Southeastern Massachusetts Conference Math League: Set theory, gcf,lcm
In summary: No, it's not quite that simple. 4 and 8 are both divisible by 2 but LCM(4,8)=8, not 4*8/2=16. Maybe it would be simplest just to look at...In summary, Jimmy could own a maximum of 2520 baseball cards.
RubixRevenge
2.) if jimmy piles his baseball cards in stacks of 4, then there is 1 left over. if he piles them in stacks of 7, there are 4 left over. If he piles them in stacks of 9, there are 6 lefty over. If he piles them in stacks of 10, there are 7 left over. compute the smallest amount of baseball cards Jimmy could own.
maybe using LCM?
I spent 1 hour trying to figure out the solution and the only things I could figure out were that the ones digit has to be 7. I spent the rest of my time testing numbers with my calculator.
However, if this was the actual competition, I wouldn't have a calculator and I would only have 3-4 minutes to solve it. so I have no clue.
maybe using LCM?
There are systematic ways to do this. See for example, http://en.wikipedia.org/wiki/Method_of_successive_substitution. There's also http://en.wikipedia.org/wiki/Chinese_remainder_theorem for the case where your pile sizes are relatively prime (which yours aren't). To do it in 3-4 minutes without a calculator would probably take a lot of practice, and accurate arithmetic, but I'm guessing there are people would could do that.
This one is special. If you would never have any cards left (so you can pile them in stacks of 4,7,9,10), you would multiply the stack numbers: 4*7*9*10=2520
but note the sequence:
4 -> 1
7-> 4
9-> 6
10->7
You are always 3 cards short for the next stack!
4 -> 1
7-> 4
9-> 6
10->7
Ooo. That's clever. So n=(-3) is an obvious solution. And you can add the product to get another. But that's not going to give you the smallest solution. I think you want an LCM instead of the product.
2517 is the smallest number of cards: 4*7*9*10 - 3
Really? Then why does 1257 cards work as well?
Yes, you're right, my mistake. But I don't know how you can see that actually 4*7*9*10/2 - 3 is the minimum.
All that matters is that 4, 7, 9 and 10 divide the number you are adding to -3. So the smallest number to add is the least common multiple of 4, 7, 9 and 10. Which is only their product if they are relatively prime.
bigfooted, that's because if there were always zero cards left over you would want the least common multiple of 4,7,9 and 10, you wouldn't just multiply them all together.
Yes, I see that you shouldn't simply multiply because 4 and 10 are not prime. So when a and b are both divisible by 2, then the LCM is a*b/2? And when a and b are both divisible by prime p, then the LCM is a*b/p? And the LCM of a*b*p1*p2*p3 with prime numbers p1,p2,p3 is a*b/2*p1*p2*p3?
No, it's not quite that simple. 4 and 8 are both divisible by 2 but LCM(4,8)=8, not 4*8/2=16. Maybe it would be simplest just to look at http://en.wikipedia.org/wiki/Least_common_multiple
True, but it works when a and b have only two prime factors with multiplicity 1, and in your example, 8 has multiplicity 2. For multiplicity 2 you have to divide by 2^2:
LCM(4,8)=4*8/2^2=8
I see in your wiki link that I should just multiply the prime factors with the highest multiplicities, so
LCM(4,7,9,10)=LCM(2^2, 7, 3^2, 2^1 * 5) = LCM(4,7,9,5) = 4*7*9*5=1260
OK, that makes sense now.
Related to Southeastern Massachusetts Conference Math League: Set theory, gcf,lcm
1. What is the Southeastern Massachusetts Conference Math League?
The Southeastern Massachusetts Conference Math League is a competitive math league for high school students in the southeastern region of Massachusetts. It aims to promote and develop students' mathematical skills through challenging math problems and competitions.
2. What is set theory and why is it important in math?
Set theory is a branch of mathematics that deals with the study of sets, which are collections of objects or elements. It is important in math because it provides a foundation for other mathematical concepts and helps in understanding mathematical structures and relationships between different sets.
3. What is GCF and how is it calculated?
GCF stands for Greatest Common Factor, which is the largest number that can evenly divide two or more given numbers. It is calculated by finding the common factors of the numbers and then selecting the largest one.
4. What is LCM and how is it calculated?
LCM stands for Least Common Multiple, which is the smallest number that is divisible by two or more given numbers. It is calculated by finding the multiples of each number and then selecting the smallest one that is common to all numbers.
5. How can I prepare for the Southeastern Massachusetts Conference Math League?
To prepare for the Southeastern Massachusetts Conference Math League, you can practice solving math problems, participate in math competitions, and review concepts such as set theory, GCF, and LCM. It is also helpful to work on improving your problem-solving skills and time management.
  • Computing and Technology
  • Beyond the Standard Models
  • Quantum Physics
  • Math Proof Training and Practice
  • Quantum Interpretations and Foundations
  • Quantum Physics
10K
