Quantum states and representation freedom
In summary, an operator has a spectrum which depends on the Hilbert space on which it acts. Pure states have all the interference terms between basis states, while mixed states have lost these interference terms.
fog37
1,568
108
Hello Forum,
When a system is in a particular state, indicated by a |A>, we can use any basis of eigenvectors to represent it. Every operator that represents an observable has a set of eigenstates. I bet there are operators with only one eigenstate or no eigenstates. There are operators, like the evolution operator, that does not represent an observable.
The position operator has an infinite spectrum of eigenvalues and infinite eigenstates. When we see the wavefunction written as Psi(x), the position representation is implicit.
The energy operator (called Hamiltonian) also has an infinite spectrum and infinite eigenvectors.
The momentum operator has an infinite spectrum of eigenvalues and infinite eigenstates.
What about the angular momentum operator?
The spin operator has only two eigenvalues and two eigenstates, correct? How is it possible to represent any general state using only two eigenvalues and two eigenvectors?
So, in general, the generic state |A> can be written as a sum of any of those eigenvectors, correct?
What is the difference between a pure state and a mixed state?
Why do we call "1st quantization" the process of converting observables to operators? Does "2nd quantization" represent the conversion of the wavefunctions, i.e. states, to operators?
Thanks,
Fog37
Let me see if I can answer your questions in a concise manner. They seem to be pretty broad in scope.
1) An operator's spectrum depends on the Hilbert space on which it acts. For example, the momentum operator no longer has a continuous spectrum if you are in a bounded space (e.g. on a ring, or in the infinite square well where you are limited to operate on a closed interval). The angular momentum operator in regular 3-space has a countably infinite number of eigenvalues and eigenstates enumerated usually by ##\left|l,m\right>##.
2) The state ##\left|\psi\right>## lives in some Hilbert space. It can be deconstructed into any valid set of vectors that form a basis for the Hilbert space it lives in. However, not all states live in the same Hilbert space. A state describing the spin of a spin 1/2 particle ##\left|s_z\right>##, for example, lives in a different Hilbert space than a momentum eigenstate ##\left|p\right>##. You can't deconstruct a state in one Hilbert space in terms of states in another Hilbert space.
3) The difference between a pure and mixed state is a slightly subtle point. I'm not sure I can explain it very well in a concise manner. Basically a pure state has all the "interference" information between basis states, while a mixed state has lost these interference terms. One usually hears a pure state is a coherent mixture of states, while a mixed state is a statistical ensemble of states. In math language, a pure state is one which can be represented by a state vector ##\left|\psi\right>## while a mixed state must be expressed as a density matrix ##\rho=\sum_n p_n \left|\psi_n\right>\left<\psi_n\right|##. A pure state can also be represented by a density matrix ##\rho=\left|\psi\right>\left<\psi\right|##
In this language, a pure state is one in which ##\rho^2=\rho##, while a mixed state does not have this equality hold.
4) First quantization and second quantization is basically old language. Roughly it corresponded to 1st quantization being promoting observables to operators, and second quantization being promoting wave functions to operators (while demoting others). This language is not seen quite as much anymore.
You need to read the first two chapters of Ballentine - QM - A Modern Development:
https://www.amazon.com/dp/9810241054/?tag=pfamazon01-20
But as an overview of mixed and pure states here is the skinny.
First get out of your mind a state is an element of a vector space. It isn't - forget all you have read otherwise - its WRONG.
In general its a positive operator of unit trace, P, such that the expected outcome of an observation with observable O is E(O) = Trace (PO). A state of the form |u><u| is called pure. A convex sum of pure states is called mixed. It can be shown all states are mixed or pure. The |u> in the pure state can be mapped to a vector space - but not uniquely ie |u><u| = |cu><cu| for any complex number c.
When people speak of states from a vector space they mean pure states. For pure states its simple to see E(O) = <u|O|u>. Now, just as an example, the observable of position that gives one for position x and zero otherwise is O = |x><x|. Then of course E(O) = probability of getting x. And from that its again easy to see E(O) = <u|x><x|u> = |<u|x>|^2 which is how the squaring rule comes into it.
To understand eigenvalues and eigenvectors better you need to investigate the spectral theorem, but Ballentine gives you what you need to know about it for the purposes of QM.
