Static friction coefficient question
In summary, The question is asking for the coefficient of static friction for a drag racer that covers a quarter mile in 6.0 seconds assuming a constant acceleration and no slipping of tires. Using the kinematic formula, the acceleration was calculated to be 22.36 m/s^2. The friction force can be found by subtracting the applied force from the normal force multiplied by the coefficient of friction. However, in this case, the applied force and friction force are equal since the car is accelerating as fast as it can without losing traction. This means that the coefficient of friction can be solved for using the given information.
hamsterpower7
43
from giancoli 5th ed (algebra based)
chapter 4, question 42
Drag race tires in contact with an asphalt surface probably have one of the higher coefficients of static friction in the everyday world. Assuming a constant acceleration and no slipping of tires estimate the coefficient of static friction for a drag racer that covers the quarter mile in 6.0s
I converted quarter mile to m ----> 402.5m
using kinematic formula i found the acceleration a=22.36 m/s^2
[tex] \Sigma F = F_A - F_fr [/tex]
[tex] F_A - \mu_s F_N = mass 22.36 m/s^2 [/tex]
and than I got stuck...
the answer key states that I shouldn't have put applied force in the equation
but how does that make sense? the person should have put applied for to have constant acceleration
anyways if there wasn't a applied force I can solve for static friction from the equation above
help me please
Keep in mind that the friction force (coefficient of friction times mass of car times acceleration of gravity) will be equal to the applied force (mass of car times its acceleration) if you assume that the car is accelerating as fast as it can without losing traction.
I don't get this, isn't applied force and friction force two separate force?
In this case, they are one and the same! The car's tire is exerting a friction force parallel to the ground that accelerates the car. That friction force can be no greater than the tire's normal force times the coefficient of friction.
Hello,
Thank you for your question. I can understand why you may be confused about the concept of static friction and the lack of an applied force in the equation provided. Let me try to explain it in a bit more detail.
First, let's define the coefficient of static friction as the ratio of the maximum static friction force to the normal force between two surfaces. In this case, the surfaces are the drag racer's tires and the asphalt surface. The coefficient of static friction is dependent on the materials of the two surfaces and is a measure of how well they "stick" together.
Now, in order for there to be static friction, there must be a force acting on the tires that is trying to make them slip on the ground. This force is known as the applied force or the driving force. In the case of a drag racer, this would be the force from the engine that propels the car forward. However, in this question, we are assuming that the acceleration is constant and there is no slipping of the tires. This means that the applied force is equal to the maximum static friction force, and this is why it does not need to be included in the equation.
So, to solve for the coefficient of static friction, we can use the equation you provided:
Since we know that the acceleration is constant and there is no slipping, we can rewrite this equation as:
\Sigma F = ma - F_fr
And since we are looking for the coefficient of static friction, we can rearrange this equation to solve for it:
\mu_s = \frac{ma - F_fr}{F_N}
Now, we know that the mass is given, and we can calculate the normal force using the weight of the car (mass x gravity). The only unknown in this equation is the maximum static friction force, which we can calculate using the acceleration and the mass of the car. Once we have all the values, we can solve for the coefficient of static friction.
I hope this explanation helps to clarify the concept for you. If you have any further questions, please don't hesitate to ask.
Related to Static friction coefficient question
1. What is static friction coefficient?
The static friction coefficient is a measure of the force required to initiate motion between two surfaces that are in contact with each other. It is a dimensionless quantity that is specific to the materials in contact and their surface properties.
2. How is static friction coefficient determined?
The static friction coefficient is determined through experiments and calculations that involve measuring the force required to initiate motion between two surfaces. It also depends on factors such as the roughness of the surfaces, the normal force applied, and the materials in contact.
3. What factors affect the static friction coefficient?
The static friction coefficient is affected by factors such as the roughness of the surfaces in contact, the normal force applied, the materials involved, and the presence of any lubricants or contaminants on the surfaces.
4. Is static friction coefficient constant?
No, the static friction coefficient is not constant. It can vary depending on the factors mentioned above, and it may also change as the surfaces in contact wear down or become smoother over time.
5. How does the static friction coefficient differ from the kinetic friction coefficient?
The static friction coefficient refers to the force required to initiate motion between two surfaces, while the kinetic friction coefficient refers to the force required to maintain motion between two surfaces. The static friction coefficient is typically higher than the kinetic friction coefficient for the same surfaces.
