- #36
Dale
Mentor
- 35,412
- 13,689
That is fine to ask here, but I will just point out that the answers you are complaining about were not answers to that question. You had asked a different question and the examples you are complaining about now were perfectly good responses to that question then. Even if they are not good responses to this new question.DanMP said:I'm asking for are the clocks actually and successfully used in experiments of interest for relativity,
In principle you could use all of the clocks you complained about in successful relativity experiments, despite the fact that it has not actually been done to date. In other words, actual and successful are separate criteria.
There are many clocks that have actually been used for relativity experiments that do not have these parts.DanMP said:I meant clocks as manmade devices, not some abstractions. (Such a clock, in my opinion, must have at least the following parts: one for generating events, one for counting the events and one for displaying the results.)
In relativity experiments interferometers are used as clocks that measure a difference in light travel time between two paths. They produce events, don’t count them (usually the difference is less than one event), but do display the result.
A.A. Michelson and E.W. Morley, "On the Relative Motion of the Earth and the Luminiferous Ether", Am. J. Sci. (3rd series) 34 333–345 (1887).
R.J. Kennedy and E.M. Thorndike, "Experimental Establishment of the Relativity of Time", Phys. Rev. 42 400–418 (1932).
And dozens of less famous other experiments.
Lasers, masers, and optical resonators could qualify as clocks having your three parts, with the laser producing events, the Fabry Perot etalon sort of “counting”, and then the interference sort of “displaying”. As long as you aren’t too picky about counting and displaying. Although I think it is a stretch. E.g., see:
A. Brillet and J.L. Hall, "Improved Laser Test of the Isotropy of Space", Phys. Rev. Lett. 42 549–552 (1979)
Mossbauer absorbers really don’t fit your definition. The clocks are nuclear transitions. The “events” are random and the detectors don’t determine the number of events but rather only if the nuclear clocks frequencies match or not.
Isaak et al., Phys. Bull. 21 (1970), pg 255.
Turner and Hill, Phys. Rev. 134 (1964), B252.
Hay et al., Phys. Rev. Lett. 4 (1960), pg 165.
Kuendig, Phys. Rev. 129 no. 6 (1963), pg 2371.
Sherwin, "Some Recent Experimental Tests of the 'Clock Paradox'", Phys. Rev. 129 no. 1 (1960), pg 17.
Muons are also often used as clocks. They are unstable fundamental particles, so they do not have any parts at all. Furthermore, they decay by the weak interaction, so they are not based on EM and the weak interaction bosons are quite massive.
Bailey et al., "Measurements of relativistic time dilation for positive and negative muons in a circular orbit," Nature 268 (July 28, 1977) pg 301.
Bailey et al., Nuclear Physics B 150 pg 1–79 (1979).
Rossi and Hoag, Physical Review 57, pg 461 (1940).
Rossi and Hall, Physical Review 59, pg 223 (1941).
Rasetti, Physical Review 60, pg 198 (1941).
Redei, Phys. Rev. 162 no. 5 (1967), pg 1299.