Thanks
Bill
Is it wrong, or a matter of interpretation? Wrong is better, because then Many-Worlds will be immediately falsified :P
Let me correct: "When a system is in a particular state, indicated by a |A>, we can use any basis of eigenvectors of a self-adjoint operator to represent it."
Could be, but if the the eigenstates do not span the full Hilbert space, then the operator is not self-adjoint and therefore does not represent an observable.
It depends on the states you are interested in. If you want to describe spin s = 1/2 and nothing else, then the basis vectors are |s>, and everything is fine. If you want to describe spin and momentum, then the basis vectors read |p,s>, so for each p you have a two-dim subspace of the full Hilbert space.
So in the latter case you have to use
[tex]|A\rangle = \sum_p\,\sum_s\,a_{p,s}\,|p,s\rangle[/tex]
It is WRONG - not interpretationally wrong - but WRONG.
The following state 1/2 (|a><a| + |b><b|) is not an element of a vector space, nor can it be mapped to one. It is a mixed state however.
And it doesn't falcify MW - in fact MW very elegantly uses it.
What decoherence does is transform a superposition like 1/root 2 (|a> + |b>) to a mixed state like 1/2 (|a><a| + |b><b|). |a><a| and |b><b| are each interpreted as their own world and each evolve as part of that state - no collapse - no nothing.
Thanks
Bill
And it doesn't facify MW - in fact MW very elegantly uses it.
Thanks
Bill
That's just terminology. I'm asking whether you object to Many-Worlds which is based on pure state evolution as fundamental. If pure state evolution is fundamental, then one should be able to base quantum mechanics on pure states which are vectors in a Hilbert space. Also if you object to pure states as fundamental, then one should also not accept Schroedinger's equation as fundamental. Mixed states do not generally evolve following Schroedinger's equation.
Atty - I think you are forgetting that the pure state of an entangled system, when you just observe one component, is a mixed state.
This is one of the key areas detractors of MW harp on about - its dependant of that separation ie its the factoring problem.
Thanks
Bill
I disagree. One is certainly entitled to define states in QM as pure states, and those are elements of a Hilbert space. It's like saying the projection postulate is wrong because one should use POVMs, or that POVMs are wrong because one should use the projection postulate. In fact whether one defines states as operators or states as elements in a vector space, the resulting physical theory and all its predictions are the same, so it is a matter of interpretation.
You can define anything as anything you like.
But if you do that then what do you call P in the Born Rule which is Trace (PO) where P is any positive operator of unit trace?
The usual approach taken is to start with elements of a vector space as states - see that it has phase invariance - which is rather interesting. Then you consider the situation where someone randomly presents you with a state to be observed and find that can't be a state. However if you define pi as that probability if P = ∑ pi |ui><ui| then E(O) = ∑ pi <ui|O|ui> = Trace (PO). Then you extend the definition of state to include these mixed states. And as Ballentine points out they occur in solving problems as well.
You are only making things harder ignoring them.
Ballentine, and me, simply deal with it from the start.
Thanks
Bill
I think we are far from the original question
May be we are far from the original question, which we cannot answer in the forum. It's a good advice to point the poster to a good textbook, and Ballentine is among the best I know. So I strongly recommend to read the first parts of this book to get clear definitions about the fundamental objects of the theory without interpretational ballast you can add later, if you want, and in this book it's pretty well shown that most of it is in fact ballast you don't need to bother about as long as you stick to physics and don't want to enter philosophy or metaphysics. I'd consider this off topic in this forum.
Now to the point concerning states: Pure states, i.e., states which provide maximal possible information about a quantum system, are represented by rays in Hilbert space, i.e., by a normalized Hilbert-space vector modulo a phase factor. It is of utmost importance to keep this in mind, because many important things are ununderstandable, if you simply define a state to be represented by a normalized Hilbert-space vector. E.g., you could not come to the idea that also the half-integer representations of the Lie algebra of the rotation group (angular-momentum algebra) has a physical meaning, and in fact it has, because all matter around us is composed of spin-1/2 particles (quarks and leptons). Alternatively you can define pure states as being represented by projection operators, [itex]\hat{R}=|\psi \rangle \langle \psi|[/itex] with a normalized Hilbert-space vector [itex]|\psi \rangle[/itex].
