Static Vs Dynamic Force Analysis in Mechanism
tetris
When should static or dynamic force analysis be applied when analyzing moving mechanisms ?
N/A
My understanding is that :
Static Force Analysis
  • carried out on objects in static or dynamic equilibrium, that is rigid bodies that are not moving or moving with zero acceleration
  • therefore, does not take into account the inertia of the object
  • carried out on objects in motion with an acceleration
  • therefore, takes into account the inertia of the object (along with the angular velocity and angular acceleration)
However, I have seen both static and dynamic force analysis applied to a moving four bar linkage. In the case where I would like to find the force applied to the coupler to move the mechanism from position A to B, would dynamic force analysis be used? Since, the velocity would not be constant, hence, it has an acceleration.
Any help is appreciated, thanks in advance.
Likes Delta2
Welcome! :smile:
It depends on what force is greater.
We are interested on how robust the joint should be to resist those forces.
We can have a light link accelerating much and rapidly, like the connecting rod of a small engine: dynamic forces are more important in that case.
Likes tetris, Delta2 and erobz
Firstly, thank you for your help :smile:
In summary, it depends on the speed of the mechanism. So, for the same mechanism, if one is moving at very high speed, then dynamic analysis would be used. On the other hand, if it is moving at low speed, static analysis would be sufficient since the inertia effects are small.
However, is there a velocity or any other value threshold where dynamic analysis should be applied?
It depends on the accelerations of the mechanism components. There could be a mechanism with a low output velocity, but that experiences large accelerations in its components. Accelerations and mass are what generate force. It really should be taken on a case by case basis.
Likes tetris
What is static force analysis in mechanism?
Static force analysis in mechanism involves calculating the forces acting on a mechanism at rest or in a constant velocity state. It helps determine the internal forces within the mechanism to ensure it can withstand external loads without failure.
What is dynamic force analysis in mechanism?
Dynamic force analysis in mechanism involves calculating the forces acting on a mechanism when it is in motion or experiencing acceleration. It takes into account the inertia forces and accelerations of the moving parts to predict the system's response to dynamic loads.
What are the main differences between static and dynamic force analysis in mechanism?
The main difference is that static force analysis deals with forces in equilibrium, while dynamic force analysis considers forces in motion or acceleration. Static analysis is used to determine if a mechanism is stable under static loads, while dynamic analysis helps understand the system's behavior under dynamic conditions.
When is static force analysis used in mechanism design?
Static force analysis is used in mechanism design when the system is expected to operate under constant loads or at rest. It helps engineers ensure that the mechanism can support the intended loads without failure and provides insights into the distribution of forces within the system.
When is dynamic force analysis used in mechanism design?
Dynamic force analysis is used in mechanism design when the system is expected to experience varying loads, accelerations, or motion. It helps engineers evaluate the system's response to dynamic conditions, predict the forces acting on the components during motion, and optimize the design for performance and durability.
  • Classical Physics
  • Classical Physics
  • Mechanical Engineering
  • Classical Physics
