Single particle Density Matrix meaning
In summary, the conversation discusses the definitions and interpretations of the second order reduced density matrix and the single particle density matrix in an n-electron system. The main point of the 1-particle reduced density matrix is that its knowledge is sufficient to evaluate the expectation values of all 1-particle operators for the system. The off-diagonal elements of the 1-RDM are closely related to covalent bonding in simple wave functions. The use of primed variables in the complex conjugate is a trick to be able to calculate through the electron density, which is more easily available than the wave function.
jajabinker
Hey guys!
In an n-electron system,
The second order reduced DM is defined as
[tex]\Gamma (x_{1},x_{2}) = \frac{N(N-1)}{2}\int{\psi(x_{1},x_{2}...,x_{n})\psi^{*}(x_{1},x_{2}...,x_{n})}dx_{3}...dx_{n}[/tex]
It can be intepreted as the probability of finding two electrons at [itex]x_{1}[/itex] and [itex]x_{2}[/itex] respectively for all possible configurations of the other electrons because of the probabilistic interpretation of [itex]|\psi\psi*[/itex]
The single particle density matrix is defined as :
[tex]\gamma (x_{1},x'_{1}) = N\int{\psi(x_{1},x_{2}...,x_{n})\psi^{*}(x'_{1},x_{2}...,x_{n})}dx_{2}...dx_{n}[/tex]
Where the prime variable appears only in the complex conjugate of the function.
Can this be interpreted in probabilistic terms? why is there a prime? What is the meaning of the product of a wave function with its complex conjugate and having a different variable.
I know that for the diagonal terms it reduces to [itex]\rho (r)[/itex].
Any replies are much appreciated.
The main point of defining the 1-particicle reduced density matrix (or 1-RDM) is that its knowledge is sufficient to evaluate the expectation values of all 1-particle operators for the system. Consider the matrix as expanded in a basis set in 2nd quantization:
[tex]
\gamma_{rs}:=\langle c^\dagger_r c_s\rangle
[/tex]
where r/s are the basis labels and the c's are creation and destruction operators. Then for any 1-particle operator o
[tex]
\hat o = \sum_{rs} o_{rs} c^\dagger_r c_s
[/tex]
its expectation value [itex]\langle \hat o \rangle[/itex] can obviously be evaluated with the RDM only, without knowing the actual wave function.
This does not say anything about the direct interpretation of the 1-RDM of course. But in simple kinds of wave functions (Slater determinants), the off-diagonal elements of the 1-RDM are closely related to covalent bonding. For example, the Wiberg bond order (pure covalent bond order) is defined as
[tex]B_{AB}=\sum_{r\in A,s\in B}|\gamma_{rs}|^2[/tex]
where r are AO basis functions of the first atom A and s the AO basis functions of the second atom B (how those are defined is another matter, they are not technically observable, but there are sensible ways of defining them).
However, this interpretation is relying (indirectly) on the fact that for such determinant wave functions the 2-RDM can also be expressed in terms of the 1-RDM, not only the other way around---bond order is really a 2-particle property.
Nevertheless, there is one thing one can learn from that: Unlike the diagonal elements, the off-diagonal elements of the 1-RDM have no simple classical analogon and represent pure quantum effects.
Thanks for your answer but it did not answer my question, which was why do we need primed variables in the complex conjugate?
Anyways here is the answer from Mcweeny and Sutcliffe:
Consider the expectation value of an operator F:
[itex]\langle F\rangle=\int\psi ^{*} (x) F \psi(x)dx[/itex]
If we want to write this in terms of the electron density, [itex]\rho=\psi ^{*} \psi[/itex]
we need F to be able to commute wit [itex]\psi*[/itex], which is generally not true for an integral or differential operator.
So we give dummy variables to [itex]\psi ^{*}[/itex] called x'. These no longer interact with the operator F and we can integrate safely at x=x'.
So this is just a trick used to be able to calculate stuff through the electorn density which is more easily available than the wave function.
Related to Single particle Density Matrix meaning
1. What is a single particle density matrix?
A single particle density matrix is a mathematical representation of the probability distribution of a single particle in a quantum system. It is used to describe the quantum state of a single particle in terms of its position and momentum.
2. How is the single particle density matrix different from the many-body density matrix?
The single particle density matrix describes the probability distribution of a single particle, while the many-body density matrix describes the probability distribution of a group of particles. The single particle density matrix is a reduced form of the many-body density matrix.
3. What is the physical significance of the single particle density matrix?
The single particle density matrix provides information about the quantum state of a single particle, including its position, momentum, and other properties. It is used to calculate the expectation values of observables and can also be used to study the dynamics of a single particle in a quantum system.
4. How is the single particle density matrix related to the wave function?
The single particle density matrix is related to the wave function through a mathematical transformation known as the Wigner transform. The wave function describes the quantum state of a system as a whole, while the single particle density matrix describes the state of a single particle within that system.
5. Can the single particle density matrix be used to study entanglement?
Yes, the single particle density matrix can be used to study entanglement between particles in a quantum system. By examining the correlations between the single particle density matrices of different particles, it is possible to determine the degree of entanglement between them.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
