Question including ideal gas law, change in energy/work.
In summary: You need to find the work done by the system, convert it to joules, and subtract it from the energy stored in the system (dW).
doctordiddy
54
This question would be impossible to solve without the diagram, which I can't post so instead i'll just tell you what I have so far.
gas springs are commonly used on trunk lids of cars. They are a closed system consisting of a pressure tube and piston rod with piston, as well as nitrogen gas as an energy source.
if the nitrogen gas is compressed from initial volume Vi and initial pressure Pi to final volume Vf, as the trunk lid is slowly closed find the formula for how much energy is stored in the gas spring?
pV=nRT
W=pV
what I have so far is
dE(energy) = dW = -p(dV) Why is this -pdV?
pV=nRT
T= constant ---> pV = constant = PiVi Not sure what this means either
E=-∫(Vf-Vi)pdV = -PiVi∫(Vf-Vi)(dV/V) = -PiVi[ln(Vf)-ln(Vi)]
again i know this is to integrate dE into just E, but I don't really understand this process, especially E=-∫(Vf-Vi)pdV = -PiVi∫(Vf-Vi)(dV/V)
therefore E=-PiVi*ln(Vf/Vi)
So yes I'm not looking for the answer since i have it I am just confused about the work to get to the answer
PS ∫(Vf-Vi) just means ∫(Vf over Vi)
You need to inform us if the piston was thermally insulated, whether the piston was maintained at a constant temperature, or whatever.
There is no mention of that in the question, though it does say the gas spring is a closed system, wouldn't that mean constant temperature of the piston once equilibrium is reached?
And my main problem is just what exactly the formulas I am using mean, not so much how to solve it
doctordiddy said:
1.
because pdV is the work done BY the system (the gas). So that work must result in a REDUCTION in energy of the remaining gas.
And btw that equation tells me this is an adiabatic process, i.e. a thermally insulated one. Why? Look at the first law with Q = 0. Q=0 defines an adiabatic (also called isentropic) process.
That being the case, what formula involving p and V did you learn that applies to such a process? Hint: T is NOT constant.
pV=nRT
It would mean the product pV idoes not change as pressure and volume change. Like, if the volume is squished to half the original volume, the pressure doubles. Etc. But that applies to an isothermal (constant temperature process. That is not your case here.
[/quote]
That formula makes no sense. Where did you dig that up?
That formula makes no sense. Where did you dig that up?[/QUOTE]
I'm very confused because this is what was the work that was provided to solve the equation and I copied it down hoping to understand it better but it isn't really helping to just read ovver it.
I'm very confused because this is what was the work that was provided to solve the equation and I copied it down hoping to understand it better but it isn't really helping to just read ovver it.[/QUOTE]
OK I see the problem. You meant for Vf and Vi to be the limits of integration. I would suggest using "go advanced" and write ∫ViVfpdV instead. (The smart ones on this forum use itex or whatever but personally I'm too lazy to pick it up.)
Unfortunately, this is an adiabatic process (dQ = 0), so you can't write pV = constant, which you did in going from your first to your second integral above.
I ask again: what relation between p and V might you have learned exists for an adiabatic process?
I ask again: what relation between p and V might you have learned exists for an adiabatic process?[/QUOTE]
I know of the equation
PiVi^γ=PfVf^y
However I do not think there is anything wrong with the solution because this is the solution given, I am just confused as to how the solution was obtained.
In addition, this question was before we learned adiabatic processes so I am a bit skeptical about needing to account for it.
PiVi^γ=PfVf^y
Then you must be right, and the gas is kept at a constant temperature in going from Vi to Vf. But I noticed you gave dE = -dW at the beginning, and that equation holds only for an adiabatic process if E is the internal energy U of the system. Possibly your prof/text used E = U + Q where U is internal energy channge and Q is heat added, so that would explain things.
The thing is, you never defined if the gas/spring system was thermally insulated or whether it was kept at a constant temperature in going from Vi to Vf. That has nothing to do with "settling" of the system's temperature. It has to do whether heat Q is added/subtracted, or not.
So it looks to me like you're in good shape - anything still puzzling you?
Yeah I guess this question is nearly impossible to figure out for you without the diagram unfortunately. I guess I will just go find a TA to figure it out. Thanks a lot for the help.
Related to Question including ideal gas law, change in energy/work.
1.
What is the ideal gas law and how does it relate to changes in energy/work?
The ideal gas law is a mathematical equation that describes the relationship between pressure, volume, temperature, and number of moles of an ideal gas. It can be written as PV = nRT, where P is pressure, V is volume, n is the number of moles, R is the gas constant, and T is temperature. This law can be used to calculate the change in energy or work of an ideal gas in a closed system.
2.
How does the ideal gas law differ from real gases?
The ideal gas law is based on a theoretical model of a gas that assumes no intermolecular forces and that the gas molecules occupy no volume. In reality, real gases do have intermolecular forces and occupy some volume, so the ideal gas law may not accurately predict their behavior. However, it is still a useful approximation for many gases under certain conditions.
3.
How is energy related to changes in pressure, volume, and temperature of an ideal gas?
According to the ideal gas law, energy can be changed in a gas by changing its pressure, volume, or temperature. For example, if a gas is compressed at a constant temperature, its pressure will increase and work will be done on the gas, increasing its energy. Similarly, if a gas expands at a constant temperature, its pressure will decrease and work will be done by the gas, decreasing its energy.
4.
Can the ideal gas law be used to calculate changes in energy or work for non-ideal gases?
No, the ideal gas law is only applicable to ideal gases. For non-ideal gases, other equations or models must be used to calculate changes in energy or work. These may include the van der Waals equation or the compressibility factor.
5.
How is the ideal gas law used in practical applications?
The ideal gas law is used in many practical applications, such as in the design of engines and compressors, in the production of industrial gases, and in the study of atmospheric phenomena. It can also be used to predict the behavior of gases in various conditions, such as in chemical reactions or in different states of matter.
  • Classical Physics
  • Classical Physics
  • Mechanical Engineering
