- #36
- 21,558
- 12,734
That is not a constructive response. A constroctive response would be pointing out which part you do not understand.the farmer said:Still don't understand what you meant
Those are the two methods available. That they give the same answer suggests you've done it right.the farmer said:Am I on the right truck or there is other method that I can use to solve my a)?
As it stands, that formula is not correct. Remember PEMDAS. The formula above parses as: ##\gamma = mc^2 + \frac{\text{KE}}{mc^2}##. That is obviously dimensionally incorrect. Gamma is a pure number. You've given a formula for an energy plus a pure number.the farmer said:I don't understand the way you responded. My question was:
Since the question is asking me to find a length, L = Lo/ y. Y is my gamma factor. In the question I am given kinetic energy. So to find my gamma I need to make it the subject of formula. Y= mc^2 + KE / mc^2
I had trouble making sense of this. Oh, I think I get it now. You've done a simplification behind the scenes.the farmer said:Y = 1 + (50×10^6) × ( 1.6×10^-19) J ÷ 9.11×10^-31 kg ( 3× 10^8m/s)^2
Seems sound.the farmer said:Y = 98. 57287474
L = 10m/98.5787474
=0.10 in to 2 decimal place.
Yes inceed. Since you are given that ##\frac{v}{c} = .999949## then ##\sqrt{1-\frac{v^2}{c^2}} = \sqrt{1-.999949^2}##.the farmer said:I tried to calculate my length again but this time I am using the given speed and used this formula l= Lo/Y ,Y is gamma factor then L = 10m × (1 -(0.999949)^2)^1/2 ,c^2/c^2 canceled each other then my final answer is 0.10 m in 2 decimal place. I concluded that both these two methods are giving me same answer. Am I on the right truck or there is other method that I can use to solve my a)?
Wow thanks,so meaning I answered the question correctly right?jbriggs444 said:As it stands, that formula is not correct. Remember PEMDAS. The formula above parses as: ##\gamma = mc^2 + \frac{\text{KE}}{mc^2}##. That is obviously dimensionally incorrect. Gamma is a pure number. You've given a formula for an energy plus a pure number.
Presumably you meant to write ##\gamma = \frac{mc^2 + \text{KE}}{mc^2}## That formula would be correct. Total energy is rest energy plus kinetic energy. Gamma is total energy divided by rest energy.
Let us look at your math.
You set out to evaluate: ##\gamma = \frac{mc^2 + \text{KE}}{mc^2}##
You actually evaluated ##\gamma = \frac{mc^2}{mc^2} + \frac{\text{KE}}{mc^2} = 1 + \frac{\text{KE}}{mc^2}##
You convert the ##50 \text{ MeV}## to Joules for the numerator of the right hand side.
You multiply the rest mass of the electron, ##9.11\times 10^{-31}\text{ kg}## by ##c^2## to get Joules for the denominator.
That is a valid calculation for gamma.
Seems sound.
So you have computed ##\gamma## based on the energy ratio that you were given (50 MeV from the problem and ##9.11 \times 10^{-31} \text{ kg}## from other references). Personally I would have looked up the rest mass of the electron in Mev (about 0.5 MeV) and skipped both conversions to joules. Then you can practically read off gamma without even using a calculator.
As you say, this time you used velocity as the starting point instead of kinetic energy.
Yes, both methods are giving you the same answer. Which is what @Orodruin was trying to point out. The person who set the question purposely chose the kinetic energy (50 MeV) and the velocity (0.999949 c) so that the two figures were consistent.
One of the skills needed for success in the course is the ability to judge the validity of your answers for yourself. Focus on sense-making rather than answer-making.the farmer said:Wow thanks,so meaning I answered the question correctly right?
But,I need that to discuss with my colleagues, I want to ensure that is correctMister T said:One of the skills needed for success in the course is the ability to judge the validity of your answers for yourself. Focus on sense-making rather than answer-making.
I know. That's my point. You need to learn how to do that. Otherwise you have to take it on someone else's authority and you never learn. You won't achieve success that way.the farmer said:But,I need that to discuss with my colleagues, I want to ensure that is correct
You a right? It correct or i need to redo it again?Mister T said:I know. That's my point. You need to learn how to do that. Otherwise you have to take it on someone else's authority and you never learn. You won't achieve success that way.
In classical physics, we have four quantities associated with a particle: mass, kinetic energy, magnitude of momemtum and speed. If you know any two of those, you can calculate the others.the farmer said:Still don't understand what you meant
