Standard form, vertex form. Something isn't right here
In summary, my homework says that f(x) = x^2+10x+24 is in standard form, but mathewarehouse says that it is already in standard form. I don't understand which is which.
Niaboc67
249
I mainly just need some clarification here. I was doing my homework and then browsing the web to find an answer to my problem and came across mathewarehouse' definition of Standard form and then I looked at my homework and went..."huh?" I don't understand if my homework is listening this wrong or mathwarehouse or if I am misunderstanding something.
Please help
Here are the two images my homework first:
here it is telling me f(x)=x^2+10x+24 is a quadratic function which must be expressed in standard form. But mathewarehouse would leads me to think that it's already in standard form:
What's the deal?
The standard form is expressed by completing the square.
The vertex is simply the point on the parabola where the graph changes direction, as shown on the graph you posted above, the (h,k) coordinate which is determined from the vertex form equation (complete the square equation of the function).
I still don't understand. These two things are giving me conflicting ideas. Which is which? Is f(x)=x^2+10x+24 a quadratic function or is standard form? So maybe it's just trying to confuse me? and I just need to put it in twice and then to find the vertex but completing the square aka putting it in vertex form? is that right?
Is a quadratic function something which is already in standard form?
An equation can be expressed in standard or vertex form. A quadratic function in standard form is f(x) = a(x - h)2 + k.
It's just semantics really, albeit confusingly laid out above.
The standard and vertex equations ( y =) are referred to as standard and vertex respectively and in that sense are not incorrect in what is being shown, however, a quadratic function in standard form is expressed as f(x) = a(x - h)2 + k.
So in the question you are being asked to express a function in standard form, you complete the square. As with most mathematical questions a follow on effect is used, your answer for (a) is guiding you towards the answer for (b).
@Jimmy Johnson THANKS A TON! that clears up a lot. This math program I am using likes to be purposely cryptic I think.
You need to use whatever definition your program is using for the term "standard form." I don't think many textbooks would call y = a(x - h)2 + k "standard form" but your program seems to be doing this.
No - standard form is the [itex] ax^2 + bx + c [/itex] version, and [itex] a\left(x-h\right)^2 + k [/itex] is the vertex form. Your text is using the names in a non-standard way - as is #5.
I agree.
In most cases of this topic I've seen in textbooks or online the standard form of a quadratic function is expressed in vertex form. However I agree that it is inconsistent throughout different teachings etc.
"Different textbooks have different interpretations of the reference "standard form" of a quadratic function. Some say f (x) = ax2 + bx + c is "standard form", while others say that f (x) = a(x - h)2 + k is "standard form". To avoid confusion, this site will not refer to either as "standard form", but will reference f (x) = a(x - h)2 + k as "vertex form" and will reference f(x) = ax2 + bx + c by its full statement."
Nevertheless I think we can all agree that the standard form of this question is looking for the vertex form.
No, I don't think we can agree on that. Perhaps the book (or on-line course, or whatever) really does mean that a*x^2 + b*x+c is the standard form, and maybe the question is merely asking the student to recognize that the given function is already in standard form. Sometimes simple exercises like that are given to help firm up a concept in a student's mind, the theory being that repetition helps. However, I would hope that somewhere in the course notes or lectures (or whatever) the concepts of "standard form" and "vertex form" are actually defined.
That was my thought, as well.
It appears that your quote is from the link: http://mathbitsnotebook.com/Algebra1/Quadratics/QDVertexForm.html .
I agree with you that the terminology "standard form" for a quadratic function is not standard. I currently teach College Algebra using a textbook by Ron Larson. In my view, it's unfortunate that he refers to the well named "Vertex Form" as the "Standard Form" for quadratic functions. This seems to be a fairly wide-spread practice in these lower level Algebra textbooks. It's rather inconsistent (again, that's in my view) because these same books often refer the "standard form" of a quadratic equation as being: ax2 + bx + c = 0.
Larson uses the terminology, "General Form" for a quadratic function written as: f(x) = ax2 + bx + c .
That's my two cents.
SammyS
Related to Standard form, vertex form. Something isn't right here
1. What is the difference between standard and vertex form?
Standard form is a way of writing a quadratic equation in the form of ax^2 + bx + c, while vertex form is a way of writing it in the form of a(x-h)^2 + k. The main difference is that vertex form can easily identify the vertex of the parabola, while standard form cannot.
2. When should I use standard form and when should I use vertex form?
Standard form is useful for graphing and solving quadratic equations using the quadratic formula. Vertex form is useful for quickly identifying the vertex of a parabola and for graphing parabolas using transformations.
3. How do I convert an equation from standard form to vertex form?
To convert from standard form to vertex form, you can use the process of completing the square. First, factor out the coefficient of x^2. Then, take half of the coefficient of x and square it. Add this number to both sides of the equation, and then factor the resulting perfect square trinomial. This will give you the equation in vertex form.
4. What does it mean if something doesn't seem right when using standard or vertex form?
If something doesn't seem right when using standard or vertex form, it could mean that there is an error in the equation itself or in the calculations. Double check your work and make sure all steps were followed correctly.
5. Is there a preferred form to use for quadratic equations?
It depends on the situation. Both standard and vertex form have their own advantages and uses. It is recommended to use the form that is most convenient for the specific problem or situation at hand.
  • General Math
  • General Math
