Qn. on general rotational mechanics
In summary, the problem involves a uniform rod of mass m and length 2l on a smooth horizontal surface, with a particle of mass m attached to one end of the rod via a string of length l. The particle is given a velocity v perpendicular to the string, and the objective is to find the tension in the string and the angular acceleration of the rod. The attempt at a solution involves using the equation ζ = Iα about the center of mass, but further progress is needed.
manogna08
a uniform rod of mass m nd length 2l lies on smooth horizontal surface. a particle of mass m is connected to a string of length l whose other end is connected to one of the ends of the rod. initially string is taut and both string and rod lie in same plane with 90 angle b/w them. if particle is given velocity v perpendicular to string, then jus after givin velocity find tension in string and angular acceleration of rod.
i tried using ζ = Iα about centre of mass but could not succeed..pleasez help...
I would think that when the velocity was imparted to the particle, since is it attached to the rod via a string (assumed inextensible, otherwise it's a spring) then the same velocity would be imparted to the end of the rod.
No, the particle is driven perpendicularly to the string.
Always start by creating some names for unknowns that might be relevant:
T = tension
α = angular acceleration of rod
a = linear acceleration of rod.
Then draw the free body diagram and try to write down some equations using the conservation laws. Post whatever you come up with.
That makes for a more interesting problem. Reading is fundamental :redface:.
Dear Student,
Thank you for your question. It seems like you are on the right track by using the equation ζ = Iα about the center of mass. However, in order to solve this problem, you will need to use a combination of rotational and translational equations.
First, let's define some variables:
m = mass of the rod and particle
l = length of the string
v = velocity of the particle
t = tension in the string
α = angular acceleration of the rod
Now, let's start by looking at the translational motion of the particle. Since the particle is moving in a circle with radius l, we can use the equation for centripetal force:
F = mv^2/l
This force is provided by the tension in the string, so we can set it equal to t:
t = mv^2/l
Next, we can look at the rotational motion of the rod. The rod will experience a torque due to the tension in the string, which will cause it to rotate. The equation for torque is τ = Iα, where I is the moment of inertia of the rod. Since the rod is rotating about its center of mass, we can use the equation for a rod rotating about its center:
I = (1/12)ml^2
Substituting this into the torque equation, we get:
t*l = (1/12)ml^2 * α
Now, we have two equations for t, so we can set them equal to each other and solve for α:
mv^2/l = (1/12)ml^2 * α
α = 12v^2/l^3
Finally, we can substitute this value of α into either of the equations for t to find the tension in the string:
t = (1/12)ml^2 * α/l
t = 12mv^2/l^2
Therefore, the tension in the string is 12 times the mass of the particle times its velocity squared divided by the length of the string squared.
I hope this helps you solve the problem. Remember to always think about both translational and rotational motion when dealing with problems involving rotating objects. Good luck!
Sincerely,
Related to Qn. on general rotational mechanics
1. What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. It is a type of motion that is characterized by the rotation of an object instead of its linear movement.
2. What is angular velocity?
Angular velocity is a measure of how fast an object is rotating around its axis. It is usually measured in radians per second or degrees per second.
3. How is torque related to rotational motion?
Torque is the measure of the force that causes an object to rotate around an axis. It is directly proportional to the angular acceleration of the object and the distance from the axis of rotation.
4. What is the difference between rotational and translational motion?
Rotational motion involves the movement of an object around an axis, while translational motion involves the movement of an object in a straight line. In rotational motion, the object's position changes with respect to an axis, whereas in translational motion, the object's position changes with respect to a fixed point.
5. How do you calculate the moment of inertia?
The moment of inertia is a measure of an object's resistance to rotational motion. It is calculated by multiplying the mass of an object by the square of its distance from the axis of rotation.
