Solving Kepler's 1st law as a function of time
In summary, the conversation discusses the poster's attempt to solve a differential equation using WolframAlpha and their question about purchasing Wolfram|Alpha Pro for better computation time. They also mention their goal of verifying Kepler's first law through solving the differential equation. Some solutions and equations are presented, but the conversation ultimately ends without a solution.
jebez
TL;DR Summary
p , ε , c constants :
θ'(t)(p/(1+ε cos(θ(t))))^2=c
θ(t)=?
Hi
I posted this differential equation to WolframAlpha https://www.wolframalpha.com/input?i2d=true&i=Power[\(40)Divide[a,1+b*cos\(40)y\(40)x\(41)\(41)]\(41),2]*y'\(40)x\(41)=c but no solution , " Standard computation time exceeded... Try again with Pro computation time "
Should I ( buy and ) post to Wolfram|Alpha Pro ? I don't want to buy Pro if it doesn't solve it ... Maybe someone who has Pro can post it ? Lend his/her account ?
In fact we have r(θ) = p/(1+ε cos(θ)) ( 1st Kepler's law ) , r²θ'(t)=c ( 2nd Kepler's law ) and I want r(t) so need to solve the differential equation .
https://en.wikipedia.org/wiki/Kepler's_laws_of_planetary_motion
Thanks .
jebez said:
In fact we have r(θ) = p/{1 + ε cos(θ)) ( 1st Kepler law ) , r² θ'(t) = c ( 2nd Kepler law ) and I want r(t) so need to solve the differential equation .
Thanks .
Surprisingly, perhaps, there is no closed-form solution other than for circular orbits. :frown:
Likes topsquark
jebez said:
TL;DR Summary: p , ε , c constants :
θ'(t) (p/(1 + ε cos(θ(t))))^2) = c
θ(t) = ?
Hi
In fact we have r(θ) = p/(1 + ε cos(θ)) ( 1st Kepler law ) , r² θ'(t) = c ( 2nd Kepler law ) and I want r(t) so need to solve the differential equation .
Thanks .
Have a look at
https://www.wolframalpha.com/input?i=arccos(y(t))'=(a+b*+y(t))^2
Likes topsquark
The equation is separable in [itex]\theta[/itex], so [tex]
\int_{\theta(0)}^{\theta(t)} \frac{1}{(1 + \epsilon\cos\phi)^2}\,d\phi = \frac{ct}{p^2}.[/tex] But that's as far as you can go: there is no known antiderivative for the integrand when [itex]\epsilon \neq 0[/itex].
Likes topsquark and PeroK
What's wrong with my substitution ##y(t)=\cos\theta(t)##? Nasty, but it looks like it has an implicit solution.
Well sorry I thought equations will be rendered automatically like WolframAlpha , it seems to need LaTeX but I never used this and it seems tiresome ...
In fact I want to verify if r(t) is solution to this differential equation to prove the Kepler's 1st law :
c , G , M constants :
c²/r(t)^3-G M/r(t)²-r''(t)=0
r(t)=?
r(θ)=?
Having again r²θ'(t)=c ( 2nd Kepler's law ) , centrifugal force=m r θ'(t)² and gravity force=G M m/r² so
force=m r''(t)=centrifugal force - gravity force
m r''(t)=m c²/r(t)^3-G M m/r²
then above .
And same problem with WolframAlpha .
The usual approach is to set [itex]u = 1/r[/itex] and [tex]\begin{split}
\frac{dr}{dt} &= \frac{dr}{d\theta}\frac{d\theta}{dt} = \frac{L}{r^2}\frac{dr}{d\theta} = -L\frac{du}{d\theta} \\
\frac{d^2r}{dt^2} &= \frac{L}{r^2} \frac{d}{d\theta}\frac{dr}{dt} = -L^2u^2\frac{d^2 u}{d\theta^2}
\end{split}
[/tex] whence [tex]
\frac{d^2u}{d\theta^2} + u = \frac{GM}{L^2}[/tex] which we can solve for [itex]u(\theta)[/itex].
In fact WolframAlpha does give an antiderivative [tex]
\int \frac{1}{(1 + \epsilon\cos\theta)^2}\,d\theta = \frac{\epsilon \sin \theta}{(\epsilon^2 - 1)(\epsilon \cos \theta + 1)}
- \frac{2\operatorname{artanh}\left( \frac{(\epsilon-1)\tan(\frac12\theta)}{\sqrt{\epsilon^2-1}} \right)}{(\epsilon^2 - 1)^{3/2}} + C[/tex] but we then have the problem of solving that for [itex]\theta[/itex].
Likes PeroK
I found r=p/(1+ε cos(θ(t)) is solution to c²/r(t)^3-G M/r(t)²-r''(t)=0 :
r²θ'(t)=c
θ'(t)=c/r²
(dr/dθ)(dθ/dt)=dr/dt=v=r'(θ)c/r²=c ε sin(θ)/p
v'(θ)=c ε cos(θ)/p
(dv/)(dθ/dt)=dv/dt=r''(t)=ε cos(θ)(c(/1+ε cos(θ)))²/p^3
c²(1+ε cos(θ)/p)^3-G M(1+ε cos(θ)/p)²-ε cos(θ)(c(/1+ε cos(θ)))²/p^3=0
c²-p G M=0 as bonus .
