Spinning Toroid shaped objects
In summary, the conversation discussed the observation of a toroid shaped object made of foam rotating and vibrating while being tossed around in a class. The main cause of this phenomena was determined to be the intermediate axis theorem, which states that any object with the ability to vibrate will do so. Further experiments were conducted with different velocities and air resistance, but the exact reason for the object's vibration was not determined. The conversation ended with a request for more information and a video of the experiments.
Prannoy Mehta
94
In our class we were playing with a toroid shaped object made of foam (Probably). While tossing it around, not only was the disc rotating simply. It was well, sort of vibrating. Like one end of the object is up and the other is down then after a small interval the vice versa occurs. What is the main cause of this phenomena ? Is this an example of a toroid shaped example.
Thank you.
Thank you.
I have a personal theorem: if it can vibrate in some way, then it will.
I think we need more detail on what you observed. How long was this torus in the air? How dense is this foam? Could air resistance be a factor? How symmetric is the shape?
It was symmetric, there were no visible signs of damage. Torus was in the air for perhaps maximum 1-2 seconds, we were throwing it from one end of the class to the other The distance it traveled was about 10 - 15m. Density of the foam is something I can't comment but it was as squishy as a tennis ball. Can't comment about air resistance. It was non porous, and did not seem to be hollow.
I'd say distance traveled was too short to make any clear conclusion without sophisticated equipment.
I will try at larger distances tomorrow when we go back to school.. Thank you :)
Hello Anyone ? Please reply ?
Seeing the video, there's nothing strange going on at all. When thrown, the angular momentum is not aligned with the major axis. This is because the thrower isn't perfectly spinning the torus along this axis.
We tried, doing many other experiments with this. First one was, throwing it diagonally because I assumed that could be a good answer, it din't work. The torus spun perfectly no vibrations at all. Then we suspected something to do with the velocity inside and outside (Air resistance) We covered it with foil on one side, the vibration increased, when covered on both sides there were no vibrations. Then we threw it vertically, vibrations occured. The video of the other cases has been misplaced. The foil seemed really convincing but we failed to come up with appropriate reasons to why it would go up and down.
Related to Spinning Toroid shaped objects
1. What is a spinning toroid shaped object?
A spinning toroid shaped object is a three-dimensional object that resembles a donut or a ring. It is a solid object with a hole in the middle and a circular cross-section. The object spins around its central axis, giving it a toroidal or donut-like shape.
2. How are spinning toroid shaped objects created?
Spinning toroid shaped objects can be created through various methods such as 3D printing, casting, or machining. They can also be formed naturally, such as in the case of planets and stars.
3. What properties do spinning toroid shaped objects have?
Spinning toroid shaped objects have unique properties due to their shape and rotational motion. They exhibit gyroscopic stability, which means they resist changes in their orientation. They also have a moment of inertia, which is the object's resistance to changes in its rotational speed.
4. How are spinning toroid shaped objects used in science and technology?
Spinning toroid shaped objects have various applications in science and technology. They are used in gyroscopes for navigation, in flywheels for energy storage, and in particle accelerators for research. They also have applications in engineering, such as in bearings and gears.
5. Can spinning toroid shaped objects exist in different materials?
Yes, spinning toroid shaped objects can exist in different materials, including metal, plastic, and even liquid. The material used will affect the object's properties, such as its weight, strength, and ability to spin smoothly. Some natural examples of spinning toroid shaped objects include Saturn's rings and vortex rings in fluids.
  • Other Physics Topics
