Rotational energy, find minimum, for nitrogen molecule
In summary: E_rot = (L*(L+1)*h-bar^2)/(2*M*r_0^2), I get 0.0258943 eV. But I submitted this and it was wrong.It's frustrating, 'cause the problem w/ answer in the book is for the easiest thing ever, the hydrogen molecule. When I do this problem for hydrogen using this new method, I totally get the correct answer of 0.00739841 eV. So switching between hydrogen and nitrogen, something is changing that I'm not accounting for.I'm beat. The more I figure out for this problem, the less I feel I know.Tips
Yroyathon
42
i made a mistake, and fixed it, but I'm still wrong. I totally thought I had this one. Little help here.
What is the minimum (nonzero) rotational energy of the <sup>14</sup>N_2 molecule?
E_rot = L * (L + 1) * E_0 * (m_e) / (4*M)
M = (M_1 + M_2) / (M_1 * M_2)
first off, is E_0 = 13.6 eV? that's what it was in the similar problem on molecular hydrogen. If it isn't...well, how do I calculate it for this situation?
Ok, so the minimal non-zero E has to be when L=1, since L=0 yields E=0. With L=1, we get
E_rot = (E_0 * m_e) / (2 * M)
From the far-above equation for reduced mass M, I plug in 7 times the mass of a proton for each of the nitrogen nuclei, and get M = (7*m_p*7*m_p)/(7*m_p + 7*m_p). After simplifying, M = (7*m_p)/2
Plugging in E_0, m_e = .00091*10^(-27) kg, m_p = 1.672*10^(-27) kg, and M into the above equation for E_rot, I get
E_rot = (13.6 * .00091*10^(-27) * 2) / (2 * 7 * 1.672*10^(-27)), and after simplifying
E_rot = 0.00105742 eV. But this is wrong.
I thought I was pretty careful. Can anyone see a calculation error, or a mistake in my understanding of how to use these equations with this particular molecular nitrogen situation?
Many thanks.
,Yroyathon
I am about to log off, and don't have time to read through your post in detail. But, wouldn't the minimum (nonzero) rotational energy occur when the angular momentum is h-bar?
I'm not sure how to respond to your response, since the approach of using angular momentum isn't quite comprehensible to me. in the book, they say A is angular momentum, and it's defined in this context as A^2 = L * (L + 1) * h-bar^2. Well, I guess this is the numerator of my new equation for E_rot, shown below. I just didn't think L could be anything but non-negative integers, so I don't know how A would be h-bar as you suggest. Can you see a way to do this, or explain what I don't get about angular momentum here?
back to my own approach, so I think I was wrong on a few points, my chemistry is super rough.
I switched equations first off for E_rot, using E_rot = (L * (L + 1) * h-bar^2)/(2*M*r_0^2).
I re-calculated r_0, using r_0=2*a_0, where a_0 is just like hydrogen but swapping out the term m_e for 7*m_e, since nitrogen has 7 electrons instead of the single electron for hydrogen. so now a_0 = 7.57143*10^(-12) m, making r_0 = 1.51429*10^(-11) m. r_0 is what I'll actually use below.
Also the reduced mass figure, M. I was forgetting to include the neutrons, in addition to the protons. So it ultimately doubles the result, M = 7 * m_p.
Plugging in these new values for M and r_0 into the new E_rot equation, (and also using L=1 since it has to be an integer and L=0 causes E_rot to be 0), I get
E_rot = (L * (L+1) * h-bar^2) / (2*M*r_0^2), I get 0.0258943 eV. But I submitted this and it was wrong.
Tips, suggestions? Thanks much.
,Yroyathon
Ah, you're right. Yes, A2 is what you say above, and L=1 would give the lowest nonzero value.
... back to my own approach, so I think I was wrong on a few points, my chemistry is super rough.
This might be where things are going awry. r0 should be something you would look up for nitrogen -- does your textbook have a table of atomic radii? I really don't think it's possible to calculate r0 using another molecule and substituting masses.
