Result of Euclidean division
In summary: Thinking)In summary, we discussed the application of euclidean division with $x^6-1$ and $x^2- \alpha^{a+1} (\alpha+1)x+ \alpha^{2a+3}, a \geq 0$, over the field $\mathbb{F}_7$. We also explored the use of primitive 6-th root of unity $\alpha$ and its properties in simplifying the division. Additionally, we identified the values of $\alpha$ that satisfy the criteria for a primitive 6-th root of unity in $\mathbb{F}_7$. Finally, we discussed the significance of $\alpha^3$ as a primitive 2-nd root of unity in the calculations
evinda
MHB
3,836
Hello! (Wave)
I have applied a lot of times the euclidean division of $x^6-1$ with $x^2- \alpha^{a+1} (\alpha+1)x+ \alpha^{2a+3}, a \geq 0$, $\alpha$ a primitive $6$-th root of unity. But I don't get the right result... (Sweating)
We are over $\mathbb{F}_7$.
I got that $x^6-1=(x^2- \alpha^{a+1}(\alpha+1) x+ \alpha^{2a+3}) (x^4+ \alpha^{a+1} (\alpha+1) x^3+ \alpha^{2a+2}[(\alpha+1)^2- \alpha] x^2+ \alpha^{3a+3}(\alpha+1)[\alpha^2+1]x+ \alpha^{4a}[\alpha^4(\alpha+1)^2(\alpha^2+1)-[(\alpha+1)^2- \alpha]])+ \alpha^{5a}(\alpha+1)[\alpha^2+ \alpha+1+\alpha^5]x-2 \alpha^4-2\alpha^3-2 \alpha^8-\alpha^7+\alpha^4+\alpha^3-1$.
But the rest should be $0$. Have I done something wrong?
Mathematics news on Phys.org
evinda said:
Hello! (Wave)
Hey evinda! (Smile)Did you take into account that for instance $\alpha^3 = -1$?
And that $\alpha^5 = \overline \alpha$?
And that $\alpha + \overline \alpha = 1$? (Wondering)
Oh, and how about writing it as:
$$\frac{x^6-1}{x^2- \alpha^{a+1} (\alpha+1)x+ \alpha^{2a+3}}
= \frac{(x-1)(x+1)(x^2-x+1)(x^2+x+1)}{(x-\alpha^{a+1})(x-\alpha^{a+2})}
= \frac{(x-1)(x+1)(x-\alpha)(x-\overline\alpha)(x-\alpha^2)(x-\overline\alpha^2)}{(x-\alpha^{a+1})(x-\alpha^{a+2})}
$$Now we can see that for instance with $a=1$, it simplifies to:
$$(x-1)(x-\alpha)(x-\overline\alpha)(x-\overline\alpha^2) = (x-1)(x^2-x+1)(x-\overline\alpha^2)
Btw, that is not in $\mathbb F_7$ is it? (Thinking)
How do we get these relations?
Why does it hold that $(x-1)(x+1)(x^2-x+1)(x^2+x+1)=(x-1)(x+1)(x-\alpha)(x-\overline\alpha)(x-\alpha^2)(x-\overline\alpha^2) $ ?
Why isn't this in $\mathbb{F}_7$ ? (Thinking)
Since $\alpha$ is a primitive root of unity, isn't it:
$$\alpha = e^{\pm i \pi / 3}$$
(Wondering)
Then it would follow that $\alpha^3 = e^{i\pi} = -1$.
Those roots of unity correspond to points on the unit circle in $\mathbb C$:
Why does it hold that $(x-1)(x+1)(x^2-x+1)(x^2+x+1)=(x-1)(x+1)(x-\alpha)(x-\overline\alpha)(x-\alpha^2)(x-\overline\alpha^2) $?
The equation $x^6 - 1 = 0$ has 6 solutions in $\mathbb C$, which are so called roots of unity.
The solutions are $1, \alpha, \alpha^2, ..., \alpha^5$.
It means that we can write:
$$x^6 - 1 = (x-1)(x-\alpha)(x-\alpha^2)...(x-\alpha^5)$$
We can verify that the stated equality holds. (Thinking)
Isn't $\mathbb F_7 = \{0,1,2,3,4,5,6\}$?
The primitive root of unity $\alpha$ is not in there... (Worried)
(Wondering)
Those roots of unity correspond to points on the unit circle in $\mathbb C$:The equation $x^6 - 1 = 0$ has 6 solutions in $\mathbb C$, which are so called roots of unity.
I thought that we get from the fact that $\alpha$ is a $6$-th root of unity that $\alpha^6=1$ and $\alpha^i \neq \alpha^j, i \neq j, 1 \leq i, j \leq 6$. (Sweating)
If we take a field of the form $\mathbb{F}_{7^m}$ for some $m \in \mathbb{N}$ ?
Hold on! (Wait)
Actually, $\mathbb{F}_{7}$ does have a primitive 6-th root of unity.
We have either $\alpha=3$ or $\alpha=4$.
Note that the numbers $3^k$ are all distinct for $1 \le k \le 6$, and $3^6=1$. (Emo)
Btw, we still get $\alpha^3 = -1$, since it's a primitive 2-nd root of unity. (Nerd)
How did you deduce this?
I see...
Why is it a 2-nd root of unity?
