- #36
- 2,953
- 1,498
Yes, this seems right (as a check for myself ;) ). So this is one example of a general relativistic problem in which a naive intuition gives the wrong answer (the most massive black hole pulls the least), while a Newtonian intuition gives the right answer (the Schwarzschild radius combined with the fact that gravity falls of as one over r squared gives a surface gravity inversely proportional to mass, so the lightest black hole will pull the most). This is a really nice scenario to show different aspects of general relativity (surface gravity as measured at "infinity", surface gravity as measured near the horizon, etc).PeterDonis said:In other words, the areal radius ##r## in both cases is ##2M## + 1 meter. Ok.10 solar masses is not "supermassive", but basically you're asking how things vary with the mass of the hole, so ok.
I'll use SI units throughout.
Some useful constants:
One solar mass: ##1.9885 \times 10^{30}##
Newton's gravitational constant ##G##: ##6.6732 \times 10^{-11}##
Speed of light ##c##: ##299792458##
1 Year: ##31558118.4##
##r = 2GM/c^2## plus 1 meter for
One solar mass hole: ##2953.897##
Ten solar mass hole: ##29529.97##
Redshift factor at ##r## for
One solar mass hole: ##0.01839761##
Ten solar mass hole: ##0.005813797##
Proper acceleration at 1 m above horizon for
One solar mass hole: ##8.266231 \times 10^{15}##
Ten solar mass hole: ##2.617423 \times 10^{15}##
##2GM / c^2 r## at 500 ly for
One solar mass hole: ##6.242327 \times 10^{-16}##
Ten solar mass hole: ##6.242327 \times 10^{-15}##
So we can treat this as "infinity" for both holes. That means the redshift factor above is the factor by which we multiply the proper acceleration at 1 meter above the horizon, to get the force exerted at infinity. So...
Force exerted at infinity for
One solar mass hole: ##1.520789 \times 10^{14}##
Ten solar mass hole: ##1.521716 \times 10^{13}##
Both of these are quite close to the surface gravity, which is the limit of the redshifted proper acceleration at the horizon, and which in SI units is ##c^4 / 4 G M##. So...
Surface gravity for
One solar mass hole: ##1.521819 \times 10^{14}##
Ten solar mass hole: ##1.521819 \times 10^{13}##
Notice how the ten solar mass value 1 meter above the horizon is closer to the limiting surface gravity; that is because 1 meter is a smaller increment in terms of the mass of the hole.
Thanks (and sorry for the late reply)!
