Related rates & unknown factors
In summary, the problem involves finding the rate at which the radius is increasing while blowing up a balloon at a rate of 300 cubic inches per minute. This can be solved using the Chain Rule, by differentiating the formula for volume with respect to the radius. The final answer is approximately 2.65 inches per minute.
Michael Santos
29
Your blowing up a balloon at a rate of 300 cubic inches per minute. When the balloon's radius is 3 inches, how fast is the radius increasing?
I know the answer to this question. It is approximately 2.65 inches per minute, what my question is; the area is 113.0973355 when the radius equals 3. when 300 and 2.65 are divided by 60 sec you find that the area is increasing at 5 inches per sec and the radius is increasing at 0.04416666667 per sec, tho when you input 3.04416666667 in the formula for a sphere the area comes out to be 118.1663682 just over 5 inches, what is this unknown factor that participates in the growth of the area or is this a physics problem, this continues to happen if you divide even further. It is the same thing for when you increase the radius of 3 by 2.65 and find the area which says it would be 300 cubic inches wider as the area increases at 300 cubic inches per minute but it is not.
You're making a mistake in your assumptions. Specifically, you're assuming that just because the volume changes constantly with time, so too must the radius. You can see by a very quick application of the chain rule that this isn't true, but you can also think about it physically -- If you want to add 300 cubic inches of volume to a balloon, that will make the radius change a lot more when the balloon is empty than it will if the balloon is a mile wide.
Yes i see
Likes Dewgale
I assume this is a calculus class (correct me if I'm wrong). So the principle here is the Chain Rule.
##\frac {dV} {dt} = \frac {dV}{dr} \frac {dr} {dt} ##
You obtain the expression for ##\frac {dV}{dr}## by differentiating the formula for volume of a sphere with respect to the radius.
The rate you were given is ##\frac {dV}{dt}##. And you're being asked for ##\frac {dr}{dt}##, so you can easily solve for that by plugging in the other information.
Related to Related rates & unknown factors
1. What are related rates in mathematics?
Related rates refer to the rate at which two or more quantities change in relation to each other. This is often used to solve problems involving motion or change over time.
2. How do you determine unknown factors in related rate problems?
To determine unknown factors in related rate problems, you must first identify the variables and their rates of change. Then, you can use the given information and appropriate equations to solve for the unknown factor.
3. What is the role of calculus in solving related rate problems?
Calculus is used in solving related rate problems because it provides a way to find the rate of change of a function at any given point. This allows us to find the relationship between different rates and solve for unknown factors.
4. Can related rates be applied to real-world situations?
Yes, related rates can be applied to real-world situations such as calculating the speed of a moving object or the rate at which a population is growing. It is a useful tool for understanding and predicting changes in various systems.
5. What are some common mistakes to avoid when solving related rate problems?
Some common mistakes to avoid when solving related rate problems include not accurately identifying the variables and their rates of change, using incorrect equations, and not paying attention to units of measurement. It is important to carefully analyze the problem and double check your work to avoid errors.