In addition you need mixed states, which are represented by positive semidefinite self-adjoint operators with trace 1, the statistical operator, if you don't have complete information about a quantum system, i.e., if it is not known to be prepared in a state, where a complete compatible set of observables is determined. Of course, the pure state, represented by a projection operator is then only a special case of this general description by a statistical operator.
vanhees71 said:
... if you simply define a state to be represented by a normalized Hilbert-space vector. E.g., you could not come to the idea that also the half-integer representations of the Lie algebra of the rotation group (angular-momentum algebra) has a physical meaning ...
Why not?
It has nothing to do with the Hilbert space states but with the fact that you have to use SU(2) instead of SO(3)
Well, if you assume that the Hilbert space vector represents the states, then for half-integer spins a rotation around the 3-axis (quantization axis) immediately leads to [itex]\hat{D}_3(2 \pi) |\psi \rangle=-|\psi \rangle[/itex], and this would have to be considered as representing a different state than [itex]|\psi \rangle[/itex]. On the other hand, a rotation by [itex]360^{\circ}[/itex] should be the identity.
Now, the states are to be considered equal if the representing state vectors differ only by a non-vanishing factor, but then [itex]|\psi \rangle[/itex] and [itex]-|\psi \rangle[/itex] represent indeed the same state, and thus you admit the half-integer irreps of the rotation Lie algebra. Reconstructing the group leads to representations of SU(2) which is the covering group of SO(3), which is obviously correct, because there are particles with half-integer spin which behave exactly as predicted by this interpretation.
Another, even more drastic argument is, that you wouldn't even get a useful non-relativistic quantum theory that is compatible with the Galileo symmetry of Galileo-Newton spacetime! The fact that the rays represent states not the state vectors themselves leads to the conclusion that I do not need to realize the Galileo group by a unitary representation but a unitary ray representation is sufficient, and this admits both to use the irreps of the covering group as well as the central extensions of the group. Indeed, good old Heisenberg-Schrödinger non-relativistic quantum mechanics realizes a ray representation of a central extension of the Galileo group, with the mass as the central charge (and of course the SO(3) rotation subgroup substituted with its covering group SU(2)).
Wigner and Inönü have shown in a famous paper that the unitary irreps of the original Galilei group do not lead to a sensible quantum dynamics of non-relativistic particles.
http://link.springer.com/article/10.1007/BF02782239
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC527951/pdf/pnas00729-0073.pdf
Thanks everyone. I am carefully going through your responses.
I am reading the book "Essential Quantum Mechanics" by Gary Bowman. It is an introductory book.
The book teaches that he system state |ψ⟩ embodies information about the system’s various observables, in various representations. As an abstract entity, the state itself is representation free. It exists independently of any language, any representation we choose to write it. Dirac notation is great because it symbolizes the representation-free object |ψ⟩.
If a state is expanded in the eigenstates of some operator, and if that expansion consists of only one term, then the state is not a superposition in that representation. If there is more than one term in the expansion, the state is a superposition in that representation.
Particle in the box problem: the energy eigenstates in introductory books are expresses as functions of the space variable x. The energy values are quantized. Each possible position, each x, corresponds to an eigenstate of the position operator x. The eigenstates and eigenvalues of H are discrete for this system while those for x are continuous.
The eigenstates constituents are written as superpositions in the x representation. So which representation is the state |ψ⟩ written in? The H operator representation of the x operator representation? The answer seems to be the H representation since there is one coefficient for each H eigenstate and two coefficients for each eigenstate of x.
The point seems to be that the particular state |ψ⟩ can be expanded either using the basis eigenstates of the H operator, x position operator, spin operator, etc...(all self-adjoint). What is strange is that the spin basis has only two eigenstates (and two eigenvalues, the + hbar/2 and -hbar/2). That does not seem to give flexibility to represent any particular vector...
You are still confusing two different systems, namely the particle in a box and a spin-1/2 system. They are two different systems!
For a particle in an infinite square well potential confined to the [0,L] you may have an energy eigenstate |n>. The "energy-representation" is just this: |n>, or |En> if you like. For the x-representation you have to use the wave function ψ(x) which is a projection of |n> on the position-states <x|; so you get
[tex]\psi_n(x) = \langle x|n\rangle = \sin k_nx;\;k_n = n\pi/L;\;n=1,2,\ldots[/tex]
That means that the energy-eigenstate |n> is represented in x-rep. by the above mentioned wave function ψn(x).
There is no spin! This particle does not carry spin! You cannot / must not use any spin variable for this particle b/c there is none!
So for the particle in an arbitrary state |ψ> w/o spin you may use the following two representations.
