Seeing history when crossing event horizon
  • #36
Ibix said:
I would say there's a null path along the horizon, yes, but if I'm not mistaken light from older crossings will be redshifted into oblivion. So I doubt you'd actually see anything much.
I'd agree that the image is faint, but I don't think it's due to redshift. By my analysis, light emitted right at the instant of the event horizon should just stay there, without gaining or losing any energy. As I see it, the problem is that the number of photons with just the right timing to stay on the horizon gets lower and lower. Unfortunately, I don't have a rigorous calculation, so my intuition could be incorrect.
If we consider a very long spaceship falling into an ultra-massive black hole, consider looking at a light on the bow of the ship from the stern. Nothing special happens to the light in the bow as we consider longer and longer ships (no redshift for an ultra-massive blackhole), but it gets fainter and fainter due to the distance from the bow to the stern. For a black hole with finite mass, there will be some redshift due to tidal forces, but that redshif will be present through the entire falling process, it won't suddenly start as the ship crosses the horizon.
  • #37
Why do you think so? In a classical model (or, if you like, in the geometric optics approximation, which should be sufficient here), the light is just null worldlines that coincide with the generators of the horizon. There is no issue of "timing" to stay there; they just stay there.
  • #38
If we consider the distance from the bow to the stern to be constant (which is not quite exact--see below), then this statement is incorrect; there is no redshift from bow to stern. The simplest way to see this is just to adopt Fermi normal coordinates centered on the ship. But if you insist on a global analysis, heuristically, the "gravitational redshift" from bow to stern is exactly cancelled by the Doppler blueshift due to the increase in the falling speed of the stern during the travel time of the light.
In actuality, the bow-stern distance is not constant due to tidal effects, which, since the ship cannot be infinitely rigid, will eventually stretch the ship radially. But for a sufficiently massive hole and a reasonably sized ship this correction is negligible until the ship is well below the horizon.
  • #39
I had two different thought pictures in mind. But, I think that my first thought picture was confused. I was thinking that pulses emitted near the event horizon would be "smeared out" in time, but from a coordinate independent point of view, I don't think that makes any sense. The coordinate dependent viewpoint starts to get confused by the Schwarzchild coordinate singularities, so I think I'll stick with coordinate independent thinking.
The second thought picture is to re-frame the problem of "previous travelers" by imagining that all the travellers are on a very long spaceship falling into the black hole together.
Then, in the limit of an ultra-massive black hole, which requires that the length of the ship is less than the Schwarzschild radius of the black hole, the previous image of the bow of the ship falling in first is nothing mysterious, it's just like watching the bow of the ship from the stern. So - no redshift, for the ultra-massive case. But for any given black hole, eventually the analogy starts to get strained. For Sag A, that would be about a minute between travellers, if my numbers are not too far off.
For the case where the analogy makes sense, though, if we watch a beacon falling into a 4 million solar mass black hole with a 10 second head start, it should be the same as watching the same beacon in Minkowskii space from about 3 million kilometers (3 billion meters). There'll be no redshift, but it'll be fainter in intensity because of the inverse square law.
  • #40
Ah, I see, you were thinking of a spherical wave front instead of a light ray (or "laser pulse", or whatever you want to call it--basically a tight beam that can be represented as a null worldline). Treating it that way means you can no longer use the geometric optics approximation, so the whole problem becomes more complicated. I think the complications don't matter as long as we are restricting consideration to a single local inertial frame in which the wave front can travel from bow to stern.
  • #41
This is no stranger than the optical size of an object decreasing as you go further away. Except described in a rather roundabout manner.
  • #42
Yes, after post #39 I understand what he meant--no redshift, just optical dimming due to distance apart.
