NTL2009
- 596
- 380
All the references I find refer to safely charging lithium cells by a method like this:
https://www.powerstream.com/li.htm
The next page shows the effects on capacity of charging to less than the 4.2 V terminal cell voltage. For example, charging to 4.0 V still provides 73% of the capacity achieved at 4.2V, with a 4x improvement in life cycle. That might be a good trade-off if getting that last 27% of capacity isn't a priority.
https://www.powerstream.com/lithium-ion-charge-voltage.htm
I think the above means that it would be safe to design a very simple charger, just a 4.0 V source, with enough source resistance to limit current to ~ .2 C at the lowest voltage ( ~ 2.8 V) . No specific current changes at the top, since you would never reach the 4.2 V terminal voltage. With a 4.0 V ~ 4.1 V source, current would drop to zero before hitting that terminal 4.2 V.
I'm thinking about circuits to provide a few hours of back up to a low draw (~40 mA?) 5 V device, just to protect against short term power outs, or unplugging the device to move it. The charge time could be long, these would be rare events.So for a 150mA cell, a divider off a 5 V source, with a source R of ( (5 - 2.8) / (.2 * .15) ) ~ 73 Ohms. So 5 V feeding a 75/300 Ohm divider would do it. Ahhh, that 300 Ohm would draw ~ 13 mA when power is out, reducing battery up time by ~ 8%. If that's an issue, feed a BJT emitter follower with a voltage divider @ 4.7 V to get 4.0 out, and the b-e junction will isolate the battery when power is out. The emitter follower would be lower impedance, so you can use higher values in the divider, and put the 75 Ohm between the emitter and the battery.
Maybe increase the low voltage C rate closer to 1, it will be dropping as the battery charges, and approaching zero as you reach the terminal 4.0 V level.
These small, cheap 150 mAH have high/low voltage cut-offs (BMS) built in ( < $2 each at aliexpress << link to search). But I kinda hate to rely on their high voltage cutoff for something that will be on 24*7*365, plus, it goes open circuit for high voltage cut-off, so you might need to regulate your source anyhow. I've got a half dozen of these little batteries for my micro-quad copters, and have tested the cut-offs. For me the advantage is simple, common parts, versus buying a specific charger circuit plus BMS, waiting for shipping, etc. And cheaper, but that's minor for one-offs
Thoughts?
The lithium ion battery is easy to charge. Charging safely is a more difficult. The basic algorithm is to charge at constant current (0.2 C to 0.7 C depending on manufacturer) until the battery reaches 4.2 Vpc (volts per cell), and hold the voltage at 4.2 volts until the charge current has dropped to 10% of the initial charge rate. The termination condition is the drop in charge current to 10%.
Thoughts?
