Scalar field energy density and pressure in hot universe
In summary, Kolb&Turner's discussion on the evolution of the universe using Friedman's equation involves considering a scalar field at finite temperature, where the pressure and energy density are related to the potential energy including temperature corrections. This is obtained from the free-energy computed at finite temperature in perturbation theory, and the results quoted are the results after summing over momentum modes. For late-term cosmology, the pedestrian free-particle equations of state are usually used, but for early times, the finite temperature, interacting theory results are necessary.
karlzr
131
Kolb&Turner in "the early universe" mentioned that for a scalar field ##\phi## at finite temperature, ##p=-V_T(\phi)## and ##\rho=-p+T\frac{d p(T)}{d T}## where ##V_T## is potential energy including temperature correction. My question is: when we consider the evolution of the universe using Friedman's equation, should we use this kind of definition of ##\rho## and ##p## or we stick to those obtained from stress energy tensor? I would say the latter since that's what we can get from Einstein's equation. But then I don't understand what are Kolb&Turner's ##\rho## and ##p##. Why doesn't kinetic term contribute to them?
Perhaps the notation is unfortunate, but ##V_T(\phi)## there is not the scalar potential, but rather the free-energy computed at finite temperature in perturbation theory. So one puts the particles in an appropriate box with finite temperature boundary conditions (periodicity) and computes the partition function
$$ Z = \int \mathcal{D}\phi \exp \left\{ -\int_0^\beta d\tau \int d^3x \, \mathcal{L}(\phi) \right\}.$$
The effective action is ##-\ln Z## and is the sum of 1-particle irreducible diagrams. This quantity is called the "effective potential" because the perturbative calculation is done over diagrams where the external field legs are set to the vacuum expectation value of the scalar field. There are no physical external particles in the process.
The results quoted there are the results once the sum over momentum modes has already been done. There is a reference to [3] for the result which is the classic paper of Dolan and Jackiw, but a random web-accessible source is this master's thesis that seems to include the relevant calculations.
For most calculations of late-term cosmology, the pedestrian free-particle equations of state are appropriate. However, for early times, when phase transitions are possible, the finite temperature, interacting theory results are necessary.
Related to Scalar field energy density and pressure in hot universe
1. What is a scalar field energy density?
A scalar field energy density refers to the amount of energy contained within a specific area of space. It is a measure of the energy per unit volume of a scalar field, which is a type of field that has a single numerical value at each point in space.
2. How is scalar field energy density related to the hot universe?
In the context of the hot universe model, scalar field energy density is a crucial factor in determining the expansion rate and evolution of the universe. It is the dominant component of the total energy density in the early stages of the universe's history, and plays a significant role in the inflationary period and subsequent expansion.
3. What is the pressure of a scalar field in a hot universe?
The pressure of a scalar field in a hot universe is a measure of the force that the field exerts on the surrounding space. It is directly related to the scalar field energy density and is an important factor in determining the dynamics of the universe, including its expansion and the formation of large-scale structures.
4. How does the energy density and pressure of a scalar field change over time in a hot universe?
In the hot universe model, the energy density and pressure of a scalar field are not constant, but instead change over time. During the early stages of the universe's expansion, the energy density dominates and the pressure is negative, driving inflation. As the universe cools, the energy density decreases and the pressure becomes positive, causing the expansion to slow down.
5. What are the implications of scalar field energy density and pressure for the fate of the hot universe?
The energy density and pressure of a scalar field are crucial factors in determining the ultimate fate of the hot universe. Depending on the values of these parameters, the universe may continue to expand indefinitely, eventually leading to a cold and empty state, or it may eventually collapse in a "big crunch." The exact fate of the universe is still a topic of ongoing research and debate among scientists.
  • Quantum Physics