I see...
By checking all numbers in $\mathbb F_7$, to see if they satisfied the criterion for a primitive root of unity. (Sweating)
Because $(\alpha^3)^2 = 1$, so $x=\alpha^3$ satisfies $x^2=1$.
We also know that $\alpha^3 \ne 1$, which follows from the fact that $\alpha$ is a primitive 6-th root of unity.
And finally, because the only numbers that satisfy $x^2=1$ are $x=\pm 1$. (Whew)
Ah I see... Do we use this at my initial calculations or at the calulations that you did?
evinda said:
Ah I see... Do we use this at my initial calculations or at the calculations that you did?
Well... if we divide $x^6-1$ by $x-\alpha^{a+1}$ first, we get:
\frac{x^6-1}{x-\alpha^{a+1}}
= x^5 + \alpha^{a+1}x^4 + \alpha^{2(a+1)}x^3 + \alpha^{3(a+1)}x^2 + \alpha^{4(a+1)}x + \alpha^{5(a+1)}
+\frac{\alpha^{6(a+1)} - 1}{x-\alpha^{a+1}}
Note that the remainder term $\alpha^{6(a+1)} - 1=0$, because $\alpha$ is a 6-th root of unity.
That leaves dividing what we found by $x-\alpha^{a+2}$... (Thinking)
Alternatively, if I redo your calculation, I get the same terms for $x^4$, $x^3$, and $x^2$, but a different term for $x$.
Mine is $\alpha^{a+1}(\alpha^{2a+2} - 2\alpha^{a+2}) x = \alpha^{2a+3}(\alpha^a - 2)x$.
Oh, and my final remainder term has a constant of $1+\alpha+\alpha^2+\alpha^3+\alpha^4+\alpha^5$, which is indeed $0$. It suggests that my calculation is correct.
Perhaps there is a mistake in your calculation. (Worried)
So we divide $x^5 + \alpha^{a+1}x^4 + \alpha^{2(a+1)}x^3 + \alpha^{3(a+1)}x^2 + \alpha^{4(a+1)}x + \alpha^{5(a+1)}$ by $x- \alpha^{a+2}$ , right?I got that $$ x^5 + \alpha^{a+1}x^4 + \alpha^{2(a+1)}x^3 + \alpha^{3(a+1)}x^2 + \alpha^{4(a+1)}x + \alpha^{5(a+1)}=(x- \alpha^{a+2}) (x^4+ \alpha^{a+1}(\alpha+1) x^3+ \alpha^{2a+2}[\alpha^2+ \alpha-1] x^2+ \alpha^{3a+3}[1+ \alpha [\alpha^2+ \alpha-1]]x+ \alpha^{4a+4}[1+ \alpha(1+ \alpha(\alpha^2+\alpha-1) )])+ \alpha^{5a+5}[\alpha [1+ \alpha (1+ \alpha(\alpha^2+ \alpha+1))]]$$
Is it again wrong? (Sweating)
Ok, I will retry them... (Nerd)
Again I get the same result as before... (Sweating)
Also why does it hold that $1+\alpha+\alpha^2+\alpha^3+\alpha^4+\alpha^5$ is equal to $0$ ? (Thinking)
So what did you find $\frac{x^6-1}{x^2- \alpha^{a+1} (\alpha+1) x+ \alpha^{2a+3}}$ to be equal to?
Isn't it a geometric series? What would its sum be? (Wondering)
Let $B=\alpha^{a+1}(\alpha+1)$ and $C=\alpha^{2a+3}$.
Then:
\begin{aligned}x^6-1 &= \Big(x^2-Bx+C\Big)\
\Big(x^4 + Bx^3 + (B^2-C)x^2 + B(B^2-2C)x + (B^4 - 3B^2C + C^2)\Big) \\
&+ \Big[B(B^4-3B^2C+C^2) - BC(B^2-2C)\Big]x - C(B^4-3B^2C+C^2) - 1
\end{aligned}
I veried that $- C(B^4-3B^2C+C^2) - 1 = 0$ by filling in $\alpha$ and making use of its properties.
I also filled in $\alpha$ in $Bx^3$ and in $(B^2-C)x^2$ and found the same thing you did.
Related to Result of Euclidean division
1. What is the result of Euclidean division?
The result of Euclidean division is the quotient and remainder obtained when a given dividend is divided by a divisor. It is also known as integer division or division with remainder.
2. How is Euclidean division different from regular division?
Euclidean division differs from regular division in that it always produces an integer quotient and remainder, while regular division can produce decimal values. Euclidean division is also used for finding the greatest common divisor between two numbers.
3. What is the purpose of using Euclidean division?
The main purpose of using Euclidean division is to find the quotient and remainder of a division operation. It is also used in algorithms for finding the greatest common divisor and for converting between different units of measurement.
4. What is the algorithm for performing Euclidean division?
The algorithm for performing Euclidean division involves repeatedly subtracting the divisor from the dividend until the remainder is less than the divisor. The number of times the divisor is subtracted is the quotient, and the final remainder is the remainder of the division operation.
5. Can Euclidean division be used for all types of numbers?
Euclidean division can be used for all types of numbers, including positive and negative integers, decimals, and fractions. However, it is most commonly used for whole numbers and integers.
  • General Math
  • General Math
