Rubber Band Spinning in midair
In summary: It is also the case that, if you have a massless compressed spring in equilibrium, the force on each end of the spring is the tension in the spring. So, in that sense, tension can be regarded as a force.)In summary, a rubber band behaves like an elastic solid when stretched and the relationship between tension and change in length can be expressed as T = EA(Δl/l). When analyzing the forces on a mass element in a stretched rubber band, the resultant of the two tensions on each end is equal to the centripetal force, which can be written as 2Tsin(Δθ/2). By equating this to the centripetal force equation, we can solve for
Chozen Juan
A uniform thin circular rubber band of mass M and spring constant k has an original radius R. Now it is tossed into the air. Assume it remains circular when stabilized in air and rotates at angular speed ω about its center uniformly. Derive an expression for the new radius of the rubber band. Express your answer in terms of ω, k, M, R, and any fundamental constants.
Fspring = kΔx
Fcp = mω2R
F = ma
C/(2r) = π
I first considered a mass element Δm in the rubber band. This Δm has acceleration ω2R', where R' is the new radius. Of course, this means that the mass element has centripetal force of magnitude ΔF = (Δm)ω2R'.
Furthermore, a rubber band stretched a distance Δx behaves just like a spring; so if a rubber band with initial length 2πR (original radius of the rubber band) is stretched to a final length of 2πR', the magnitude of the force on the rubber band is T = 2πk(R' - R).
But I don't know how to relate the force T to ΔF. Since the center of mass of the rubber band only moves in the up-down direction, I don't think it's true that the sum of all the small ΔF's is T; I think the sum of all the small ΔF's is actually 0 since there's 0 net force on the rubber band in the horizontal plane. Because of this, I don't know how to even use these two equations together.
What more information can I use to solve this problem?
The correct answer is R' = (4π2kR)/(4π2k - Mω2).
Consider a short element of the band subtending an angle dθ at its centre. The tensions at each end are not quite in line. Find an approximate expression for their resultant.
Likes Chozen Juan and Chestermiller
Another way to do this is to imagine the rubber band hypothetically cut in half, and obtain the net resultant acceleration of half the rubber band. Then, from a free body diagram on half the rubber band, write the force balance, including the tensions on the two cut ends.
Likes haruspex
Ok I tried haruspex's method, and it seemed to work. However, I'm still a bit confused as to why it works.
I figured that the small mass element would have tensions on both sides equal to T. The two tensions must be equal since the mass element has no tangential acceleration. So now the free body diagram of the mass element is an isosceles triangle with two equal sides T. The resultant of these two tensions is 2Tsin(Δθ/2), where Δθ is the angle subtended at the center. This resultant vector is the centripetal force and has magnitude Δmω2R'. Since Δθ/2 is so small, sin(Δθ/2) = Δθ/2. The equation is then
TΔθ = Δmω2R'
Integrating both sides, we obtain:
T∫dθ =ω2R' ∫dm ⇒ 2πT = Mω2R' ⇒ T = Mω2R' / (2π)
Another equation we have is F = 2πk(R'-R), where F is the force on the rubber band when the rubber band is stretched linearly a distance of 2π(R'-R). If we equate T to F, then we can solve for R' and obtain the final answer.
But why is F = T? Stretching the rubber band linearly is different from having it stretch in midair. It's difficult for me to intuitively understand this.
Actually, the rubber band should be treated as an elastic solid, rather than a spring. For an elastic solid, the relationship between the tensile force and the change in length is given by: $$T=EA\frac{\Delta l}{l}$$ where E is the Young's modulus, A is the cross sectional area, l is the original length of a portion of the rubber band, and ##\Delta l## is the change in length of the same portion of the rubber band. For this problem, you can use $$\frac{\Delta l}{l}=\frac{2\pi (r'-r)}{2\pi r}=\frac{(r'-r)}{r}$$. So $$T=EA\frac{(r'-r)}{r}$$
Chozen Juan said:
But why is F = T?
Tension is not exactly a force. It is more like a pair of equal and opposite forces. When you maintain a steady pull on a light spring with force F, there is a tension F at each point of the spring. That is, in each small segment of the spring there is a force F pulling at each end. Thus, F=T.
Related to Rubber Band Spinning in midair
1. How does a rubber band spin in midair?
When a rubber band is stretched and released, it contains potential energy. As it recoils, this energy is converted into kinetic energy, causing the rubber band to spin in a circular motion.
2. What factors affect the speed of a rubber band spinning in midair?
The speed of a rubber band spinning in midair is affected by the initial release velocity, the amount of stretch in the rubber band, and the air resistance it encounters.
3. Can a rubber band spin indefinitely in midair?
No, a rubber band will eventually lose momentum and stop spinning due to air resistance and the dissipation of its potential energy.
4. How does the shape of the rubber band affect its ability to spin in midair?
A rubber band with a wider shape will have more surface area and thus more air resistance, causing it to spin slower than a thinner rubber band with less surface area.
5. Is it possible to control the direction of a spinning rubber band in midair?
Yes, the direction of a spinning rubber band can be controlled by the angle at which it is released and the amount of force applied to one side of the rubber band.
