PTC/Resistance for 150°C at 220V AC and 24V DC
  • Thread starter sumit_volant
  • Tags
    Ac Dc
In summary, PTC/Resistance refers to a type of thermistor with a positive temperature coefficient that increases resistance with temperature. It can be used in electrical circuits to protect against overcurrent at high temperatures. At 150°C, the resistance of the PTC/resistor will be at its highest, limiting the flow of electricity to prevent overheating. The voltage rating for PTC/Resistance depends on the specific thermistor, but generally, they can handle both AC and DC currents. PTC/Resistance thermistors can also be used for temperature control at 150°C, as their resistance changes with temperature. They offer advantages such as reliability, long lifespan, and cost-effectiveness at high temperatures and voltages.
sumit_volant
What should be value of PTC/ Resistance to raise its temperature to 150 deg Celsius for 220V AC and 24V DC..
Please explain this with required formula...
Impossible to answer. It depends on how quickly it losses heat.
Remember that a resistor wil heat up only if it can't dump the dissipated energy quickly enough.
What is the context of the question? Is it for a project or for schoolwork?
Related to PTC/Resistance for 150°C at 220V AC and 24V DC
What is PTC/Resistance for 150°C at 220V AC and 24V DC?
PTC/Resistance refers to a type of thermistor that exhibits a positive temperature coefficient, meaning that its resistance increases with increasing temperature. When used in electrical circuits, PTC/resistors can protect against overcurrent by limiting the flow of electricity at high temperatures.
How does PTC/Resistance work at 150°C?
At 150°C, the PTC/resistance thermistor's resistance will be at its highest, limiting the flow of electricity in the circuit. This helps to prevent overheating and potential damage to the circuit components. As the temperature decreases, the resistance will decrease, allowing more current to flow through the circuit.
What is the voltage rating for PTC/Resistance at 220V AC and 24V DC?
The voltage rating for PTC/Resistance depends on the specific thermistor and its intended use. However, in general, PTC/resistors have high voltage ratings and can handle both AC and DC currents, making them suitable for a variety of electrical applications.
Can PTC/Resistance be used for temperature control at 150°C?
Yes, PTC/Resistance thermistors can be used for temperature control in electronic devices and appliances. Their resistance changes with temperature, making them ideal for regulating the temperature in a circuit. At 150°C, the PTC/resistor will reach its maximum resistance, helping to maintain a stable temperature.
What are the advantages of using PTC/Resistance at 150°C and 220V AC/24V DC?
PTC/Resistance thermistors offer several advantages at high temperatures and voltages. They are reliable, have a long lifespan, and are cost-effective. They can also handle high currents and provide overcurrent protection, making them essential for many electronic devices and appliances.
  • Electrical Engineering
9K
