Strong light material to be lifted by a drone?
In summary: It's strong and light, but it's also fairly expensive. You could use composites or plastic, but those materials are also more expensive.
Pidge
Hi, I am currently constructing a personal project, and I was wondering if anybody knew any thin material that was relatively light weight, cheap, and as strong as wood. I understand that carbon fiber exists, but this material is rather expensive. If anyone knows alternatives to using wood or carbon fiber, please inform me. Thanks.
Material also needs to be able to be lifted by a small drone.
What's wrong with good old aluminium?
What do you mean by "strong" ? HOW strong? Wood strength varies quite a bit. What is the application? If you want a helpful answer, give helpful information.
EDIT: Hm ... I see you are a new member. Perhaps you don't have much experience formulating specific scientific questions. You'll find that the most informative questions elicit the most helpful answers.
Wood is relatively light weight, cheap, and exactly as strong as wood. Why won't this work?
  • Haha
Likes Dale, russ_watters and Borek
Carbon fibre is much stronger than wood. How about plastic? Plastics are about as strong as wood.
It depends on what condition of the project your working on. A great alternative to wood is wood composite. Or you want something malleable and easy to work with-- Go for flexi acrylic sheet.
I recall reading (I think I was looking into RC plane DIY builds at the time), that most wood had similar strength/density ratios.
Looking at this site,
http://www-materials.eng.cam.ac.uk/mpsite/interactive_charts/strength-density/basic.html
if I'm interpreting correctly (big if, I'm not an ME or materials science guy), it seems that sort of holds true for many/most materials. It looks to me that some wood has a better/similar strength/density versus the lower grades of aluminum? That doesn't seem right to me. Maybe the scales don't work that way, I was assuming that a line crossing the 10x axis intersects (going from lower left to upper right) on that chart would mean that X Kg of any material on that line would have the same strength?
If you describe what you want to build it will help to suggest possible materials and or techniques that are both light and strong.
Fiberglass?
Related to Strong light material to be lifted by a drone?
1. How much weight can a drone lift?
The weight a drone can lift depends on its size, power, and design. Generally, most consumer drones can lift up to 2-3 pounds, while larger industrial drones can lift up to 20 pounds or more.
2. What type of material is best for lifting with a drone?
The best material for lifting with a drone is a strong and lightweight material, such as carbon fiber or aluminum. These materials are durable and can withstand the weight and force of the drone's lift.
3. How does the weight of the material impact the drone's flight?
The weight of the material being lifted can significantly impact the drone's flight. The heavier the material, the more power and energy is required from the drone's motors, which can decrease flight time and maneuverability.
4. Can a drone lift fragile materials?
Yes, a drone can lift fragile materials if they are properly secured and balanced. However, it is important to note that the vibrations and movements of the drone during flight can still potentially damage fragile materials.
5. Are there any safety precautions to take when lifting materials with a drone?
Yes, it is important to follow all safety regulations and laws when operating a drone. When lifting materials, it is crucial to ensure they are properly secured and do not exceed the weight limit of the drone. It is also important to keep a safe distance from people and property to avoid any accidents or damage.
72K
  • Biology and Medical
9K
  • General Engineering
  • Mechanical Engineering
