Superposition of waves formula
In summary, ehild was trying to solve a homework problem involving finding the combined elongation of two waves, but she didn't understand the equation. She tried adding the waves together, but ended up getting an incorrect answer.
Gauss M.D.
153
Find the combined elongation of the waves 7sin(wt) and 2sin(wt + pi/4). Express it both in real and complex form.
A = sqrt(A12 + A22 + A1A2cos(Δθ)
I was given the formula above, which I don't understand, but it does spit out the correct amplitude (8.53). But how do I find the phase shift of the new wave? I tried:
g(t) = 7sin(wt) + 2si(wt + pi/4)
g(0) = 2sin(pi/4) = √2
f(t) = 8.53sin(wt + θ)
f(0) = 8.53sin(θ)
But g(0) = f(0) since f(t) = g(t) so 8.53sinθ = √2
arcsin(√2/8.52) = θ = 0.167
Which is incorrect. How do I find the phase of the new wave?
I'm a moron ty
What is meant by elongation? The formula you give looks like the law of cosines. It seems that you are basically vectorically adding the two waves.
BTW, how did you get the answer of 8.53?
Adding two SHM-s with the same angular frequency, f1= asin(wt) and f2=bsin(wt+ψ), it results is a single SHM, with amplitude C and phase constant θ:
g(t)=asin(wt)+bsin(wt+ψ)=Csin(wt+θ)
Applying the addition rule, expand sin(wt+ψ) and sin(wt+θ).
asin(wt)+b[sin(wt)cosψ+cos(wt)sinψ)=C[sin(wt)cosθ+cos(wt)sinθ]
Collect the terms containing sin(wt) and cos(wt):
sin(wt)[a+bcosψ]+bcos(wt)sinψ=Csin(wt)cosθ+Ccos(wt)sinθ
The equation is an identity, it must hold for every value of wt.
If wt = 0 cos(wt) = 1: bsinψ=Csinθ *
When wt=pi/2 sin(wt)=1, cos(wt)=0: a+bcosψ=Ccosθ. **
Square both equations and add them: b2sin2ψ+(a2+2abcosψ+b2cos2ψ)=C2[sin2wt)+cos2(wt)]
Use that sin2ψ+cos2ψ=1
a2+b2+2abcosψ = C2
Dividing the equations * and **
tanθ=sinψ/(a+bcosψ).
You can decide about the quadrants from the sign of sinθ =bsinψ/C, cosθ=(a+bcosψ)/C.
Your solution was correct.
ehild
I didn't mean that Gauss MD's answer was incorrect but if he plugged his numbers into the equation he gave you would get a different answer. He is missing a 2 I believe in the formula. Also, some insight might be helpful. If you have any number of waves, sinusoidal, they can be added vectorically. The answer can easily be achieved by not using the formula but instead doing basic vector addition. Also, the angle is the angle of the resulting vector. If he had 100 waves, added together, at the same frequency, the result could be obtained using simple vector addition that is normally learned in Geometry or Alg 2. In electrical engineering, we often refer to the sinusoids as a phasors represented in this case by 2/_ pi/4 and 7/_ 0. From a mathematical point of view using trig identities, ehild's derivation is correct.
Also some insight, this is still a variation of the law of cosines, from geometry. If you draw the vectors, pi/4 becomes 3pi/4 as the included angle between the vectors and the law of cosines will give the resultant of the sum.
Yes his equation was wrong.
ehild
Related to Superposition of waves formula
What is the superposition of waves formula?
The superposition of waves formula is a mathematical equation that describes the combined behavior of two or more waves as they overlap and interact with each other.
What does the superposition of waves formula tell us?
The formula tells us the resulting amplitude and phase of the combined waves at any given point in space and time. It also helps us understand how the waves interfere with each other and whether they will amplify or cancel each other out.
How is the superposition of waves formula derived?
The formula is derived from the principle of superposition, which states that the displacement of a medium caused by two or more waves at any point is equal to the sum of the individual displacements caused by each wave separately.
What are the variables in the superposition of waves formula?
The variables in the formula include the amplitude and frequency of each individual wave, as well as the distance between the waves and the phase difference between them.
What are some applications of the superposition of waves formula?
The formula is used in various fields such as acoustics, optics, and electromagnetism to analyze and predict wave behavior. It is also used in technologies such as noise-cancelling headphones, diffraction patterns in photography, and radio wave transmission.
