- #36
Nugatory
Mentor
- 14,863
- 9,390
Neither. A hovering object is one that that is firing a rocket straight down with enough force to keep ##r## (which must be greater than ##R_S## for hovering to be possible) fixed so neither climbing up out of the gravity well nor falling deeper in.John SpaceY said:when you write "you are hovering at radial coordinate r above the black hole" you want to say that the speed of the spacecraft is in the direction of the center of the black hole or the spacecraft is turning around the black hole at a distance r ?
If we are dealing with a solid planet that is not a black hole, then the solid surface will be at some ##r## greater than ##R_S## so it is possible to "hover" just by standing on the surface; the upwards force of the ground on our feet works just as well as a rocket to keep us in the same place, neither falling inwards nor climbing up into the sky.
Note that a hovering observer will have non-zero proper acceleration.
