Quantum mechanics and Minimal coupling of Dirac field
In summary, the conversation discusses the coupling of spin to electric and magnetic fields in the relativistic context. It is resolved through minimal coupling and an interaction term of the form σμνFμν. The Dirac equation implies a magnetic dipole moment but not an electric dipole moment, which violates parity conservation. The Standard Model predicts very small electric dipole moments, while other theories like supersymmetry predict larger ones. The existence of electric dipole moments would not arise from the Dirac equation but rather from internal loops of parity-violating particles.
mtak0114
47
Hi
I have a simple question:
We know from non-relativistic quantum mechanics that the spin of an electron couples only to the magnetic field, i.e. it processes around the magnetic field. How is this resolved in the relativistic context where it would seem that the spin should couple to both electric and magnetic fields? In particular how is this implied through minimal coupling which seems to be relativistically covariant where as the magnetic field isnt?
thanking you in advanced.
mtak, You can either start by giving your particle a minimal coupling or else put in an anomalous moment by hand. Either way you wind up considering an interaction term of the form σμνFμν. As you point out, this is relativistically invariant and reduces to S·B in the particle's rest frame. Of course you're also right that this is not S·B in a frame in which the particle is moving. In fact in a moving frame there will be an additional interaction with the E field that looks like S·(v x E). Well you can't quantize the spin along two different directions, so the obvious thing to do is combine these two terms and write them together as S·Beff where Beff is the necessary linear combination of B and v x E. But Beff is also just the B field back in the particle's rest frame, so we just write it that way!
Thanks Bill
that makes sense, but is that assuming that [itex]F^{\mu\nu}[/itex] is just the magnetic field [itex]{\bf B}[/itex] in the rest frame otherwise I can't see how [itex]\sigma_{\mu\nu}F^{\mu\nu}[/itex] reduces to such a term in the rest frame. Is it possible to see the converse, that QFT implies that spin does not couple in the rest frame to the electric field?
S·E would mean that the particle had an electric dipole moment, in contrast with a magnetic dipole moment. This violates parity conservation. Very small electric dipole moments are predicted by the Standard Model, and larger ones by other theories, but none has ever been observed.
So would it be correct to say that the Dirac equation includes effects due to both electric and magnetic dipole moments of the electron? but given that the former are not observed they are suppressed?
When one goes to QED however is such a suppression necessary or does the theory predict that the electric dipole moment is small?
do you have any good references which discuss this issue?
thanks again
Mark
mtak, Minimal coupling implies a magnetic dipole moment but no electric dipole moment. If electric dipole moments exist, they don't arise from the Dirac equation, rather from internal loops of parity-violating particles.
In the Standard Model the moments predicted in this way are far smaller than can be detected. Other theories like supersymmetry predict moments near the present detection threshold. For a reference, look for "Neutron electric dipole moment" and "Electron electric dipole moment" on Wikipedia. Almost all of the information you'll find will be experiment-oriented.
Related to Quantum mechanics and Minimal coupling of Dirac field
1. What is quantum mechanics and how does it relate to the minimal coupling of Dirac field?
Quantum mechanics is a branch of physics that studies the behavior of particles at a microscopic level. The minimal coupling of Dirac field is a mathematical framework used to describe the interactions between particles and electromagnetic fields in quantum mechanics. It is an important concept as it allows us to understand the behavior of fundamental particles and their interactions.
2. What is the significance of the Dirac equation in quantum mechanics?
The Dirac equation is a fundamental equation in quantum mechanics that describes the behavior of fermions, or particles with half-integer spin. It is important because it successfully combines Einstein's theory of special relativity with quantum mechanics, providing a more comprehensive understanding of the behavior of particles at high speeds.
3. How does the minimal coupling of Dirac field affect the behavior of particles?
The minimal coupling of Dirac field introduces the concept of gauge invariance, which means that the laws of physics remain the same regardless of the choice of a gauge or mathematical representation. This allows for a more unified understanding of the behavior of particles and their interactions with electromagnetic fields.
4. Can the minimal coupling of Dirac field be applied to other fields besides the electromagnetic field?
Yes, the minimal coupling of Dirac field can be applied to other fields such as the weak and strong nuclear forces. This allows for a more comprehensive understanding of the fundamental interactions between particles and fields in the universe.
5. What are some practical applications of quantum mechanics and the minimal coupling of Dirac field?
Quantum mechanics and the minimal coupling of Dirac field have numerous practical applications, including the development of new technologies such as transistors, lasers, and superconductors. They also play a crucial role in fields such as quantum computing, particle physics, and materials science.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
