Regularly Parametrized Curves
  • MHB
  • Thread starter Poirot1
  • Tags
    Curves
In summary: We know that the dot product of two vectors is equal to the product of their magnitudes multiplied by the cosine of the angle between them. In this case, the angle between y(s) and y'(s) is always 90 degrees, so the cosine of the angle is always equal to 0. Therefore, we can write the dot product of y(s) and y'(s) as:$y(s).y'(s) = y(s)*y'(s)*cos(90) = y(s)*y'(s)*0 = 0$Since we know that $y(s).y'(s)=s$, this means that $s=0$. Therefore, we can
Poirot1
245
consider y mapping R to R^3 and such that y(0)=(1,0,0) and y'(0)=(0,1,0).
suppose $y''(s)=y(s) * y'(s)$. where * is the cross product
1) show y is a unit speed curve.
2)show that $\frac{d^2}{ds^2}(|y(s)|)=2$
3) deduce $y(s).y'(s)=s$ and further $|y(s)|=(s^2+1)^{0.5}$
Hello! Thank you for your interesting post. Let's take a look at the given information and see what we can deduce.
1) To show that y is a unit speed curve, we need to prove that the magnitude of its velocity vector is always equal to 1. We know that y(0)=(1,0,0) and y'(0)=(0,1,0). Using the given equation y''(s)=y(s)*y'(s), we can find the velocity vector y'(s) at any point s by taking the cross product of y(s) and y''(s). Since the cross product of two vectors gives a vector perpendicular to both, we can deduce that y'(s) is always perpendicular to y(s). This means that y'(s) and y(s) are always at a right angle, and therefore, the magnitude of y'(s) is always equal to 1. This proves that y is a unit speed curve.
2) To show that the second derivative of the magnitude of y(s) is equal to 2, we can use the chain rule and the given equation y''(s)=y(s)*y'(s). We know that the magnitude of a cross product is equal to the product of the magnitudes of the two vectors multiplied by the sine of the angle between them. In this case, the angle between y(s) and y'(s) is always 90 degrees, so the sine of the angle is always equal to 1. Therefore, we can write the second derivative of the magnitude of y(s) as:
$\frac{d^2}{ds^2}(|y(s)|)= \frac{d}{ds}(y(s)*y'(s)) = y'(s)*y'(s) = 1*1 = 1$
Since we know that y(s) is a unit speed curve, we can substitute 1 for the magnitude of y'(s), giving us:
$\frac{d^2}{ds^2}(|y(s)|)= 1*1 = 1$
This means that the second derivative of the magnitude of y(s) is always equal to 1, which proves that $\frac{d^2}{ds^2}(|y(s)|)=2$.
3) Finally, we can deduce that $y(s).y'(s)=s$ by using the chain rule and the given equation y''
Related to Regularly Parametrized Curves
1. What is a regularly parametrized curve?
A regularly parametrized curve is a curve that can be described by a continuous function, called a parametrization. This function maps a parameter, typically denoted by t, to a point on the curve. The resulting curve is smooth and has a well-defined direction at each point.
2. How is a regularly parametrized curve different from a non-regularly parametrized curve?
A regularly parametrized curve is different from a non-regularly parametrized curve in that it is smooth and has a well-defined direction at each point. Non-regularly parametrized curves may have abrupt changes in direction or may have points where the derivative of the parametrization function does not exist.
3. What is the significance of having a regularly parametrized curve?
Regularly parametrized curves have several important applications in mathematics, physics, and engineering. They are used to describe the motion of objects in space, such as the trajectory of a projectile or the path of a planet. They are also used in differential geometry to study the properties of curves and surfaces. In physics, regularly parametrized curves are used to describe the path of a particle in motion.
4. How is a regularly parametrized curve represented mathematically?
A regularly parametrized curve is represented mathematically as a vector-valued function, where the input is the parameter t and the output is a point on the curve. For example, a 2D regularly parametrized curve can be represented as r(t) = (x(t), y(t)), where x(t) and y(t) are the x and y coordinates of the point on the curve at parameter t.
5. What are some common parametrization functions used for regularly parametrized curves?
Some common parametrization functions used for regularly parametrized curves include linear functions, trigonometric functions, and exponential functions. These functions can be combined and manipulated to create more complex curves, such as circles, spirals, and ellipses. In some cases, the parametrization function may also depend on other variables, such as time or velocity, to describe the motion of the curve.
  • Topology and Analysis
