is right. But what about? On what ground can we conclude this? (I have no idea indeed.)
julypraise
110
I ask this question only to those who read or have this book:
If you have Baby Rudin, it would be even better.
On the page 34 of the text Conway's Functions of One Complex Variable Vol 1, it proves the Chain Rule
but it seems the proof is not valid:
It uses sequences to show the limit is satisfied to be the differentiation i. e., f'(g(z_0))g'(z_0)
We all know for the limit of function to hold, sequence should be chosen arbitrary
For example, to show limf(x) = f(p) with x to p, choose arbitary x_n such that x_n to p and then show limf(x_n)=f(p).
But in some parts of the proof
it uses constructed sequences which, obviously, not arbitrary.
For example, in Case 1 of the proof, when deriving f'(g(z_0)), it uses a sequence f(x+h_n) which is not arbitrary, obvious, though h_n is arbitrary.
And in Case 2, it separate h_n to l_n and k_n which are also not arbitrary.
So I think the proof is not really valid.
Am I the only one who think like this?
Btw can I use just Rudin's Chain Rule proof though this proof is on real-domain functions?
On the page 34 of the text, it proves the Chain Rule
My Baby Rudin has the chain rule in page 105 and uses no sequences. Can you be more specific about the edition?
DonAntonio
Pd Besides, proof with sequences is fine as we a have a little lemma that says the limit exists iff the sequential limit exists
DonAntonio
Ah of course yes, baby Rudin does not use sequences in his proof (in his latest edition).
And Rudin's proof is very clear whereas Conway's seems not valid.
As for the lemma, doesn't that lemma state that
'limit exists iff for an "arbitrary" sequence the sequential limit exists'?
Conway does not prove for arbitrary sequence but only for some sequence (at least I think so).
Ok, sorry about that: I missed the Conway part and looked into Rudin. Anyway, there's no problem as [itex]\,z_0+h_n\,[/itex] covers all the open ball
of radius r around [itex]\,z_0\,[/itex] , thus making the limit as generalized as possible.
DonAntonio
DonAntonio
Okay..
I think by your notion it seems very plausible to conclude that
[tex] \lim_{n\to\infty}\frac{f(z_{0}+h_{n})-f(z_{0})}{h_{n}}=\lim_{h\to0}\frac{f(z_{0}+h)-f(z_{0})}{h} [/tex]
though I'm not using Thm 4.2 in Baby Rudin
But what about
[tex] \lim_{n\to\infty}\frac{g(f(z_{0}+h_{n}))-g(f(z_{0}))}{f(z_{0}+h_{n})-f(z_{0})}=\lim_{k\to0}\frac{g(f(z_{0})+k)-g(f(z_{0}))}{k} [/tex]
By the way the major concern is that
it seems the author does not intend to use your notion namely epsilon-delta logic
(though you use r rather than delta and any ball instead of arbitrary epsilon)
but rather limit law namely Thm 4.2
If the proof is right, it's just that I don't get this part
Related to Proof Error Q. Conway's Functions of One Complex Variable VI
1. What is Proof Error Q. Conway's Functions of One Complex Variable VI?
Proof Error Q. Conway's Functions of One Complex Variable VI is a mathematical theorem proposed by mathematician John Horton Conway. It is the sixth in a series of proofs relating to complex variable functions and is known for its complexity and difficulty.
2. What is the significance of Proof Error Q. Conway's Functions of One Complex Variable VI?
Proof Error Q. Conway's Functions of One Complex Variable VI is significant because it provides insights into complex variable functions and the complexity of mathematical proofs. It also showcases the brilliance and creativity of John Horton Conway as a mathematician.
3. What is the main difficulty in understanding Proof Error Q. Conway's Functions of One Complex Variable VI?
The main difficulty in understanding Proof Error Q. Conway's Functions of One Complex Variable VI is its complex and abstract nature. It requires a deep understanding of complex variable functions and mathematical logic to fully comprehend.
4. How does Proof Error Q. Conway's Functions of One Complex Variable VI relate to other mathematical theorems?
Proof Error Q. Conway's Functions of One Complex Variable VI is related to other mathematical theorems in the field of complex variable functions and mathematical proofs. It builds upon previous theorems and contributes to the advancement of mathematical knowledge.
5. Are there any real-world applications of Proof Error Q. Conway's Functions of One Complex Variable VI?
Proof Error Q. Conway's Functions of One Complex Variable VI may not have direct real-world applications, but it has implications in various fields such as physics, engineering, and computer science. The concepts and techniques used in this proof can be applied in problem-solving and understanding complex systems.
  • Topology and Analysis
  • Sticky
