Quantum mechanics and the macroscopic
In summary, the conversation discusses the concept of quantum mechanics and the measurement problem. It is noted that a particle has a wave function that describes the likelihoods of it having certain exact values when measured, but it is still unclear how the classical world emerges from this. Decoherence is mentioned as a separate phenomenon from wave function collapse, with the example of pressing a finger on a desk. The idea of examining interactions with objects as part of a larger quantum system is proposed as a way to understand measurement. It is also mentioned that observation requires interaction with the environment and that quantum phenomena are most easily observed when the object is isolated except for the measurement device.
jaydnul
558
I know the key tenants of quantum mechanics, and am not interested in the measurement problem. What we do know is that a particle has a wave function that describes the likelihoods of it having certain EXACT values when we measure it.
That's all good, but I am still confused how the classical world emerges from an underlying quantum framework. As I understand it, decoherence is different from "wave function collapse". For example, when I press my finger on my desk, are the desk atoms acting like they are being measured and taking exact values to repel my finger,? Or does my finger become part of the same quantum system and nothing has "collapsed"?
The likelihood of what having certain exact values?
One way to see how the classical world emerges from the large-scale limit of the quantum world is to understand that quantum effects are only really observable when the quantum object is isolated from interacting with the environment.
If you try to consider the system-plus-environment as a larger scale quantum system, and calculate the quantum state of the system as part of the larger whole, that state will almost never just be a pure superposition unless it is completely independent of the environment. Since everything we see/hear/touch is due to second/third hand information about particles that interacted with the objects in question (e.g., a table), it is understandable that we don't see quantum effects in everyday life.If someone were to describe the state of you-plus-desk, you can imagine that before you touched the desk, the joint state of you-plus-desk factors as the state of you, times the state of the desk. Because of your interaction, the physical systems "you" and "the desk" become entangled, and the quantum state describing "you" is a mixture of relative states depending on the information you obtained from making contact with the desk. Indeed, this loss of coherence due both to your system no longer being in a pure superposition and to this interaction is how measurement is described in "decoherence".
There's still philosophical issues to resolve, but this perspective of examining your interaction with an object as though you and the object are part of a larger quantum system can be quite illuminating as far as measurement goes.
Likes Greg Bernhardt
No. In this case nothing is observable. Observation requires an interaction with the environment. Measurement results are visible in the environment only if it has interacted with the system.
Likes AlexCaledin and vanhees71
To be technically correct (the best kind of correct), quantum phenomena are most easily observed when the quantum object is isolated from everything else, except the measurement device.
Related to Quantum mechanics and the macroscopic
1. What is the difference between quantum mechanics and the macroscopic world?
Quantum mechanics is a branch of physics that deals with the behavior of matter and energy at a very small scale, such as atoms and subatomic particles. The macroscopic world, on the other hand, refers to objects and phenomena that are visible to the naked eye and can be observed and measured without the need for microscopic tools.
2. Can quantum mechanics be applied to the macroscopic world?
Yes, quantum mechanics can be applied to the macroscopic world. While classical mechanics is sufficient to describe the behavior of large objects, quantum mechanics is necessary to understand the behavior of microscopic particles within these objects. This is because at a small scale, the laws of classical mechanics break down and the quantum nature of particles becomes important.
3. How does quantum mechanics explain macroscopic phenomena?
Quantum mechanics explains macroscopic phenomena by describing the behavior of individual particles and how they interact with each other. These interactions can lead to emergent properties at a larger scale, such as the behavior of materials and chemical reactions. Additionally, quantum mechanics also describes the probabilistic nature of particles, which can explain the unpredictability of macroscopic systems.
4. What is the role of uncertainty in quantum mechanics and the macroscopic world?
Uncertainty plays a crucial role in both quantum mechanics and the macroscopic world. In quantum mechanics, the Heisenberg uncertainty principle states that the more precisely we know the position of a particle, the less precisely we can know its momentum, and vice versa. This principle also applies to macroscopic objects, but the effects are not as noticeable due to their larger size and mass.
5. How does quantum mechanics impact our understanding of reality at a macroscopic level?
Quantum mechanics has challenged our understanding of reality at a macroscopic level by introducing concepts such as superposition and entanglement, which are not observed in classical mechanics. These concepts suggest that particles can exist in multiple states simultaneously and can influence each other's behavior even when separated by large distances. This has led to debates and philosophical discussions about the nature of reality and our perception of it.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