Feel free to edit my posts to render equations , yes I can do it myself but it would be nice automatically ...
Seriously?
Which word in the "LaTeX Guide" link below the Edit window did you have trouble understanding?
  • Haha
Likes PhDeezNutz
jebez said:
I can't edit my previous messages to render equations , I'm just lazy to do that sorry and it isn't copyable ...
Please be sure to use LaTeX from now on here. Thank you.
- Copy your
As I suggested above, you should substitute [itex]u = 1/r[/itex] and eliminate [itex]t[/itex] as the independent variable in favour of [itex]\theta[/itex]. This gives you [tex]
u'' + u = \frac{GM}{L^2}[/tex] where [itex]L = r^2 \dot \theta[/itex] is constant. This is a linear ODE with constant coefficients which can be easily solved: [tex]
r(\theta) =\frac{1}{u(\theta)} = \frac{L^2/GM}{1 + \epsilon\cos(\theta - \theta_0)}.[/tex]
Likes PeroK
I can't edit my messages #6 and #9 but r=c²/(G M(1+ε cos(θ))) , c²/r(t)³-G M/r(t)²-r''(t)=0 can be simplified :
c²/r(t)-r(t)²r''(t)=G M
c²G M(1+ε cos(θ))/c²-c⁴/(G M(1+ε cos(θ)))²ε cos(θ)(G M)³(1+ε cos(θ))²/c⁴=G M .
Sorry pasmith but I don't understand from -L du/dθ in #7 ...
Well I found how to inverse t(θ) to θ(t) with WolframAlpha and Mathematica :
InverseFunction[(a^2 Integrate[(1/(1 + b Cos[x]))^2, x])/c]
but both didn't solve it , see https://community.wolfram.com/groups/-/m/t/2697668?p_p_auth=2VkMYTxA .
And ( maybe ) simplification :
t(θ)=(a^2 ((b sin(x))/((b^2-1) (b cos(x)+1))-(2 (b-1) tan(x/2) coth(x))/(b^2-1)^2+d))/c .
t(θ)=$$\frac{a^2 \left(\frac{b (x \sin )}{\left(b^2-1\right) (b (x \cos )+1)}-\frac{2 (b-1) (x \tan ) (x \coth )}{2 \left(b^2-1\right)^2}+d\right)}{c}$$
( a=p , b=ε , c=c , d=t0 )
given by Mathematica ( I've 15 days trial ) , not WolframAlpha .
There's also the differential equation θ'(t)=c((1+ε cos(θ(t)))/p)² aka y'(x)=c((1+b cos(y(x)))/a)² in Mathematica gives :
{{y(x)->InverseFunction[1/2 ((b sin(#1))/((b^2-1) (b cos(#1)+1))-(2 tanh^-1(((b-1) tan(#1/2))/Sqrt[b^2-1]))/(b^2-1)^(3/2))&][(c x)/(2 a^2)+Subscript[c, 1]]}}
$$\left\{\left\{y(x)\to \text{InverseFunction}\left[\frac{1}{2} \left(\frac{b (\text{$\#$1} \sin )}{\left(b^2-1\right) (b (\text{$\#$1} \cos )+1)}-\frac{2 ((b-1) (\text{$\#$1} \tan ))}{\left(b^2-1\right)^{3/2} \left(\left(2 \sqrt{b^2-1}\right) \tanh \right)}\right)\&\right]\left[\frac{c x}{2 a^2}+c_1\right]\right\}\right\}$$
What is # and & here ?
With Mathematica I can copy as LaTeX .
  • Wow
Likes PeroK
Related to Solving Kepler's 1st law as a function of time
1. What is Kepler's 1st law?
Kepler's 1st law, also known as the law of ellipses, states that all planets orbit around the sun in elliptical paths with the sun at one of the foci.
2. How is Kepler's 1st law solved as a function of time?
To solve Kepler's 1st law as a function of time, the equation for the orbital radius must be used, which is r = a(1-e^2)/(1+e*cos(theta)), where a is the semi-major axis, e is the eccentricity, and theta is the angle between the planet and the perihelion.
3. What is the significance of solving Kepler's 1st law as a function of time?
Solving Kepler's 1st law as a function of time allows us to calculate the position of a planet at any given time, which is crucial for predicting and understanding the motion of celestial bodies.
4. Are there any limitations to solving Kepler's 1st law as a function of time?
One limitation is that this method assumes a two-body system, meaning that the gravitational pull of other planets or objects is not taken into account. Additionally, it assumes that the orbit is stable and does not account for any perturbations.
5. How does solving Kepler's 1st law as a function of time contribute to our understanding of the universe?
By solving Kepler's 1st law as a function of time, we are able to accurately predict the motion of planets and other celestial bodies, which has allowed us to make significant advancements in our understanding of the universe and its workings.
  • Astronomy and Astrophysics
  • Classical Physics
  • Thermodynamics
