Target element in Coolidge tube and x-rays
In summary, the wavelength of the characteristic spectrum will increase, but the length of the cutoff wavelength in the bremsstrahlung spectrum is determined by a specific factor, which can be found through online sources such as the provided links. Additionally, the bremsstrahlung spectrum is affected by the target material and the characteristic spectrum may contain multiple lines.
Asmaa Mohammad
182
I would say that the wavelength of the characteristic spectrum will increase, but what about the bremsstrahlung spectrum? Will the cutoff wavelength will be longer?
There are plenty of online sources for this. Just search for each term, eg. x-ray bremsstrahlung or x-ray cutoff etc
https://www.slideshare.net/mizakamaruzzaman/phy-310-chapter-6 This link covers all the essential points about X-ray production. It answers your question explicitly.
http://www.sprawls.org/ppmi2/XRAYPRO/ this seems a more detailed discussion of all factors and again covers all the points you raise.
You are correct about the characteristic radiation, though remember there may be several lines in the characteristic spectrum.
The bremsstrahlung is affected by the target material because it is a factor in the efficiency of production of bremsstrahlung.
The cutoff wavelength is determined by a specific factor, so you need to check up on that.
Related to Target element in Coolidge tube and x-rays
1. What is the purpose of a target element in a Coolidge tube?
The target element in a Coolidge tube is used to produce x-rays. When high-speed electrons from the cathode strike the target, they generate x-rays through a process called bremsstrahlung radiation.
2. How does the choice of target element affect the properties of the x-rays produced?
The choice of target element can affect the energy and wavelength of the x-rays produced. Different target elements have different atomic structures, which can lead to variations in the energy levels of the electrons involved in x-ray production. This, in turn, can affect the energy and wavelength of the resulting x-rays.
3. Which elements are commonly used as targets in Coolidge tubes?
The most commonly used target elements in Coolidge tubes are tungsten, molybdenum, and copper. These elements have high atomic numbers, which means they have a large number of protons in their nuclei. This makes them ideal for producing x-rays with high energy and short wavelengths.
4. What factors determine the choice of target element in a Coolidge tube?
The choice of target element depends on various factors such as the desired energy and wavelength of the x-rays, the type of application (e.g. medical imaging, industrial testing), and the cost and availability of the element. Tungsten is often preferred due to its high melting point and affordability.
5. Are there any safety concerns associated with the use of target elements in Coolidge tubes?
Yes, there are some safety concerns associated with the use of target elements in Coolidge tubes. The high voltages used in these tubes can cause the target element to heat up significantly, which can lead to potential burns or other hazards if not handled properly. Additionally, the production of x-rays can also pose a risk of radiation exposure if safety protocols are not followed.
