Question about GR and Quantum gravity
In summary, the need for quantum gravity arises because general relativity and quantum mechanics cannot be fully reconciled. While quantum field theory can be formulated in curved spacetime, it cannot be a fundamental theory and must be an approximation to a deeper theory. This is due to the fact that QM allows for multiple possible configurations while GR only allows for one. This becomes problematic when quantum effects could create different possible spacetime geometries and stress-energy tensors. The theory of quantum gravity proposes the existence of a massless, spin-2 quantum field known as the graviton, which in its classical limit is equivalent to GR. However, this theory is not renormalizable and is expected to be incomplete. While gravity is not a significant force at the
Ostrados
65
First I don't have extensive knowledge about gravity beyond General Relativity, so please forgive my ignorance about this subject. I have confusion about the relation between GR and QM and I just want a general picture so that I can connect the dots.
My questions:
1- Why do we need quantum gravity? and why GR gravity does not work with QM?
2- In GR gravity is just curvature in spacetime it is not a force. So why do we need to quantize gravity if it is not a field? and why the graviton is proposed? doesn't that contradict with GR?
3- The microscopic world is dominated by forces much stronger that gravity, and gravity is already very week at such small scale, so why do we care about gravity at the quantum level?
Thanks,
Quantum field theory can be formulated in curved spacetime, so in that sense GR and QM can "work" together. The problem is that such a theory cannot be fundamental; it must be an approximation to some deeper theory. The reason, heuristically, is that, according to QM, if a system has different possible configurations, there should be an amplitude for it to be in each of them. But GR doesn't work like that: it doesn't say there are amplitudes for different possible spacetime geometries, stress-energy tensors, etc. It says there is only one spacetime geometry, stress-energy tensor, etc.--i.e., only one configuration for the system. (This is true of any classical, i.e., non-quantum, theory.)
So any situation in which quantum effects could create different possible spacetime geometries, stress-energy tensors, etc., with amplitudes for each, cannot be properly modeled using GR. But such situations should occur whenever any significant quantity of mass or energy is subjected to quantum superposition. A typical such situation is determining how a mass moves by some quantum process, such as the decay of a radioactive atom.
Saying that gravity is "not a force" in the sense of Newtonian physics (but instead is spacetime geometry) is not the same as saying that gravity is not an "interaction" in the sense of quantum field theory. The latter statement could very well be true; and in fact, the simplest approach to quantum gravity is to assume it is true, and to model gravity at the fundamental level using a massless, spin-2 quantum field, for which the "graviton" is the corresponding particle excitation. It was shown in the 1960s and 1970s that the classical limit of such a theory is in fact GR itself--i.e., that the classical limit of the field equation satisfied by such a quantum field is in fact the Einstein Field Equation of GR. So such a theory of quantum gravity is perfectly consistent with GR.
The problem with this theory of quantum gravity is that it is not renormalizable, which basically means that it is not expected to be a complete theory by itself. There should be extra terms in the theory describing extra interactions which only occur at extremely high energies, and which we have no way of probing experimentally. In fact we have no way of even probing the quantum nature of the spin-2 field itself experimentally, since such quantum aspects are not expected to become significant until we reach length scales on the order of the Planck length, some 20 orders of magnitude smaller than the smallest length scales we can currently probe.
We don't in any practical sense; as I noted above, the quantum aspects of gravity are much too small for us to probe now or in the foreseeable future. We care because we know, for the reasons given above, that our current theories are not complete, and we would like to try to find more complete theories.
Likes Ostrados, timmdeeg and Dale
Just a follow-up question I have to build off of this topic:
Would a quantum gravity theory still predict that mass bends spacetime? I'm not sure if mass curving spacetime is something that is already excepted as true without doubt, or simply accepted because general relativity predicts it and is our current best theory of gravity, but does quantum gravity require mass to curve spacetime?
It would say that this is a low energy approximation to the underlying theory.
Could you explain what you mean by "low energy approximation"? I'm unfamiliar with that term.
It means roughly that, if the average energy per particle is low enough, the physics that is present in the underlying theory (quantum gravity in this case) happens too rarely to observe, and the effective physics is limited to that in the approximate theory (GR in this case).
Likes Comeback City
@PeterDonis Thanks for the detailed answer.
Regarding superposition: let's say we have a particle in superposition in multiple places, then it's gravity effect will also be in superposition too? For example in double slit experiment will we get something analogues to interference pattern in the gravity field?
Ostrados said:
lets say we have a particle in superposition in multiple places, then it's gravity effect will also be in superposition too?
That is what our understanding of QM would tell us, yes. But GR cannot model this; that's the issue.
Related to Question about GR and Quantum gravity
1. What is the difference between General Relativity and Quantum Gravity?
General Relativity (GR) is a theory of gravity that describes the behavior of large-scale objects, such as planets and galaxies. It explains gravity as the curvature of space and time caused by the presence of massive objects. Quantum Gravity, on the other hand, is a theoretical framework that aims to unify GR with the principles of quantum mechanics, which govern the behavior of particles on a very small scale. It seeks to provide a more complete understanding of gravity at the quantum level.
2. Why is it important to have a theory of Quantum Gravity?
A theory of Quantum Gravity is important because it would help us understand the fundamental nature of the universe. It would provide a more complete description of gravity, which is one of the four fundamental forces of nature. It could also help us reconcile inconsistencies between GR and quantum mechanics, and potentially lead to new breakthroughs in physics and technology.
3. Can Quantum Gravity be tested experimentally?
Currently, there is no experimental evidence for the existence of Quantum Gravity. The energies and scales at which quantum effects become important in the context of gravity are far beyond what we can currently probe in experiments. However, some theories of Quantum Gravity make predictions that may be testable in the future, such as the existence of extra dimensions or the effects of quantum gravity on the behavior of black holes.
4. Is there a consensus on the most promising theory of Quantum Gravity?
No, there is currently no consensus on the most promising theory of Quantum Gravity. There are several competing theories, such as String Theory, Loop Quantum Gravity, and Causal Dynamical Triangulations, each with its own strengths and weaknesses. Further research and experimentation are needed to determine which theory, if any, is the most accurate description of Quantum Gravity.
5. How does Quantum Gravity relate to the search for a theory of everything?
Quantum Gravity is often considered a key component in the search for a theory of everything, also known as a theory of everything (TOE). A TOE would be a single, unified theory that explains all physical phenomena in the universe, including the behavior of all particles and the fundamental forces. Quantum Gravity is seen as an important piece in this puzzle because it seeks to unify GR with the principles of quantum mechanics, which is necessary for a complete understanding of the universe.
