Sterman's QFT - 2.7b (on functional derivatives)
In summary, the conversation discusses the concept of functional derivatives and the confusion surrounding it, specifically in relation to a passage from Sterman's work. The discussion also touches on references for further understanding of functional derivatives and the differences between the physicist and mathematician definitions. The conversation also delves into the justification for the form of the functional derivative and its relation to the Euler-Lagrange equations.
ddd123
481
55
I've been trying to fill in my mathematical blanks of things I just took as dogma before. Especially, not having a background in functional analysis, the functional derivatives often seem to me mumbo jumbo whenever things go beyond the "definition for physicists".
In particular I tried looking everywhere to make sense of this passage from Sterman's:
I understand everything here but that last ##\equiv## . Especially what makes it look total whatever-y to me is the indices i, j on the RHS. Why does the momentum operator have j and the field i on the numerator, and the field j on the denominator? This could've been totally different and I would've equally said "mmh okay I suppose", something which worries me every time it happens.
If you think it would be beneficial, on top on the answer to this specific part, a primer of functional analysis / derivatives / ? would be appreciated.
Thanks.
The ##j## in the numerator is probably just a typo given that ##f_i(x^0)## was defined before to have ##i## on both arguments. As far as references, the wikipedia entry on "functional derivative" gives the formal mathematical definition of the derivative and develops it briefly. If you really need a longer discussion you might consult the references by Courant and Hilbert and Gel'fand that are listed there.
Apart from the supposed typo, why is that a functional derivative? I only see a delta * a derivative, and the wiki page says nothing about this form.
Yes, I should have said a bit more. The physicist version of the functional derivative is slightly different, but I think consistent with the mathematician's version. In the formal definition one introduces a test function ##\phi(x)## that defines the "direction" in which the functional derivative is taken. In the physicist's definition this test function is morally almost always a delta distribution. I can't give a rigorous derivation, so I do not want to claim too much about it.
Instead, you can derive the physicist's version as a formal process where you can compute the derivative of functionals,
F[\phi_i] = \int f(\phi_i(\mathbf{x}), \nabla \phi_i(\mathbf{x}) ) d \mathbf{x},
by a process in which we use the chain rule (and integration by parts) in order to reduce operations to a fundamental definition
$$ \frac{\delta \phi_i(\mathbf{x})}{\delta \phi_j(\mathbf{y})} = \delta^j_i \delta(\mathbf{x}-\mathbf{y}).$$
The presence of the delta distribution also means that, while the functional expression includes an integral over the domain of the functions ##\phi_i##, in the physicist's functional derivative, the integral is gone, having been taken care of by the delta.
Sterman is trying to justify the form of the functional derivative in a slightly different way, which I suppose would be more clearly related to the mathematician's definition. You should be able to verify that the rule I suggested above is completely consistent with Sterman's treatment and leads to the Euler-Lagrange equations, etc.
Likes ddd123
Related to Sterman's QFT - 2.7b (on functional derivatives)
1. What is Sterman's QFT - 2.7b?
Sterman's QFT - 2.7b refers to a specific version of Quantum Field Theory (QFT) developed by the physicist George Sterman. It is a mathematical framework used to describe the behavior of subatomic particles and their interactions.
2. What are functional derivatives in QFT?
Functional derivatives in QFT are mathematical tools used to represent the change in a functional (a function that takes in other functions as inputs) when its input function is varied. They are an important tool in QFT as they allow for the calculation of physical quantities such as particle interactions and scattering amplitudes.
3. How do functional derivatives differ from regular derivatives?
Functional derivatives differ from regular derivatives in that they operate on functions instead of numerical values. They are also defined in terms of an integral rather than a limit, making them more complex to calculate.
4. What are some applications of Sterman's QFT - 2.7b?
Sterman's QFT - 2.7b has a wide range of applications in physics, including the study of particle physics, quantum electrodynamics, and quantum chromodynamics. It is also used in the development of theoretical models for understanding the behavior of subatomic particles and their interactions.
5. How does Sterman's QFT - 2.7b contribute to our understanding of the universe?
Sterman's QFT - 2.7b, like all versions of QFT, provides a mathematical framework for understanding the behavior of matter and energy at the smallest scales. This allows scientists to make predictions and test theories about the fundamental nature of the universe and its building blocks. It has also been crucial in the development of quantum technologies, such as quantum computing and quantum cryptography.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