[tex]|\psi\rangle = \sum_{n=1}^\infty \psi_n\,|n\rangle[/tex]
[tex]|\psi\rangle = \int_{-\infty}^{+\infty}dx\;|x\rangle\langle x|\psi\rangle = \int_{-\infty}^{+\infty}dx\;\psi(x)\;|x\rangle[/tex]
(Note that for an energy eigenstate the first sum collapses to one single term)
Now what you can do is to introduce an additional degree of freedom called spin. For a free particle where the Hamiltonian does not depend in the spin you find new states |n,s> where n is just the counting if the eigenvalues for the energy, and s is the new spin d.o.f.
Then you find for an arbitrary state /w spin
[tex]|\psi\rangle = \sum_s \sum_{n=1}^\infty \psi_{n,s}|n,s\rangle[/tex]
[tex]|\psi\rangle = \sum_s \int_{-\infty}^{+\infty}dx\;|x,s\rangle\langle x,s|\psi\rangle = \sum_s \int_{-\infty}^{+\infty}dx\;\psi_s(x)\;|x,s\rangle[/tex]
But now you are describing a system with spin! It's different from the first one. The spin does not replace the n or the x; it's an additional d.o.f. of your system.
(Note that the new wave function ψs(x) is a two-component spinor for spin 1/2)
I see now.
My mistake was to put spin, an observable, on the same footing as energy H, position x, or momentum p and since those operators have a complete basis of eigenstates through which represent the particular state the system is in, I thought that the state expansion was also possible and valid using the spin eigenstates...
It simply depends on the size of your Hilbert space.
Let's look at a 3-dim. eigenvalue problem (A - a)|a> = 0 with a 3*3 hermitean matrix A. Of course A has 3 lin. indep. eigenvectors |a>, and of course they span 3-space. Now Let's look at a 2-dim. eigenvalue problem (B - b)|b> = 0. Of course the 2 eigenvectors |b> do not span 3-space.
Now you could think of 3-space as 2-space plus a 3rd direction, i.e. somehow enlarging 2-space to 3-space. For B and A, i.e. |b> and |a> this could work.
But for position space and spin-space the situation is different. In the presence of spin you habe to use a tensor, something like |n,s> in the energy-rep. This is b/c position and spin are two entirely different physical quantities.
In the example with A and B this would mean you solve for the 3 eigenvalues a with 3 eigenvectors |a>. Then you do the same for b and |b>. Now the important step is NOT to consider 2-space as a subspace of 3-space but to introduce the 2*3 = 6-dim. tensor product space
[tex]|a,b\rangle = |a\rangle \otimes |b\rangle[/tex]
Look at energy and spin; the states are
[tex]|E_n,s\rangle[/tex]
That means that you do not describe the system either in terms of energy or in terms of spin (which you do for position and momentum: you use either position of momentum), but you describe a system using both energy and momentum.
Thanks for the patience Tom!
Let me "try" to summarize some points:
So the "state" that is a system is in is represented mathematically by a vector. The system is characterized by its observables which can be extracted from the state vector itself. The observables are energy, angular momentum, spin, position, linear momentum, etc. (which are linear operators in QM).
The particular state the [tex] |psi\rangle [/tex] can be expanded into a linear superposition of eigenvectors that belong to an operator (observable). The state [tex] |psi\rangle [/tex] could expanded using only the eigenstates of the position operator, only the eigenstates of the momentum operator, only the eigenstates of the energy operator, etc but that is the expansion may not possible in the case of certain other operators.
It also seems possible (see your example of energy and spin eigenvectors) to represent the particular state [tex] |psi\rangle [/tex] the system is in using eigenvectors of two operators at the same time: the same state can have a representation using only one set of eigenvectors or two set of eigenvectors, i.e. it can be represented using two observables...
But if the system does not have a specific observable (like spin, for example, in the case of the particle in the box), then it is not possible to expand the state using spin eigenstates.
At the beginning of the thread it was said that "1st quantization" means that the observables become operators in QM. Quantization means that the measurable values of the observables come up in discretely separated amounts. What is the connection between being an operator and the values of measurable observables being quantized?
Is quantization implied when an observable becomes an operator?
fog37 said:
But if the system does not have a specific observable ... then it is not possible to expand the state using spin eigenstates.
yes, exactly
It's a bit more complicated than that; but yes, quantization essentially means to translate obervables as functions on phase space into linear, self-adjoint operators acting on a Hilbert space.
fog37 said:
At Quantization means that the measurable values of the observables come up in discretely separated amounts.
