How Does E Relate to Q[x]/(x²+x+1) in Complex Algebra?
  • MHB
  • Thread starter mathjam0990
  • Tags
    Closed
In summary, we need to show that $E$ is closed under addition, subtraction, multiplication, and division (for non-zero elements). To prove this, we can use the fact that the elements of $\Bbb Q[x]/\langle x^2 + x + 1\rangle$ are all cosets of the form $a + bx + \langle x^2 + x + 1\rangle$. Additionally, we can use the properties of complex numbers, specifically the fact that $\omega^3 = 1$ and $\omega \neq 1$. Showing closure under subtraction and division will suffice, and the specific complex number $\omega$ is not as important as its properties.
mathjam0990
29
Let, E={a+bw : a,b in ℚ) ⊆ ℂ
w = -1/2 + [√(3)/2]*i ∈ C
Prove: E is closed under addition, subtraction, multiplication and division (by non zero elements)
Prove: E ≅ Q[x]/(x2+x+1)
Is the goal to show that for any two elements in E, all 4 operations can be performed on those two elements and the result would still be within E?
Is every element of Q[x]/(x2+x+1) in the form (a+bi)(x2+x+1) which would lead to showing why E ≅ Q[x]/(x2+x+1) ?
I'm not even sure of my statements are correct so it is hard to proceed forward. If anyone could provide a detailed answer as to how to solve this that would be most helpful. Thanks!
The elements of $\Bbb Q[x]/\langle x^2 + x + 1\rangle$ are all cosets of the form:
This is because we can write any element of $\Bbb Q[x]$ as $q(x)(x^2 + x + 1) + r(x)$, where the degree of $r$ is less than 2, and $q(x)(x^2 + x + 1) \in \langle x^2 + x + 1\rangle$.
The above might give a hint as to what the possible isomorphism between $E$ and $\Bbb Q[x]/\langle x^2 + x + 1\rangle$ might be.
It suffices to show that $E$ is closed under subtraction and division (for non-zero elements for division). This is because:
$a+b = a-(-b)$, and $ab = \dfrac{a}{\frac{1}{b}}$
The particular complex number $\omega$ is, isn't all that important, what IS important is that:
$\omega^3 = 1$, and $\omega \neq 1$.
(Why? well it turns out that $x^2 + x + 1 = \dfrac{x^3 - 1}{x-1}$).
Related to How Does E Relate to Q[x]/(x²+x+1) in Complex Algebra?
What does it mean for a set to be closed under a specific operation?
A set being closed under a specific operation means that when that operation is performed on any elements within the set, the result is still an element of the set.
What does it mean for a set to be closed under addition?
A set being closed under addition means that when any two elements within the set are added together, the result is still an element of the set.
What does it mean for a set to be closed under multiplication?
A set being closed under multiplication means that when any two elements within the set are multiplied together, the result is still an element of the set.
How do you prove that a set is closed under a specific operation?
To prove that a set is closed under a specific operation, you must show that when the operation is performed on any two elements within the set, the result is still an element of the set. This can be done through a mathematical proof or by providing specific examples.
Why is it important for a set to be closed under certain operations?
It is important for a set to be closed under certain operations because it allows for the consistent application of those operations within the set. This is especially useful in mathematical and scientific contexts, where operations must follow certain rules and laws.
  • Linear and Abstract Algebra
