Simple Q about induction motor
In summary, induction motors have a torque created by the interaction of the stator field and the currents in the squirrel cage of the rotor. When the rotor speed is synchronous with the excitation field in the stator, there are no currents generated in the squirrel cage and thus no torque. This explains why at certain speeds, such as 1500 RPM for a 4-pole motor, there is no torque. However, at slightly lower speeds, such as 1450 RPM, there is a lot of torque.
aabbddlah
hello
i v got a small question about induction motors
why does the steady state torqe is equal to zero when rotor speed is equal to 314 rad/s? and
why when rotor speed is for example is equal to 100 , torque maintain a higher positive value
many thanks
Induction motors have a copper busbar cage (called a squirrel cage) embedded in the rotor laminations. The torque is created by the stator field interacting with the field created by the currents in the squirrel cage. No currents are generated in the squirrel cage when the rotor RPM is synchronous with the excitation field in the stator. So a 4-pole induction motor has no torque at 1500 RPM (50 Hz), but a lot at 1450 RPM.
Bob S
Hi there,
Thank you for your question about induction motors. The steady state torque is equal to zero when the rotor speed is equal to 314 rad/s because at this speed, the rotor is rotating at synchronous speed with the magnetic field of the stator. This means that the rotor and stator magnetic fields are perfectly aligned, resulting in no torque being produced.
On the other hand, when the rotor speed is lower, such as 100 rad/s, the rotor is rotating at a speed lower than synchronous speed. This causes a difference in speed between the rotor and stator magnetic fields, resulting in a positive torque being produced to try to align the two fields.
I hope this helps to answer your question. If you have any further questions, please let me know. Thank you.
Related to Simple Q about induction motor
1. What is an induction motor?
An induction motor is a type of electric motor that uses electromagnetic induction to create rotational motion. It consists of a stator (stationary part) and a rotor (rotating part) and works by inducing a current in the rotor, which then interacts with the magnetic field created by the stator to produce motion.
2. How does an induction motor work?
An induction motor works by using the principle of electromagnetic induction. When an alternating current is passed through the stator windings, it creates a rotating magnetic field. This rotating magnetic field then induces a current in the rotor, which in turn creates its own magnetic field. The interaction between the two magnetic fields produces a torque that causes the rotor to rotate.
3. What are the advantages of an induction motor?
Induction motors have several advantages, including their simplicity, reliability, and low maintenance requirements. They also have a high starting torque and can operate at variable speeds. Additionally, they do not require any brushes or commutators, making them suitable for use in hazardous environments.
4. What are the applications of induction motors?
Induction motors are used in a wide range of applications, including industrial machinery, household appliances, electric vehicles, and HVAC systems. They are also commonly used in pumps, fans, compressors, and conveyor systems.
5. How do you maintain an induction motor?
Regular maintenance is important for ensuring the proper functioning and longevity of an induction motor. This includes checking and replacing worn out bearings, inspecting the rotor and stator for any damage, and keeping the motor clean and free of debris. It is also recommended to have a professional technician perform routine checks and maintenance on the motor.
  • Electrical Engineering
