Smaller electrode gap implies misfire;why?
In summary, a smaller gap increases the chances of a misfire because there is a smaller activated volume.
marellasunny
255
My book says smaller the electrode gap,greater the chances of a misfire. The reason stated is that this is because of a smaller activated volume.
I understand the meaning of misfire: it is when electricity takes a different path due to electrically conductive residue lying between electrode and ground. What I do not understand is why a misfire occurs with a smaller electrode gap.
Basically, it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression. Loss of spark includes anything that prevents coil voltage from jumping the electrode gap at the end of the spark plug. Causes include worn, fouled or damaged spark plugs, bad plug wires or even a cracked distributor cap. A weak coil or excessive rotor gas inside a distributor would affect all cylinders, not just a single cylinder.
Misfire can occur if the gap it too wide. This is usually the case when the spark plugs have ben in the engine too long..too many miles and the electrode is worn down to where the gap is too wide for the coil to overcome the gap. And is the gap is to narrow.. yes it will misfire. . Usually .015 or less...have seen them run on .010-.015 but they don't take much to fuel foul, carbon bridge, or in some cases , water or oil foul. All it takes is a tiny bit of water (condensation) between the ground and electrode and it won't generate a spark. Remember-electricity takes the path of least resistance and normally if there's water, oil, carbon, or fuel in between the gap, electricity will usually flow right through without creating enough heat to ignite a mixture. The heat comes from electricity's resistance to flowing through air. The "pop" you hear when the spark arcs is the sound of the air expanding around the arc itself, similar sound lightning causes thunder the same way. .fyi
Misfire due to loss of spark: This could either mean that no spark travels across the gap(as you say that electricity gets diverted across least resistance) OR this could also mean a spark being diverted because of a higher conducting material?
Is the second case possible?
I suspect your book is referring to a cylinder mis-fire, not an electrical mis-fire. A smaller gap has a higher chance of the mixture failing to ignite. Electrically, it increases the chance of the coil output following the correct path. A larger gap (and thus longer arc) has a higher mixture volume (the book's 'activated volume') exposed to the arc, thus increasing the chance of proper combustion.
Related to Smaller electrode gap implies misfire;why?
1. Why does a smaller electrode gap lead to misfires?
A smaller electrode gap means there is less space for the spark to jump from the center electrode to the ground electrode. This can result in a weaker spark or a spark that is unable to ignite the fuel-air mixture, leading to a misfire.
2. Can a smaller electrode gap cause engine damage?
In most cases, a smaller electrode gap will not cause any significant damage to the engine. However, if the gap is too small, it can cause the spark plug to overheat and potentially damage the engine. It is important to follow the manufacturer's recommended gap for your specific vehicle.
3. How does the electrode gap affect engine performance?
The electrode gap plays a crucial role in the ignition process. A smaller gap can result in a weaker spark, leading to a decrease in engine power, fuel efficiency, and overall performance. It is important to maintain the proper electrode gap for optimal engine performance.
4. What is the recommended electrode gap for my vehicle?
The recommended electrode gap can vary depending on the make and model of your vehicle. It is best to consult your owner's manual or a trusted mechanic for the correct gap for your specific vehicle.
5. How often should I check and adjust the electrode gap?
It is recommended to check and adjust the electrode gap every 30,000 miles or as specified by the manufacturer. Over time, the gap can widen due to wear and tear, causing a decrease in performance. Adjusting the gap can help maintain optimal engine performance and prolong the life of your spark plugs.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • Atomic and Condensed Matter
