johnq2k7
- 64
1.) When woven material is dry, air will pass directly through. When immersed in water however, clothing can be used to trap air and provide buoyancy.
a.) With the aid of the diagram, explain why this is so?
need help explaining theoreticallly?
b.) Give an eq. which can be used to calc. the buoyance force (Fb) which can be provided by a vertical cylinder of radius r_c, made from a cloth with a uniform pore size of radius r_p. assume that the cloth is completely wetted with water which has a surface energy y and that the cylinder can be as long as is necessary
need help coming up with an equation here
c.) based on your equation what would be the best type of material and shape for a cloth float?
2.) When a drop of water is placed between two microscope slides they stick together.
a.) with the aid of a diagram showing the shape of the interfaces, explain the force holding them together.
my work: they stick together because the force can be balanced horizontally and vertially, since the pressurs across the lower and upper slides are the same ignoring gravitational effects therefore they stick together... not sure if my explanation is correct?
b.) Will the sheets still stick together if they are immersed in water? Explain
no because of the pressure differences between the surface and water would cause the two slides to separate.. not sure if my explanation is correct..
please help me with these theoretical understanding questions!
