Question On Linear Independence
I think you are saying that you were going over something about linear independence in class.In summary, the professor explained that if two vectors y1 and y2 are linearly independent, then the ratio of y2/y1 is not a constant. He also mentioned that this can be turned around for linearly dependent vectors, where there exists a lambda such that y1 = lambda * y2. The concept of linear independence is defined as a set of vectors being independent from each other in a vector space.
Cantspel
We were going over linear independents in class and my professor said that if y1 and y2 are linearly independent then the ratio of y2/y1 is not a constant, but he never explained why it is not a constant.
Hi,
You can turn it around: if y1 and y2 are linearly dependent, there is a ##\lambda## such that ##y_1 = \lambda y_2##
Given that you posted this in a differential equations subforum, I take it that ##y_1## and ##y_2## belong to some vector space of functions that contains the solutions of a certain linear differential equation?
Provided this is indeed your setting, what (by definition) does it mean when ##y_{1,2}## are independent? What does it mean when they are dependent?
Minor point -- you were going over linear independence in class. Linear independence is an attribute of a set of vectors of other elements that belong to a vector space.
Related to Question On Linear Independence
1. What is linear independence?
Linear independence refers to a set of vectors in a vector space that cannot be expressed as a linear combination of other vectors in the same space. In other words, no vector in the set can be written as a linear combination of the other vectors in the set.
2. How is linear independence determined?
To determine if a set of vectors is linearly independent, we can use the following criteria: if the only solution to the equation c1v1 + c2v2 + ... + cnvn = 0 is c1 = c2 = ... = cn = 0, then the set is linearly independent.
3. What is the significance of linear independence?
Linear independence is important in linear algebra because it allows us to solve systems of equations and perform other calculations more efficiently. It also helps us to understand the properties of vector spaces and their dimensions.
4. Can a set of linearly dependent vectors be reduced to a set of linearly independent vectors?
Yes, it is possible to reduce a set of linearly dependent vectors to a set of linearly independent vectors by performing operations such as row reduction and finding a basis for the vector space. This process is known as finding a linearly independent spanning set.
5. How is linear independence related to linear transformations?
Linear independence is closely related to linear transformations because it helps us to understand the effects of these transformations on vector spaces. In particular, linear independence plays a key role in determining whether a linear transformation is one-to-one or onto (or both), and in finding the inverse of a linear transformation.
  • Linear and Abstract Algebra
