Significance of CMB anomalies?
In summary, the authors of the papers indicate that there may be evidence of a new form of physics at work in the CMB, and that further analysis will be required to ascertain the significance of the findings.
Space news on Phys.org
Poster has been reminded of the PF rule to wait at least 24 hours before bumping a thread
Nobody?
Seems like nobody’s willing to waste time reading :rolleyes:
For short the authors listed some well known anomalies in CMB,and noted that in standard view these are seen as statistical flukes.However they calculated the coherence with holographic models and found support .They concluded that these anomalies might not be simply flukes but hints of spacetime’s nature.
Please be patient. The subject matter has come up periodically in other discussions. For example,
https://www.physicsforums.com/threads/hawking-points-discovered-in-cmb.953100/
https://www.physicsforums.com/threads/is-the-universe-anisotropic.1006701/
One could have searched PF for "CMB anomalies" and found several discussions, with the latter aforementioned thread seemingly relevant.
Also, one could search PF to see if someone has already cited the ArXiV paper(s).
Likes vanhees71, phinds and berkeman
And the OP can look at the list of "Related Threads" at the bottom of the page... :wink:
Likes vanhees71
Certainly, once a thread is created. :wink: I was thinking preemptively.
Likes vanhees71 and berkeman
Seems like somebody expects others to jump to do their bidding when they snap their fingers. Seems like some people think PF is composed of their servants.
Likes vanhees71 and phinds
It seems, @Adrian Lee, we've two recent papers with shared authors.
The first paper concludes, "The results presented here are not conclusive, but are striking enough to warrant additional studies."
And the second paper concludes, "These results motivate further investigation of the possibility that the 2D angular correlation function of primordial curvature may be governed by causally-coherent quantum gravity."
So, as with other potentially anomalous events, it may be nothing...or it may be something, but more telescope time (and a new CMB telescope!) is required to progress the thinking.
Likes vanhees71 and PeroK
Guys,I’m deeply sorry for my arrogance.I thought that PF’s got a lot of members and maybe someone’s going to be there at once…Apologies anyway!:bow:
No worries. Thanks for that.
So have the replies from Astro or Melbourne or the Releated Threads helped?
Likes vanhees71
Yes,to some extent I am educated that maybe these anomalies aren’t as significant as they seem to be.Lack of academic experience leads to my disability to identify.:wink:
Likes vanhees71
It's an understandable infraction, @Adrian Lee, social media has tuned us to expect instantaneous reactions to our every little utterance. But irrespective of the number of members, a response to a technical question with two studies cited was always likely to take time. Unless it's obvious quackery or someone has encountered the research before, people need to read the papers, digest the concepts, assess the methodology, and consider their response 👍
As for the significance of the anomalies examined, they seem typical of the "it looks like something is here, if only we had more data," cosmological investigation. The something is a flavour of holographic inflation but the analysis detailed in the papers requires a lot of manipulation of CMB maps and it seems a non-trivial effort to walk through the method and ascertain the conclusion that hints of new physics is lurking in the data. The authors expect that telescopes that can separate cosmological signals from astrophysical foregrounds (and note the The Primordial Inflation Explorer (PIXIE) as one example mission, I'm not sure if that's planned, it was being talked about about a decade ago from memory) will be needed to resolve the issue.
Likes Astronuc
Hi Mel,
Don’t blame it on the social media,it’s all my fault.
About the paper,Hogan has been trying different approaches towards holography.PF threads earlier talked about his “holometer “,and he has been on this program since 2000s.So,it is that you think,the analysis isn’t conclusive,but supportive indeed ,and they would use further data?This seems to be their conclusion too.I just can’t tell to what extent it is “supportive “!:wink:
Looking the conclusion section in 2109.11092.pdf:
A simple geometrical model, constrained by precise null symmetries, agrees quantitatively with data.
Seems supportive. Then,
These results motivate further investigation of the possibility that the 2D angular correlation function of primordial curvature may be governed by causally-coherent quantum gravity. Demonstration of an exact symmetry of the two-point correlation function on large angular scales would have a profound significance. Instead of being an uninter-esting, anomalous fluke of random cosmic variance, the large-scale pattern of anisotropy could carry unique, pre-cise signatures of basic principles underlying holographic quantum gravity.
So there is some significance.
More precise tests of this possibility, and of specific candidate holographic models and symmetries using CMB data, will require better control of Galactic foregrounds.
They suggest 'better control of Galactic foregrounds. I'd wonder about intergalactic foregrounds over the age of the universe.
What do the authors indicate about the WMAP and Planck results?
In the other paper, 2110.00120.pdf, looking at the summary,
Our results lend support to a new interpretation of long-studied large-angle CMB anomalies [15]: several of them may not be independent random statistical flukes, but may be related signatures of new physics not currently included in the standard quantum system used to describe inflation.
and then a reference to more data carefully
One promising path forward to improve these would be better multi-frequency maps, preferably over the entire sky. New all-sky experiments, in particular PIXIE [22, 23], will provide all-sky CMB maps with well controlled large angular scale systematics and very broad spectral coverage to markedly reduce the uncertainties in the low-ℓ CMB structure.
I’d note that 2109.11092 is the [15] in 2110.00120!:wink:And that’s how I came to the former.
Ahhh, I see a lot of that in scientific literature, and I find it self-serving and rather annoying. I also often see essentially the same work published in slightly different format in multiple journals in the same field, which is another annoyance.
Likes Melbourne Guy
However the case here isn’t (completely)self-serving.One seems to be the theoretical discussion and the other tends to calculate.:approve:
So in summary,these literature provides data in favor of holographic inflation but aren’t conclusive,and would require more data to make sure that these “really aren’t “underinteresting flukes!
Fair enough.
Related to Significance of CMB anomalies?
1. What is CMB and why is it significant?
The Cosmic Microwave Background (CMB) is the leftover radiation from the Big Bang that fills the entire universe. It is significant because it is the oldest light in the universe and provides us with valuable information about the early universe, such as its temperature and composition.
2. What are CMB anomalies and why are they important?
CMB anomalies are unexpected patterns or variations in the CMB radiation that cannot be explained by current theories. They are important because they could potentially challenge our understanding of the universe and lead to new discoveries.
3. What are some examples of CMB anomalies?
Some examples of CMB anomalies include the Cold Spot, a large area of the CMB with lower temperature than expected, and the Axis of Evil, a pattern of aligned fluctuations in the CMB that defy the predictions of the standard model of cosmology.
4. How do scientists study CMB anomalies?
Scientists study CMB anomalies by analyzing data from satellite missions such as the Planck satellite and ground-based telescopes. They use statistical methods and computer simulations to identify and analyze anomalies and compare them to theoretical predictions.
5. What could be the possible explanations for CMB anomalies?
There are various proposed explanations for CMB anomalies, including the presence of primordial magnetic fields, interactions with dark energy or dark matter, or even the possibility of a multiverse. However, further research and data analysis are needed to determine the true cause of these anomalies.
  • Cosmology
