Pumping water upwards in a column
In summary, it takes increasing amounts of work to add height ##dy## to what is already there because there is increasing pressure to work against.
cc94
Suppose you have a tank 10 m high. The tank is currently filled 5 m high with 1000 kg of water. How much energy does it take to pump in another 1000 kg of water from the bottom to fill the column to 10 m? (Ignore friction, etc.)
E = m*g*h
I'm always confused by what we're supposed to consider in fluid mechanics problems. Is the answer simply
1000*9.8*5
since the waterline is currently at 5 m and needs to be raised another 5 m? I would think that the more water is on top of the pump, the harder it would get to pump even more water inside.
So 9.8*5*1000 would be if you are pumping 1000kg up by a height of 5m. But that isn't exactly what happens is it?
As the tank fills, it takes increasing amounts of work to add height ##dy## to what is already there because there is increasing pressure to work against. Your answer would be correct if it took the same amount of work to do that, i.e. if the force pushing down on the water you are adding did not increase as the height increases. You need to set up an integral.
Likes scottdave
Yeah I feel like I'm pumping a little water to a height of 5 m, then a little to 5.1 m, etc. My other idea was that I need to perform an integral over the height:
$$E = \int_5^{10} \rho gr\,dr$$
where ##\rho## is the weight of water per ##dr##.
Likes scottdave
I think you have the right idea almost. The work is defined as the integral of F dot dx which in this case is the integral of p dV = p A dy. p at the bottom, if the tank is open to the atmosphere at the top is p(atm) + rho g h. The cross-sectional area of the tank you can get from the initial condition that the tank contains 1000 kg of water, 5 m deep which means the tank is 0.20 m^2 cross-sectional area. So the work is the integral from 5 m to 10 m of the quantity (p atm + rho g y) A dy
Ah, so I'm also forgetting to add on atmospheric pressure. Thanks! So one final question, now if I have a shape where the area changes as a function of height, I can just substitute in A(y) and the rest stays the same, correct? I seem to recall that pressure at depth doesn't depend on the shape of water above it, only the height.
No no! @Dr Dr news seems to think the water at the bottom is not exposed to the atmosphere. I would assume it is, so atmospheric pressure cancels out.
Think about mass centres. What is the height of the mass centre of the pumped water before it is pumped? What about after?
Likes scottdave
cc94: You are right. p does not rely on the shape but A(y) gives you V(y)
@haruspex I might have either situation. Thanks!
@Dr Dr news Cool, that's just what I needed. Thanks!
Related to Pumping water upwards in a column
What is the purpose of pumping water upwards in a column?
The purpose of pumping water upwards in a column is to transport water from a lower level to a higher level. This can be used for various purposes such as supplying water to a building or irrigating crops.
What are the different methods of pumping water upwards in a column?
There are two main methods of pumping water upwards in a column: using a centrifugal pump or a positive displacement pump. Centrifugal pumps use rotational energy to move water, while positive displacement pumps use mechanical force to move water.
What factors affect the efficiency of pumping water upwards in a column?
The efficiency of pumping water upwards in a column can be affected by factors such as the type of pump used, the height and distance the water needs to be pumped, the pipe size and material, and the water flow rate.
What are the potential challenges of pumping water upwards in a column?
Some potential challenges of pumping water upwards in a column include energy consumption, maintenance costs, and the potential for pump failure. Additionally, the quality and source of the water being pumped may also impact the process.
Are there any alternative methods for pumping water upwards in a column?
Yes, there are alternative methods for pumping water upwards in a column such as using a hydraulic ram pump, a solar-powered pump, or a wind-powered pump. These methods may have lower energy consumption and maintenance costs, but they may also have limitations in terms of water flow rate and distance.
  • Classical Physics
