Show that if f: A→B is surjective and and H is a subset of B, then f([
  • Thread starter Scienticious
  • Tags
    Surjective
In summary, we have shown that if f: A→B is surjective and H is a subset of B, then f(f^(-1)(H)) = H. This can be proven by showing that f(f^(-1)(H)) is a subset of H and vice versa, using the fact that f is surjective. However, we must also be careful in considering the case of inverse functions, as it may not always be a function.
Scienticious
[f]^{}[/2]
Show that if f: A→B is surjective and and H is a subset of B, then f(f^(-1)(H)) = H.
Let y be an element of f(f^(-1)(H)).
Since f is surjective, there exists an element x in f^(-1)(H) such that f(x) = y.
But x in f^(-1)(H) implies that f(x) is in H, by definition of inverse functions.
Therefore f(f^(-1)(H)) is a subset of H.
Conversely, for y in H y must also be in f(f^(-1)(H)) since the latter expression is equivalent to H by definition
Since f(f^(-1)(H)) is a subset of H and vice versa, f(f^(-1)(H)) = H.
Scienticious said:
[f]^{}[/2]
This part is good
This part less so. What if f(x) = 0 for all x a real number, and H is the interval [0,1]? What is f(f-1(H)) in this case?
You have to use the fact that f is surjective.
O I understand now I think, thank you :3
f is surjective, so for any y in H we have f(x) = y.
since f^(-1)(H) is in the domain of f by definition of inverse functions,
y = f(f^(-1)(y)) for any y in H and thus H is a subset of f(f^(-1)(H)).
This line of reasoning checks out, right?
Consider using this type of argument: ##A \subseteq B \land A \supseteq B → A = B##.
You need to be a bit more careful. Consider the case of f: ℝ→{0,∞} where f(x)=x2. The mapping ##f^{-1}## isn't a function, which you seem to be assuming. What would ##f^{-1}(4)## be equal to, for instance — 2 or -2?
Related to Show that if f: A→B is surjective and and H is a subset of B, then f([
1. What does it mean for a function to be surjective?
A function is considered surjective if every element in the codomain (output) is mapped to by at least one element in the domain (input). In other words, every element in the codomain has a preimage in the domain.
2. How is the surjectivity of a function related to its range and image?
If a function is surjective, its range (the set of all possible output values) will be equal to its entire codomain. Additionally, the image (the set of all actual output values) will also be equal to the entire codomain.
3. What is the significance of H being a subset of B in this statement?
By stating that H is a subset of B, we are limiting the elements that are being considered in the statement. This means that the function f will only be applied to elements in H, which is a subset of the entire codomain B.
4. How does the surjectivity of f affect the existence of a preimage for elements in H?
Since f is surjective, every element in the codomain B has a preimage in the domain A. This means that for every element in H, there exists an element in A that is mapped to it by f.
5. Can you provide an example to illustrate this statement?
Sure, let's say we have a function f: R→R (real numbers to real numbers) defined by f(x) = x^2. If H is the subset of non-negative real numbers (H = [0, ∞)), then f is surjective and for every element y in H, there exists an element x in R (e.g. x = √y) such that f(x) = y. This shows that f(H) = H, which is a subset of the codomain R.
