Simple angular acceleration problem
In summary, the question is asking for the angular acceleration of a 4 meter long rod hinged at one end and released from a horizontal position. The formula for angular acceleration is given as (Tan. Accel.)/(radius), and when calculated with a force of 9.8m/s^2 and radius of 4m, the answer is 2.45rad/s^2. However, the correct answer is 3.6 rad/s^2, indicating that there is another force at play. This can be explained by considering the torque about the pivot and identifying the force acting to create the angular acceleration.
joseg707
32
A 4 meter long rod is hinged at one end. The rod is initially held in the horizontal position, and then released as the free end is allowed to fall. What is the angular acceleration as it is released?
Ang. Accel. = (Tan. Accel.)/(radius)
(9.8m/s^2)/(4m)= 2.45rad/s^2
The answer is 3.6 rad/s^2.
I don't know what I'm doing wrong. Gravity is the only force acting on the rod, but there is something that I'm not taking into account. Can someone point me in the right direction please?
Consider the torque about the pivot.
What is the force acting to create the angular acceleration.
Your calculation for the angular acceleration is correct, but the given answer is incorrect. The correct answer is 2.45 rad/s^2. It is possible that the given answer was a typo or a mistake. When solving a problem, it is always important to double check your calculations and make sure they are consistent with the given information and equations. In this case, the given answer does not match the equations provided and the correct calculation. It is also important to pay attention to units and make sure they are consistent throughout the calculation.
Related to Simple angular acceleration problem
1. What is angular acceleration?
Angular acceleration is a measure of the rate at which the rotational velocity of an object changes over time. It is typically measured in radians per second squared (rad/s^2) or degrees per second squared (deg/s^2).
2. How is angular acceleration different from linear acceleration?
Angular acceleration describes the change in rotational velocity, while linear acceleration describes the change in linear velocity. Angular acceleration is also measured in different units and follows different equations than linear acceleration.
3. How do you calculate angular acceleration?
Angular acceleration can be calculated by dividing the change in angular velocity by the change in time. The formula for angular acceleration is: α = (ω2 - ω1) / (t2 - t1), where α is angular acceleration, ω is angular velocity, and t is time.
4. What is the difference between average and instantaneous angular acceleration?
Average angular acceleration is calculated over a specific time interval, while instantaneous angular acceleration is calculated at a specific moment in time. Average angular acceleration is represented by a bar over the variable (α̅), while instantaneous angular acceleration is represented by a dot over the variable (α̇).
5. How can angular acceleration be applied in real-world situations?
Angular acceleration can be used to analyze the motion of objects that rotate, such as wheels, gears, or pendulums. It is also applicable in fields such as physics, engineering, and astronomy for understanding and predicting the behavior of rotating systems.