Another useful relation is the kinetic energy of a rotating object:
E = ½ A2 / I
For I, use the moment of inertia of two point masses (the nitrogen nuclei) separated by a distance ... is it r0 or 2r0 (not sure how you're defining it)?
well, you were right about the atomic radius. What I calculated before from modifying hydrogen's radius, and what I found on the internet about the atomic radius for nitrogen, were totally different.
so using the new correct atomic radius for nitrogen (56 pm), I get 0.00100192 eV, which is also wrong. There's not much else to fiddle with in this problem, except for the M. It's possible that the reduced mass calculation is different for nitrogen, but I don't see how.
Maybe finding the minimum is found when L is not equal to 1.
Or maybe I can't use this new formula for E_rot, and instead have to use the formula you stated in terms of I and A. But it was my impression that the two forms were equivalent.
I've only got one chance left to get the right answer, so I'm going to stall on this problem and work on some others. Thanks for your help. I feel pretty close to getting this problem, but proximity to the answer doesn't count for much unfortunately.
Good luck. It's definitely the case that L=1 here -- if it could be anything, then the energy could be arbitrarily close to 0 and there would be no answer to this problem.
The trick is in getting the moment of inertia I. It can be tricky to work in terms of reduced mass, so I recommend using the simple two-point-masses picture to figure out I.
Also, is r0 the atomic radius, or is it the distance between nitrogen nuclei? Those two things differ by a factor of 2, so be careful there.
I think you're making this way more complicated than it has to be, Yroyathon. I believe we have the same book, because most of the problems you ask questions on, I have been assigned as well. In this case, I used your original
E_rot = [l(l+1)*E_0*m_e]/(4*M)
The value of E_0 is 13.6 eV, as the book states on the top of the page, saying it is just a simplification of their expanded notation. The use of l=1 is also correct, and the value for m_e is 9.10938*10^-31 kg.
Thus, the only unknown was the M, which you initially forgot to solve including both protons and neutrons. If you include both, meaning 7 protons and 7 neutrons, your M becomes
M=2.34328e-26 kg.
Plug this value into the initial equation and solve, looks like it should be
E_rot = 2.643462e-4 eV.
Hope this helps, I know your posts have helped me this semester so far.
icysoul, you give me a tiny bit of confidence I might finish this problem.
but for one thing.
when calculating the reduced mass M, M = (M_1 * M_2) / (M_1 + M_2). Using M_1=M_2=7*m_p, I get M=7*m_p=1.1704*10^(-26) kg. this is different than what you wrote, M=2.34328*10^(-26) kg.
this would lead to a slightly different result, E_rot = 0.000529231.
do you agree? or am I misunderstanding something about reduced mass calculations?
Thanks.
,Yroyathon
You are completely correct about M, all I did was add up 7p and 7n apparently, haha. I blame 2 AM. But yes, you are right, and after recalculating I also got
E_rot = 5.28692e-4 eV,
with the values of m_p and m_n being the ever-so-slightly different values given in the book. Either way, your answer should be within the correct answer tolerance, good catch.
Related to Rotational energy, find minimum, for nitrogen molecule
1. What is rotational energy?
Rotational energy is the form of energy associated with the movement of an object around an axis. In the case of a nitrogen molecule, it refers to the energy associated with the rotation of the molecule around its center of mass.
2. How is rotational energy calculated for a nitrogen molecule?
The rotational energy of a nitrogen molecule can be calculated using the formula E = (h^2/8π^2I)(J(J+1)), where h is Planck's constant, π is pi, I is the moment of inertia of the molecule, and J is the quantum number representing the rotational state.
3. What is the minimum rotational energy for a nitrogen molecule?
The minimum rotational energy for a nitrogen molecule, also known as the ground state energy, is when J=0. This results in the formula E = 0, meaning there is no rotational energy for the molecule in its lowest energy state.
4. How does rotational energy affect the properties of a nitrogen molecule?
The rotational energy of a nitrogen molecule affects its ability to absorb and emit electromagnetic radiation, which can then impact its chemical reactivity and other properties. It also contributes to the overall energy and stability of the molecule.
5. How is rotational energy related to temperature?
The rotational energy of a molecule is directly proportional to its temperature. As the temperature increases, the molecules have more kinetic energy, leading to a higher rotational energy. This is why rotational energy is included in the calculation of a molecule's heat capacity.