No, that's not true. After having constructed an operators A representing an observable one can solve the eigenvalue problem; then math tells you whether the spectrum is discrete or continuous, but this is not clear from the beginning. In many cases the spectrum of an observable contains both a discrete and a continuous part, i.e. the bound states of the Hydrogen atom have discrete energies whereas the scattering states have a continuous spectrum.
As I said, it's the result of the eigenvalue problem on a specific Hilbert space. Look at the momentum operator -i∂x: it has a continuous spectrum when evaluated on the real line (which is quite messy b/c the plane waves are non-normalizable "generalized eigenfunctions"), but it has a discrete spectrum when evaluated for the infinite square well. The difference between these two cases is clearly not the mathematical expression for the operator (in both cases it's -i∂x) but also its domain (real line or finite inteval) and the boundary conditions (in the latter case following from the physical condition that the wave functions must have zeros at the boundaries).
Likes 1 person
ok,
so "quantization" seems to be a little improper name since we don't always have the discreteness involved. For example, a free particle has continuous energy for both the energy and momentum spectra...
Moving forward, in QFT, 2nd quantization means that the wavefunctions becomes operators too (but the observables return to be variables, either scalar or vectorial?)...
The concept of "particle" is QM is very very different from the classical concept (particle is something that is localized and occupies a finite volume). In QM a particle is simply a fundamental excitation of the quantum field.
Each particle and antiparticle (photon, electron, neutron, etc.) have their associated field. When we measure these field we interaction with the detector reduces to a local event, hence the word "particle".
Art Hobson wrote this article: There are no particles, there are only fields
http://arxiv.org/abs/1204.4616I am not sure about the difference between the word "particle" in QM and "particle" in QFT
Historically, second quantization is indeed making the wave function an operator. Since the wave function is already a quantum object, this is second quantization. But nowadays we understand it differently.
In both first and second quantization, we are looking for a quantum theory that gives the appropriate classical theory in some limit. One way to do this is to take the classical canonical theory, and turn the Poisson brackets into quantum commutators. If the classical theory involves classical particles, then this procedure is first quantization, if the classical theory involves classical fields the procedure is second quantization.
Another way of thinking about second quantization, especially in condensed matter is that it is a way of writing the non-relativistic Schroedinger equation for many-identical particles so that a field theory is obtained. However, there is no new physics, just a new language for the Schroedinger equation of many identical particles.
Take a phonon in condensed matter. The underlying particles are the atoms and electrons governed by the Schroedinger equation. A phonon is a "quasi-particle". Unlike the underlying atoms and electrons, one can create more phonons by exciting the medium. The phonon is a particle in QFT. So QFT can be thought of (roughly) as a quantum theory where particles can be created and destroyed.
A "particle" is a phenomenon described by a quantum state carrying quantum numbers like spin, isospin, ... which is sufficiently localized both in position- and momentum-space; that means it is reasonable to say "I detected an electron with spin +1/2 at this location and with that momentum"
In situations where this is not appropriate I would hesitate to call the quantum state a "particle"; so in a double slit experiment the interfering photon is not really a "particle" in that sense; and in a Bell-type experiment the entangled photon pair is not a "pair of particles".
That book has explained it correctly.
That is indeed exactly what's going on.
To hammer it home you may find the following interesting - see post 137:
https://www.physicsforums.com/showthr...=763139&page=8
Thanks
Bill
The easiest way to understand so called 'second quantitisation' - which isn't really what's going on - is to realize there is a fundamental issue with basic QM and relativity, and why relativistic theories along the same lines such as the Dirac equation runs into issues. They can be overcome, but its easier to eliminate the problem from the start.
Time is treated as a parameter, position as an observable. But relativity says they should be treated on the same footing. What Quantum Field Theory (QFT - which is really what second quantisation is) does it treat them on the same footing so that position is also a parameter ie we have a field.
You may find Weinberg's comments on it interesting:
http://arxiv.org/pdf/hep-th/9702027v1.pdf
Thanks
Bill
Perhaps we should start simple and from the beginning again. There seems to be a lot of confusion in this thread concerning abstract Hilbert-space vectors and representations.
