Square-Root of a binomial squared
  • Thread starter lightlightsup
  • Tags
    Binomial
In summary, the equation has two solutions, depending on whether the number is greater than or less than the given integer, 3.
lightlightsup
95
##\sqrt{(a-b)^2}=\sqrt{4x^2}##
##±(a-b)=±2x##
Is this a correct distribution of the ##±##s?
None.
Suppose that ##a##, ##b##, and ##x## are integers.
How would the ##±##s be correctly assigned in such an equation?
The solutions to that equation are simply ##2x = \pm (a-b)##.
Likes lightlightsup and SammyS
It really doesn't matter. If we were to accept [tex]\pm a= \pm b[/tex] literally there would be four cases:
1) taking "+" on both sides, a= b
2) taking "-" on both sides, -a= -b
But this is just a= b with both sides multiplied by -1. They are the same.
3) taking "+" on the left side and "-" on the right, a= -b
4) taking "-" on the left side and "+" on the right, -a= b
But, again, the second is the same as the first, just with both sides multiplied by -1.
So there are really just two different cases which can be given by either ##a= \pm b## or ##\pm a= b##.
Likes lightlightsup
lightlightsup said:
Homework Statement:: ##\sqrt{(a-b)^2}=\sqrt{4x^2}##
##±(a-b)=±2x##
Relevant Equations:: None.
Most introductory algebra textbooks (at least those of which I am aware) point out that actually, ##\sqrt{u^2 ~ }=|u| ## .
So for instance, solving an equation such as, ## t^2=9 ##, by taking the square root of both sides gives:
## \sqrt{t^2\ }=\sqrt{9\ } ##
simplifying gives: ##|t|=3 ## .
So that if ## t > 0 ##, then ## |t|=t## thus we have ##t = 3## .
However, if ## t < 0 ##, then ## |t|=-t## thus we have ##-t = 3## .
This gives the solutions: ##t = 3## or ##t=-3## .
I tend to think of the ##\pm## method as a short cut of sorts.
Likes lightlightsup and PeroK
I deduced the same thing by just guessing that since both sides being positive or negative would lead to the positives/negatives cancelling out, then, the only remaining scenarios are:
one where only 1 negative sign, and
one where both sides are positive.
I was hoping for a more formal understanding of what was going on.
You guys have provided that to me.
Thank You!
Likes jim mcnamara
Related to Square-Root of a binomial squared
1. What is the square root of a binomial squared?
The square root of a binomial squared is the original binomial itself. This is because the term "squared" indicates that the binomial is multiplied by itself, and taking the square root will undo this operation, resulting in the original binomial.
2. How do you simplify the square root of a binomial squared?
The square root of a binomial squared can be simplified by taking the square root of each term individually. For example, if the binomial is (x+2)^2, then the square root would be x+2.
3. Can the square root of a binomial squared be negative?
No, the square root of a binomial squared cannot be negative. This is because the square root of any number is always positive. However, the binomial itself can be negative if the original binomial contained a negative value.
4. What is the difference between the square root of a binomial squared and just the binomial itself?
The square root of a binomial squared and the binomial itself are equivalent. They both represent the same value, but the square root is a simplified form of the binomial squared.
5. How is the square root of a binomial squared used in real life applications?
The concept of square root of a binomial squared is often used in algebra and geometry to simplify equations and expressions. In real life, it can be used to calculate the length of the sides of a square or to find the distance between two points in a coordinate plane.
