Safe zero base reactivity level nuclear fission reactor?
In summary, a nuclear fission reactor with a zero base reactivity level would be able to stop the nuclear decay chain reaction more or less immediately when the reactor is turned off. However, this type of reactor would require a different design than the usual fission reactors.
consuli
62
TL;DR Summary
Is it possible to create a safe nuclear fission reactor, that - when turned off - immediately falls down to a reaction level close to natural decay?
There are already 4 generations of nuclear fission reactors. (Compare https://en.wikipedia.org/wiki/Nuclear_reactor#By_generation.)
However among these, there does not seem to be a (maximum) safe nuclear fission reactor design, which immediately stops the nuclear chain reaction when the reactor is turned off. I guess this is related to the following:
  1. Large amount of nuclear fuel.
  2. Usual impossibility to remove the nuclear fuel element out of the reactor, when the reactor is operation. (Because the fuel element is very hot and highly radioactive.)
Effectively, this leads to risk of meltdown, namely the risk nuclear fuel can continue the nuclear fission chain reaction, when the reactor is already turned off, especially also when the nuclear has already become molten. To prevent the meltdown risk high efforts for cooling the reactor and backup power have to be taken in place.
Q1: Is it possible to create a nuclear fission reactor, that has a zero base reactivity level, so that the nuclear decay chain will stop more or less immediately when the reactor is turned off, respectively a meltdown-risk free nuclear fission reactor?
I am thinking about a nuclear fission reactor, that
  • contains less nuclear fuel
  • is based on nuclear fuel in liquid form
  • has a more effective neutron moderator than water
  • would only process significant chain reaction, when the nuclear fuel ions are concentrated in a small volume by an electrical field (and will fall down to natural decay immediately, when the electrical field is switched off)
Q2: What would be necessary to create such zero base reactivity level nuclear fission reactor?
You are a little off base. Inserting the control rods stops the chain reaction.
The problem with fission reactors is what we call decay heat, which can be as high as 15% of rated power immediately after the chain reaction is stopped.
Decay heat is produced by the radioactive decay of unstable isotopes produced after splitting the atoms of the fuel. i.e. the so-called fission-products.
That is not a chain reaction.
So you're correct identifying decay heat as the origin of the safety problem, but wrong in calling it a chain reaction.
Nuclear fusion, not fission, is the usual silver bullet that people look towards as a safer form of nuclear power.
There are fission reactor designs that claim to be safer. For example.
https://en.wikipedia.org/wiki/Pebble-bed_reactor said:
This type of reactor is claimed to be passively safe;[1] that is, it removes the need for redundant, active safety systems. Because the reactor is designed to handle high temperatures, it can cool by natural circulation and still survive in accident scenarios, which may raise the temperature of the reactor to 1,600 °C.
Likes Astronuc
The challenge of course is that a different design such as the pebble bed reactor will have different failure modes, not all of which are readily predictable. So I'd take any claims of superior safety by a new design with a grain of salt.
For instance, the Julich experimental pebble bed reactor wound up contaminating much of its environment because the pebble feed jammed at 3 am and the operators tried to clear the blockage with a broomstick.
They broke over 40 pebbles, releasing fissionable material all over the site.
Likes anorlunda
Related to Safe zero base reactivity level nuclear fission reactor?
1. What is a safe zero base reactivity level nuclear fission reactor?
A safe zero base reactivity level nuclear fission reactor is a type of nuclear reactor that is designed to maintain a stable and safe level of reactivity, which is the measure of how quickly the nuclear reactions occur. This is achieved by carefully controlling the amount of fuel and the rate of neutron production in the reactor.
2. How does a safe zero base reactivity level nuclear fission reactor work?
A safe zero base reactivity level nuclear fission reactor works by using a controlled chain reaction of nuclear fission to produce heat, which is then used to generate electricity. The reactor is designed to maintain a constant level of reactivity, which prevents the reaction from becoming too fast and potentially causing a meltdown.
3. What makes a safe zero base reactivity level nuclear fission reactor safer than other types of nuclear reactors?
A safe zero base reactivity level nuclear fission reactor is considered safer than other types of nuclear reactors because it is designed to operate at a lower reactivity level, which reduces the risk of a nuclear accident. Additionally, the reactor is designed with multiple safety features and protocols to prevent and mitigate any potential accidents.
4. Are there any potential risks associated with a safe zero base reactivity level nuclear fission reactor?
While a safe zero base reactivity level nuclear fission reactor is designed to be safer than other types of nuclear reactors, there are still potential risks involved. These include the release of radioactive material in the event of an accident, as well as the proper management and disposal of nuclear waste.
5. How is the reactivity level controlled in a safe zero base reactivity level nuclear fission reactor?
The reactivity level in a safe zero base reactivity level nuclear fission reactor is controlled through various means, such as using control rods to absorb excess neutrons, adjusting the amount of fuel in the reactor, and monitoring the rate of neutron production. These measures help to maintain a safe and stable level of reactivity in the reactor.
  • Nuclear Engineering
12K