You start from a vector in the abstract separable Hilbert space. The reason that this sentence makes sense is that there is only one separable Hilbert space. On the other hand, there are a lot of different concrete realizations of this Hilbert space used in quantum mechanics. If you start with wave mechanics, the vectors are realized as (equivalence classes of) square-integrable complex functions. If you learn about matrix mechanics you use square summable sequences. All these representations are equivalent to each other, i.e., you can always find a unitary transformation from one representation onto the other.
The most clear picture is provided by starting from the abstract Hilbert space. Then you define essentially self-adjoint operators on them, building the observable algebra. As an example let's take a single massive particle with spin within non-relativistic quantum theory (say, an electron). In non-relativistic physics the spin operators commute with the position operators. The spin operators do not commute but obey the su(2)-algebra commutation relations
[tex][\hat{s}_j,\hat{s}_k]=\mathrm{i} \hbar \epsilon_{jkl} \hat{s}_l.[/tex]
From this you can derive, that you have common eigenvectors of [itex]\hat{\vec{s}}^2[/itex] with eigenvalues [itex]\hbar^2 s(s+1)[/itex] and of [itex]\hat{\sigma}_3[/itex] with eigenvalues [itex]\sigma_z \in \{-s,-s+1,\ldots,s-1,s \}[/itex] (for given [itex]s[/itex]; we assume that the particle is elementary and thus is represented by an irreducible representation of the Galileo group; that means that there are only eigenstates with fixed [itex]s \in \{0,1/2,1,/ldots \}[/itex] involved.
A complete set of observables thus are [itex]\vec{x}[/itex], [itex]\hat{\vec{s}}^2[/itex], and [itex]\hat{\sigma}_3[/itex] and corresponding generalized eigenvectors (which are not true Hilbert-space vectors, because they are not normalizable to 1; formally they live in a space of distributions). They are normalized in the generalized sense via
[tex]\langle \vec{x},s,\sigma_z|\vec{x}',s',\sigma_z' \rangle=\delta^{(3)}(\vec{x}-\vec{x}') \delta_{ss'} \delta_{\sigma_z \sigma_z'}.[/tex]
Thus the wave function in position-spin representation is given by
[tex]\psi_{s,\sigma_z}(\vec{x})=\langle \vec{x},s,\sigma_z|\psi \rangle.[/tex]
The completeness relation (for fixed [itex]s[/itex]) is
[tex]\sum_{\sigma_z=-s}^s \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} |\vec{x},s,\sigma_z \rangle \langle \vec{x},s,\sigma_z |=\hat{1}[/tex] and thus
[tex]|\psi \rangle=\sum_{\sigma_z=-s}^s \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} |\vec{x},s,\sigma_z \rangle \psi_{s,\sigma_z}(\vec{x}).[/tex]
I hope this clarifies a bit the issue how to switch between the abstract Hilbert-space vector and a given representation with respect to a complete set of compatible observables.
Thanks for the excellent summary, but I can't see the
vanhees71 said:
... confusion in this thread concerning abstract Hilbert-space vectors and representations.
All what I see is that it was not clear that spin is a new observable which requires a tensor product of Hilbert spaces.
Hi Tom,
This is Fog37. Hope all is well.
You helped me a while back in 2014 when I asked some quantum mechanics questions on this forum. I got back to that thread to review things and I still have some doubts. Would you be available for some questions?
Thanks!
fog37 said:
Hi Tom,
Thanks!
I am afraid the said user is no longer with us. Ask your questions here and some other member can help you.
Likes vanhees71
Thanks dextercioby.
Let me summarize what I think I know so you don't have to repeat yourself:
  • Every observable (position, momentum, angular momentum, energy, spin, etc. did I forget any?) is represented by a Hermitian linear operator in quantum mechanics. The operator's spectrum can be continuous, discrete or hybrid depending on the type of spatial domain over which the system exists and the forces involved.
A generic abstract state of a system is given by ##| \Psi>## is a state vector that can be expressed as a weighted superposition of eigenstates of a certain operator. That means that we can represent ##| \Psi>## in many different ways according to the operator and its associated basis. But the basis of eigenvectors of each different operator is associated to different linear vector spaces... So in which vector Hilbert space does ##| \Psi>## live in? Is there a different ##| \Psi>## for each different vector space associated to each different operator? For instance, the spin operator has a basis of only two eigenvectors (2-dimensional) while the energy basis generally contains an infinity (discrete or continuous) of eigenvectors. It does not seem possible to represent the same state ##| \Psi>## that is superposition of many energy eigenstates using only two spin eigenstates.
b) What about a "total" vector state ##| \Psi>## that contains information about all the observables?
c) In the particle in the box example, spin is not considered. Only the energy and position observables are discussed. Why? The particle trapped in the box could be an electron which has a nonzero spin.
d) Based on what said above, how does the tensor product between two (or more?) linear vector spaces fit it? Is it used when the total wavefunction is expressed in terms of eigenvectors that include multiple observables? In this thread, it was said that spin is an additional degree of freedom. Aren't position, momentum, energy, etc. also degrees of freedom?
