Sinusoidal graphs (y=sinx and y=cosx equations)
In summary, a sinusoidal graph is a smooth, continuous curve that represents the relationship between a sine or cosine function and its input values. The main difference between the equations y=sinx and y=cosx is the starting point of the graph, as well as the amplitude and period. The amplitude of a sinusoidal graph is the distance from the midline to the highest or lowest point, and can be calculated using the coefficient A in the equations y=Asin(Bx) or y=Acos(Bx). A sinusoidal graph can have a negative amplitude if the coefficient is negative. The period of a sinusoidal graph is the length of one complete cycle and can be calculated by dividing 2π by the coefficient B in the equations
becca_j
i was wondering how you would find the amplitude, vertical translation, horizontal translation and the sinusoidal axis either from just an equation, like 1/2(y-7)=cos3(x-60), or from the graph if you are given one.
Mathematics news on Phys.org
Write it in the form y= and the items you want would be obvious.
amplitude = 2, vertical (also axis) = 7, period = 2pi/3
To find the amplitude of a sinusoidal graph, you need to look at the coefficient of the sine or cosine function. In the equation 1/2(y-7)=cos3(x-60), the coefficient of the cosine function is 1/2. This means that the amplitude is 1/2.
To find the vertical translation, you need to look at the constant term in the equation. In this case, the constant term is -7. This means that the graph is shifted down 7 units.
To find the horizontal translation, you need to look at the value inside the parentheses. In this case, it is (x-60). This means that the graph is shifted to the right 60 units.
The sinusoidal axis is the midline of the graph and can be found by taking the average of the maximum and minimum values of the graph. If you are given a graph, you can simply draw a horizontal line passing through the middle of the graph and determine the y-value at that point. This will give you the sinusoidal axis.
If you are given an equation and asked to graph it, you can use the information above to plot points and create the graph. Alternatively, you can also use transformations to graph the equation. For example, for the equation y=cosx, the graph has an amplitude of 1, no vertical or horizontal translation, and a sinusoidal axis at y=0. This means that the graph will have a maximum value of 1 and a minimum value of -1, with the x-axis as the midline. To graph y=cos3x, you can use the following transformations:
- The coefficient of x is multiplied by 3, which means the graph will be compressed horizontally by a factor of 3.
- The graph is not shifted vertically or horizontally, so there is no vertical or horizontal translation.
- The sinusoidal axis remains at y=0.
Using these transformations, you can plot points and create the graph of y=cos3x. Similarly, you can use transformations to graph any sinusoidal equation given to you.
Related to Sinusoidal graphs (y=sinx and y=cosx equations)
1. What is a sinusoidal graph?
A sinusoidal graph is a type of graph that represents the relationship between a sine or cosine function and its input values. It is a smooth, continuous curve that repeats itself over a specific interval.
2. What is the difference between y=sinx and y=cosx equations?
The main difference between these two equations is the starting point of the graph. The graph of y=sinx starts at (0,0) and goes upwards, while the graph of y=cosx starts at (0,1) and goes downwards. Additionally, the amplitude (height) and period (length of one cycle) of the graph are different for each equation.
3. How do you find the amplitude of a sinusoidal graph?
The amplitude of a sinusoidal graph is the distance from the midline (average value of the graph) to the highest or lowest point. For the equation y=Asin(Bx), the amplitude is equal to A. For the equation y=Acos(Bx), the amplitude is equal to |A|.
4. Can a sinusoidal graph have a negative amplitude?
Yes, a sinusoidal graph can have a negative amplitude. This occurs when the coefficient A in the equation y=Acos(Bx) is negative, resulting in a downward opening graph.
5. How do you find the period of a sinusoidal graph?
The period of a sinusoidal graph is the length of one complete cycle. It can be calculated by dividing 2π by the coefficient B in the equations y=Asin(Bx) or y=Acos(Bx). The period is equal to 2π/B.
  • General Math
  • General Math
  • General Math
  • General Math
