Question on plate size in plate tectonics
  • Thread starter Althistorybuff
  • Tags
    Plate
In summary, the Earth's plates are large due to the formation process of continents and the behavior of the mantle. The number and size of plates can vary depending on the planet's properties, such as viscosity of the mantle. The source article mentions that smaller plates can form in active rift valleys from larger ones, indicating that the number and size of plates is constantly changing in a chaotic system.
Althistorybuff
Question from an amateur:
The Earth's plates seem pretty large compared to the planet. This example has about 20 to 30 with about 6 seemingly making up the majority of the Earth's surface.
Is there a reason why they are so large?
I'm writing a novel in which a planet, instead of having 20 to 30 plates, may have 100 small ones. That way, I don't have a handful of large oceans or large continents but a huge number of smaller Greenland to Hawaii sized island chains with dozens of large Mediterranean-sized seas.
Is there some aspect of planetary tectonics that would explain why there would be more numerous but smaller plates?
Thanks.
Consider: https://earth-planets-space.springeropen.com/articles/10.1186/s40623-016-0400-x
I would look at it in this somewhat non-scientific analogy: If you take a system of objects, like the solar system:
Few really large objects - Sun sized and larger
More medium sized objects - hot Jupiter size
Lots of much smaller objects. Earth and moon sizes
Huge number of tiny objects: thousands of asteroids.
During planetary formation, the tiny objects rained down onto the larger ones; they were subsumed.
With plates on Earth powered by continental drift, tiny ones have been subsumed by subduction in the past, leaving larger ones still intact. New smaller plates form in active rift valleys from old larger ones.
The article mentions something like this, but more from an obervational point of view.
Likes RogueOne, davenn and Nik_2213
jim mcnamara said:
nice article, Jim, thanks :)
have to agree with that. There's no real reason why there should be a set number of a specific size.
In a chaotic system that is forever changing over the millions of years, the size, shape and number is also going to be constantly changingDave
Thanks all.
jim mcnamara said:
@davenn - posts deleted.
Thanks Jim, I have deleted my one :)
That seems to be an open question. As the continents are formed by convections inside the mantle, they should be much smaller because the size of a convection cell is limited by the deep of the fluid - in this case 3000 km. In addition the resulting shape and distribution of the continents should be more symmetric (e.g. like a honeycomb structure). For some reason the mantle doesn't behave like a homogeneous fluid. A possible reason could be an increasing viscosity in deeper layers of the mantle. In that case I would expect smaller continents on a world with a lower viscosite of the mantle compared to Earth. A side effect could be increased volcanism.
Related to Question on plate size in plate tectonics
1. What is the significance of plate size in plate tectonics?
Plate size is a crucial factor in plate tectonics as it determines the amount of energy and force that is generated within the Earth's crust. Larger plates have more mass and therefore exert more force when they collide or slide against each other, leading to more significant tectonic activity and potential for earthquakes and volcanic eruptions.
2. How are plate sizes determined in plate tectonics?
Plate sizes are determined by the boundaries between tectonic plates, which are defined by the movement and interaction of the Earth's tectonic plates. The size of a plate is determined by the area of landmass it covers and the location of its boundaries.
3. What is the average size of a tectonic plate?
The average size of a tectonic plate is approximately 50-100 million square kilometers. However, the size of plates can vary greatly, with some being as small as a few thousand square kilometers, and others being as large as 200 million square kilometers.
4. Can plate sizes change over time?
Yes, plate sizes can change over time due to the constant movement and interaction of tectonic plates. Plates can break apart, merge, or change direction, resulting in changes in their size and shape. This process is known as plate tectonics and has been occurring for millions of years.
5. How does plate size affect the Earth's surface?
The size of tectonic plates has a significant impact on the Earth's surface. The movement and interaction of plates can create various landforms, such as mountains, valleys, and ocean trenches. It also plays a role in the distribution of continents and oceans, which can impact climate and the evolution of life on Earth.
  • Earth Sciences
  • Earth Sciences
  • General Discussion
  • Earth Sciences
9K
17K
9K
