Riemann Hypothesis equivalence
In summary, the Riemann Hypothesis is equivalent to the assertion that the sum of the zeta functions is 2Z. If the RH is false, then the conjugate zeros are off the critical line and symmetric to it (they come in four's in that case and not just two). How would that affect the two sums if that happened?
zetafunction
391
let be the function [tex] \sum_{\rho} (\rho )^{-1} =Z[/tex]
and let be the sum [tex] S= \sum_{\gamma}\frac{1}{1/4+ \gamma ^{2}} [/tex]
here 'gamma' runs over the imaginary part of the Riemann Zeros
then is the Riemann Hypothesis equivalent to the assertion that [tex] S=2Z [/tex] ??
Yes. What happens if the RH is false? That means the conjugate zeros are off the critical line and symmetric to it (they come in four's in that case and not just two). How would that affect the two sums if that happened?
In other words it is mirrored. If goes up in the uper half, it will be opposite in the bottom half.
The real line is the mirror line.
i got the desired result in
however it seems to good to be true http://vixra.org/pdf/1110.0041v1.pdf
manage to prove that [tex] \sum_{t}(1/4+t ^{2})^{-1}=2+ \gamma -log(4\pi) [/tex]
here 't' runs over the imaginary part of the Riemann Zeros, i have used the Riemann-Weil formula to prove it.
zetafunction
What do you mean by Riemann Zeros?
Non trivial, trivial, or both??
lostcauses10x ..
i mean the imaginary part of the zeros ON THE CRITICAL STRIP [tex] 0<Re(s)<1[/tex]
zetafunction
thanks.
Had to give this a bit of thought. Yet when examining the couture relations of the zeta function and the non trivial zeros a relation of the reflection property of the real line also shows up with the relation of the real line with limits due to the intersect of the non trivial zeros. A perpendicular intersect.
It seems to me this relation is directly proportional to the real line, and if the hypothesis is true, this relation is directly proportional and directly related tto the reflection and imaginary parts and perpendicular intersects at the real line.
Were as this limited reflective property appears around the non trivial zeros, were it starts on the real part contour is a bit of a problem to find: even if the hypothesis is true.
Just an observation, yet interesting result of what was said here. It does put the function in a bit better perspective to me. Of course this thought process is just beginning for me.
Related to Riemann Hypothesis equivalence
1. What is the Riemann Hypothesis equivalence?
The Riemann Hypothesis equivalence is a conjecture in mathematics that states that the Riemann zeta function, which is an important function in number theory, is equivalent to the distribution of prime numbers.
2. What is the significance of the Riemann Hypothesis equivalence?
If proven to be true, the Riemann Hypothesis equivalence would provide a deeper understanding of the distribution of prime numbers and could potentially lead to new mathematical discoveries and applications.
3. Has the Riemann Hypothesis equivalence been proven?
No, the Riemann Hypothesis equivalence has not been proven. It remains one of the most famous and challenging unsolved problems in mathematics.
4. What are some consequences if the Riemann Hypothesis equivalence is false?
If the Riemann Hypothesis equivalence is false, it would mean that the distribution of prime numbers is not related to the Riemann zeta function, and our current understanding of prime numbers would need to be reevaluated.
5. How is the Riemann Hypothesis equivalence related to the Riemann zeta function?
The Riemann Hypothesis equivalence states that the Riemann zeta function can be expressed in terms of the distribution of prime numbers. It is essentially a statement about the relationship between these two important mathematical concepts.
  • General Math
  • Linear and Abstract Algebra
  • General Math
  • Topology and Analysis