Let me stop here. Thank you for any help.
  • #31
  • #32
Let's go through step by step. The rough picture is correct, but there are important subtleties missing.
fog37 said:
Thanks dextercioby.
Hermitecity is not sufficient, it must be an essentially self-adjoint operator, i.e., the operator must be defined on a dense subspace of Hilbert space. In general this subspace is a proper subspace of the Hilbert space, and it's co-domain must be also in this subspace, i.e., if ##|\psi \rangle## is in the domain of the operator ##\hat{A}##, representing an observable, also ##\hat{A} |\psi \rangle## should be in this subspace.
A pure state is not represented by ##|\Psi \rangle## itself but the entire ray defined by this Hilbert-space vector. That's important since it enables us to describe, e.g., particles with half-integer spin, and the surrounding matter around us is made up of such particles (quarks and leptons).
The most general description, valid for both pure and mixed states, is the statistical operator. A state is pure if and only if the representing statistical operator is a projection operator, ##\hat{\rho}=|\Psi \rangle \langle \Psi |## with a normalized Hilbert-space vector ##|\Psi \rangle##.
Is don't know what you mean by that. The state vector contains of course probabilistic information about all possible observables through Born's rule, i.e., if ##\hat{A}## represents the observable ##A## and if ##|a,\beta \rangle## denotes all (generalized) eigenvectors of ##\hat{A}## with eigenvalue ##a## (which is a possible value when this observable is measured), then the probability (distribution) to measure this value ##a## if the system is prepared in a state represented by ##|\Psi \rangle##
$$P(a)=\sum_{\beta} |\langle a,\beta|\Psi \rangle|^2.$$
Of course ##\beta## can also be in a continuous set, and then the sum over ##\beta## becomes and integral (or you can have the case that ##\beta## takes both discrete and continuous values, in which case you have both a sum and an integral).
There's nothing that hinders you to consider also spin. In the non-relativistic case, it's just another label on the eigenstates, i.e., for an electron ##\sigma_z=\pm 1/2## in addition to energy (there's no momentum observable in this case, BTW!).
Yes, if you have a composite system the Hilbert space of this system is the tensor product of the Hilbert spaces of the composites. Formally, if you have a single particle with spin ##s##, a generalized basis is the momentum-spin basis, ##|\vec{p},\sigma_z \rangle##, where ##\vec{p} \in \mathbb{R}^3## and ##\sigma_z \in \{-s,-s+1,\ldots,s-1,s \}##. Formally you can build up this basis as a tensor product
$$|\vec{p},\sigma_z \rangle=|p_x \rangle \otimes |p_y \rangle \otimes |p_x \rangle \otimes \sigma_z \rangle.$$
Likes bhobba
Related to Quantum states and representation freedom
1. What is a quantum state?
A quantum state is a mathematical description of the physical properties of a quantum system. It represents the probability of finding a particle in a particular state and can be described using a wave function or a state vector.
2. What is representation freedom in quantum mechanics?
Representation freedom in quantum mechanics refers to the fact that different mathematical representations can be used to describe the same quantum state. This means that there is no unique way to describe a quantum system and different representations may be more useful for different purposes.
3. How does the concept of superposition relate to quantum states?
The concept of superposition is a fundamental aspect of quantum states. It refers to the ability of a quantum system to exist in multiple states simultaneously. This is described by the wave function, which contains all the possible states that the system can be in.
4. Can quantum states be observed or measured?
Quantum states cannot be directly observed or measured. Instead, measurements are made on the system, which can provide information about the state. The act of measurement causes the system to collapse into one of the possible states, as described by the wave function.
5. How do quantum states relate to quantum entanglement?
Quantum states are closely related to quantum entanglement, which is a phenomenon where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other(s). This means that the quantum state of one particle cannot be described independently of the other(s), even if they are separated by large distances.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
